- TRD swaybar
- Suspension
- First Lowered xB2 with PICS
- Can I use my lowered 2004 xB springs on the new 2008 xB???
- Camber kit needed with TRD springs?
- TRD shocks?
- Factory TRD spring
- TRD springs doode
- Hotchkis Sport Suspension
- PDF Installation instructions for TRD springs
- TRD Struts and Shock - Where to get them
- Anyone remove the wiper motor and cowl to install springs
- Can't believe Toyota did this - Can anyone help
- Alignment after Lowering - How many miles
- Camber Kit for 08 xb Do you need it
- OEM TRD Springs Mounted
- Creaking and Clunking new springs.
- 08 XB Alignment specs - Can someone please publish them
- looking for slotted drilled rotors
- Can anyone who lowered their xB2 please read this
- Painted your brake calipers yet?
- 08 XB Eibach Springs released
- Does the TC front strut fit the 08 XB
- TRD Spring or....?
- Got Bags!!!!
- TRD or eibach lower Spring ?
- Brakes
- Aftermarket shocks?
- Maui's 1st 2.25 inch Eibach drop kit for 08 xB
- EIbach Spring
- 08 Suspension
- Bag kit
- Feedback on Air suspension U.A.S.
- Tein is making our springs!!
- Another Randode Special
- Tanabe is also making Springs for the 2nd Gens!
- Wheel studs
- More greatness from Randode - '08 xB 2" drop on 18's
- Part numbers 2nd Gen xB Help
- Springs info
- SuperAutobacs Sale on Springs!
- any lift kit????
- Front springs install instructions
- Hotchkis Lowering Springs
- tien s tech springs
- TRD Springs Installed (pictures)
- TRD spring install HELP needed!
- Want to soften my stock ride...help
- TRD Sway Bar don't work?
- Lowest avail drop spring for new xB??????
- Front strut bar and quick shifter
- just got it last nite!!
- Question about suspension.
- who has springs for 2inch dropped available now to purchase?
- is it okay to cut the trd springs??? XB2????
- Getting the right amount of drop?
- getting frustrated here so can we use the 1st for 2nd gen???
- tein omg
- TRD Springs HELP
- Another Randode Drop on a Gen 2 xB
- Camber available yet?
- Who wants springs other than TRD or Randode's?
- Tanabe Springs are OUT!!!
- Sneak Peak From Hotchkis
- Coilovers are coming
- torque specs for installing springs
- Dropped it and swapped covers
- Just Dropped it 2"+ on Espelir!
- DF's should be here on Thursday/Friday for me...
- Tein is looking for spring test cars!!
- Strut bar releases...
- XB2 on DF's
- What springs to get?
- Where you Jackin' at???
- Here we fellas dropped on Tanabes DF freakinn slammed!!!!
- My xB with Tanabe DF with 18" Enkeis...
- HOW ITS MADE: Tanabe Lowering Springs
- Cheapest place to buy Tanabe DF springs online?
- Front Strut Brace Bar
- Tanabe vs. TRD
- Coilovers suggestions Updated
- KSport Kontrol Coilovers for 2nd gen xB
- Please have mercey on the noob question
- Lower............. rubbing issues
- how to not bottom out and/or scrape.
- Spring Compressor?
- Tanabe DF210's Installed w/ some pics
- TRD Drop
- Negative Camber
- Before and After DF's drop
- K Sport Coilovers are here
- Installed DF210s...and the rear is the same height :/
- Advice on some new DF210's
- SW Xb with Tanabe DF210s on 16" Enkeis (lots of pics)..
- TRD, Tanabe or H&R springs?
- TRD Rear Sway Bar
- KYB Shocks for 2nd gens!
- question about df210
- haha
- Sway bars anyone?
- Eibach sportlines UPDATED: 11/26/07 (No 56k)
- Shocks for the 08 xb?
- how are K sport coil overs
- TRD Performance Shocks
- With TRD Springs need an Alignment and or camber kit?
- Should i get the Tanabe NF210's Or the DF210's or TRD
- TRD Strut Tower Brace Install(56K...not Today)
- TRD Rear Sway Bar Install(56K Beware)
- delete post
- Where to buy Eibach Sportlines for 08 xb?
- Need torque specs please
- HOTCHKIS 08' SWAY BARS ARE HERE!
- Hotchkis Springs!
- Just Installed TRD Springs
- Has anybody lowered the rear only?
- Suspension
- Lowest drop with 20's???
- Measurements of Tanabe DF210 drop
- Which suspension parts do what?
- Aftermarket front strut
- Braided steel brake lines?
- Anyone have the Tanabe NF210's?
- After market TC rotors will they fit?
- whats up Tein??? r they coming out??? and 411???
