Front springs install instructions
Old Jul 23, 2007 | 12:33 AM
houstonhelix's Avatar
Default Front springs install instructions
Could someone provide simple worded instructions on how to install front springs?
I think I already figured out the rear springs by inspection:
1. Unbolt lower rear strut bolts
2. Lift vehicle
3. Remove springs.
Old Jul 23, 2007 | 04:42 AM
roXor_boXor's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=179137
Old Jul 23, 2007 | 12:19 PM
rsw1124's Avatar
instead of buying new front washers, use old ones with loctite. THats what I did and works fine, Instructions ay to get new but save a few bucks and re use original ones instead. Good Luck You will like the results.
Old Jul 24, 2007 | 06:14 PM
tCTaco's Avatar
Default Re: Front springs install instructions
2. Lift vehicle
3. Remove springs.
DO NOT REMOVE the lower..um shock bolt. (there are not struts in the rear)
Jack up the car, set it on jack stands. Then use the jack to compress the spring a lil. then remove the lower bolt on the shock. Then lower the jack to release the tension on the spring...reverse to install new springs.....For the fronts...I would refer to the Hotchkis website if you are unfamiliar with spring installs and check out the tC for a reference
http://www.hotchkis.net/installation_guides/19425.pdf
scionlife
10
Mar 1, 2016 09:14 PM
kleecker
Jan 9, 2015 02:26 PM
fluxingnation
Dec 26, 2014 04:28 PM
bBOXD
28
Dec 7, 2003 07:08 PM
randode
18
Nov 19, 2003 03:37 PM
