Where's the Clutch Fluid Reservoir?
Old Mar 3, 2008 | 04:04 AM
08xB714's Avatar
Default Where's the Clutch Fluid Reservoir?
I'm a Honda guy and it is very weird that i don't see the Cutch Fluid Reservoir.
How do you guys change the clutch fluid? or bleed?
Also, I notice in the maintenance manual that there is no information as to
flushing out the brake fluid nor clutch fluid. (which it should be.. every 15k-30k)
__________________
Old Mar 3, 2008 | 02:27 PM
MikeInABox's Avatar
I'm not 100% sure, but it might use the brake fluid reservoir for the clutch also. Not sure how many companies do that, but my old car was that way.
Old Mar 3, 2008 | 04:44 PM
08xB714's Avatar
clutch & brake using a same reservior... very weird... so is that mean, i need to bleed clutch & brake at same time?
Old Mar 3, 2008 | 05:36 PM
MikeInABox's Avatar
Yeah they both use brake fluid, so one reservoir, two different cylinders (one for clutch, one for brakes). I did a quick search and the tC only has one. Even found a good story where a Toyota tech told a tC owner they had two separate reservoir's, and then couldn't find the clutch one under the hood when he tried to show them, because it wasn't there. So I'm assuming ours are the same. But if I'm wrong, don't worry, someone will let us know.
As for bleeding them, it's probably a good idea to do them both at the same time. Otherwise you might end up chasing a problem back and forth trying to eliminate air bubbles.
__________________
Old Jul 12, 2021 | 01:25 PM
joeq's Avatar
And once again, this is the only place to find "any" information, concerning the Scion.
I'm in the same boat, looking to bleed the hyd. clutch on my daughters 2014 Scion tC.
Thanks for keeping this thread visible.
___
JOHNNYZX10R
Sep 5, 2017 12:12 PM
Luisfc1972
10
Feb 20, 2017 01:10 PM
gp1817
Sep 9, 2010 02:54 PM
THansenite
Jul 6, 2009 07:20 PM
MrBurrito
Apr 30, 2008 05:23 PM
