Is at bad to backfire?
Old Jun 12, 2007 | 06:40 PM
JohnathonSull's Avatar
Default Is at bad to backfire?
So after removing the resonator, the car backfires a little when I let the engine rev down from higher rpms. Is this bad on anything? What will I damage by letting it do this, and how long do you think I can go before the damage occurs? I like the sound I get when I let the engine rev down (from about 3K-3500K) but I don't want to jack anything up. Someone told me I could burn a valve or mess up a piston. I don't know, so I'm turning to my Scion family for some thoughts on it.
Old Jun 12, 2007 | 06:58 PM
MTcX's Avatar
Scionetics
moved to better location for more possible feedback.
From what I've heard it is bad on the pistons and the rods for a backfire which is trying to force the piston in an opposite direction or something.......im not a mechanic though so don't quote me.
Old Jun 13, 2007 | 05:02 AM
DriverXa's Avatar
From the sound of what ur describing that's more of a popping affect from the exhaust having a low backpressure. Believe me u'll know a real backfire when u hear it and that's not it.
Old Jun 13, 2007 | 02:45 PM
yea, it does sound more like a poping, and I know it's due to lack of back pressure. Does the popping or lack of back pressure hurt anything?
Old Jun 13, 2007 | 11:04 PM
jct's Avatar
jct
no it doesn't hurt anything heck i can even hear my car popping when i get off the gas and all i got is a dc 4-1 header and the trd muffler
Old Jun 16, 2007 | 08:16 PM
vintage42's Avatar
[quote="MTcX"... From what I've heard it is bad on the pistons and the rods for a backfire which is trying to force the piston in an opposite direction or something.......im not a mechanic though so don't quote me.[/quote]I think you are referring the situation where the mixture in the combustion chamber ignites so far before the top of the piston stroke that the piston is forced down before it can reach the top. This is better called a misfire, or pre-ignition, is caused by the timing being advanced too far. You can experience it when kick-starting an old motorcycle, in which case the lever will kick back hard. Or you can experience it in any engine when running, as knocking or pinging.
A backfire, on the other hand, is caused by ignition of the mixture outside the combustion chamber. There can be backfires in carburetors when starting, and more likely backfires in the exhaust system from unburned gases.
But you are referring to a continuous soft popping sound in the exhaust on deceleration, not a single loud backfire. The popping sound is common in exhaust systems with low backpressure. If you remove more of the exhaust restriction, the sound will become a loud crackle.
Old Jun 17, 2007 | 03:03 AM
Ok, currently I'm running without a resonator, but I still have the stock muffler, if I swap the stock muffler out with something larger, will the crackle be louder\more frequent, and will I have an issue with backpressure? is it bad to not have enough back pressure?
Old Jun 18, 2007 | 03:46 PM
randode's Avatar
Wagonistas
its fine, my green one does the same thing.
Old Jun 19, 2007 | 09:25 PM
uberspeed's Avatar
Don't you need backpressure for torque?
Old Jul 26, 2007 | 04:50 AM
SpeedChrome's Avatar
The resonator does muffle up sounds from the engine so removing it will make the car sound alot louder. Backfire will sound like gunshots.
Old Aug 3, 2007 | 07:18 PM
NurSpec's Avatar
You will not hurt your car. n/a cars require little back pressure to function at an optimal level. Most of the time a header and plain straight pipe back to the rear of your car will create suffiecent backpressure. You will get used to the sound
Old Mar 30, 2011 | 05:07 AM
ryan358's Avatar
Default the right answer
go to your nearest exhaust shop and ask them to set you up with a muffler that will eliminate the backfire, and help your pipes breath better.
Old Mar 30, 2011 | 05:30 AM
jnaval's Avatar
I guess it's been established that it is not backfiring.
Old Mar 30, 2011 | 08:07 AM
CIONIDE's Avatar
Way to bring back a dead thread from 2-1/2 years ago.
steeze69
May 24, 2021 02:57 AM
BlingSlade
Oct 19, 2016 12:39 AM
a23r
Feb 1, 2016 04:05 AM
mudguy
Oct 22, 2015 04:31 PM
alexbarspin
Sep 3, 2015 02:04 AM