- DF 210 installed PICS
- *Official Tanabe NF210 thread. Post'em up!*
- DF210 on 08 SW xB2
- TRD shocks & TANABE NF210 springs?
- Brake pedal pressure?
- Raising the xB2's?
- Wheel Speed Sensor Broken
- Can't decide between tanabe springs or hotchkis. Advice?
- Pics K Sport paired with Hotchkis
- Alignment specs?
- Just installed the TRD rear sway bar and strut tower brace.
- DF210 installation ?....DONE!!!! 01-25-08
- lowest drop springs for xb2??
- New Strut Bar?
- Total noob asking about springs.
- Front Rotors are here
- ksports are here
- xB BIG BRAKE KIT
- tanabe underbrace
- NF210 installation instructions? 4pt. crossbrace fabricator?
- Spring Drop
- Hotchkis delivers and I install!
- Went to 3 Tire shops.. Cant to alignment on my XB
- 08 xB on Ksport coilovers!!
- another tanabe dropped......
- df210 or ksport?
- DF210 too low for me?
- 2008 xB Alignment Specs from the Dealership Inside!
- Any experience with Eibach Pro-Kit and TRD springs?
- my trd stress bar and trd swaybar up for sale
- front sway bar. someone wanna buy the rear from me?
- Is the TRD Strut Brace worthwhile for a daily driver?
- Looking for pictures of lowered cars
- OFFICIAL: Tanabe Sustec Under Brace 2008 Scion XB
- suggestion on lowering springs
- df210 drop UPDATED CRAPPY PIC
- 08 xB Spring Install - Lots-O-Pics
- TDR springs in the back, stock in the front
- Do you think this will work
- Driver side rear wheel issue!
- One Day only!!! ALL TECH PDF's!!
- rear neg camber
- Lowering the rear of the 2nd Gen with 1st Gen springs
- stiffest springs?
- Eibach E-Z install
- Making a box proper
- pic of my BSP with Eibach Pro Kit
- 19's + 5 axis lip kit= what springs?
- Hotchkis vs Tanabe DF210.
- TRD Springs
- Alignment
- Clunking noise after I installed TRD rear sway bar? HELP.
- Ride comfort
- thank you Hotchiks!!!
- What springs
- Buying the Hotchkis Sway Kit, Where?
- Flux Capacitor?
- Best place to buy Tanabe nf210's
- TRD Brake Kit
- heres a new suspension upgrade!!!
- wantin to bag my Xb2
- Tanabe Upper Strut bar
- Front suspenion noise
- thinking about lowering springs
- My 08 on Air Ride
- Ordered Eibach springs today
- Eibach Scion xB Sportline
- What coilovers available for 2nd gen xB
- whats up...noob here
- Gen2 weight capacity
- rough ride?
- Tanabe df210's + 5Axis kit= possible?
- type of springs for a wheel of 20"
- *Official Hotchkis springs drop thread*
- underbody creaking....
- Hotchkis springs
- NF210's with 17's
- what springs?
- help on supension upgrade
- brake kit
- Brake and rotor replacement
- Rattle at rear after TRD Spring install?
- Hawk HPS disc brake pads for 08 xB's
- TEIN....
- hawk brake pads?
- Who has the best price on DF's?
- Need some advice for suspension
- Five Axis Suspension
- Cut bump stops for TRD springs install?
- OFFICIAL:Tanabe Under Brace 2008 Scion XB Arriving Early May
- Is a Strut Tower Brace and Front Sway Bar the same?
- Brake Nosie...
- Another Air Ride and Axis Shine 19s
- lowering springs and stock shocks?
- BOSE suspension
- Easy street air ride system now taking preorders!!!
- ksport owners?
- swift springs
- Tanabe strut towerbar at ebay
- Tenzo Lowering Springs
- ksport coilovers onwers. Can someone help me
- oem xb2 shocks for sale.
- eibach sway bar set
- Tanabe or Eibach?
- Strut Tower Bar
- Question regarding lowing... can anyone help?
- SW on Ksport coils
- road magnet with 20's on 09
- CUSCO Japan coilovers sneak peak!!!
- Tanabe NF210s
- Ebay Find?: 08+ SCION XB BB JDM LOWERING SPRING SPRINGS
- Smartest thing to prob do?
- Somebody stop me!
- Rear shocks gone bad????
- Help on TRD spings and camber for Rear
- Spring Compressors
- Pic request... rim and drop
- Tanabe nf210 with trd shocks
- Air Runner soon!!!!!! updated with pics 6/27
- Finally Negative Camber
- Major weight issue
- Does eibach = TRD spring
- Df owners
- 06 rav4 brake rotors?
- installed hotchkis springs.caster,camber questions.
- strut tower TRD,Tanabe or Hotchkis??
