TRD Thermostat Question
Old Mar 20, 2008 | 03:35 PM
Dondirtyj's Avatar
Default TRD Thermostat Question
if i install a TRD thermostat in a N/A engine will there be any benefits other than cooler engine. i know keep a cooler engine goes a long way when your boosted but will it have any effect on a N/A engine. for some reason just like the idea of a cooler engine thats why im asking.
Old Mar 20, 2008 | 06:09 PM
nodsetse's Avatar
NM, my original response pertained to the radiator cap, not the thermostat.
Old Mar 20, 2008 | 06:53 PM
bkuhl's Avatar
IIRC, the TRD Thermo opens up earlier than the OEM Thermo which allows for cooler engine coolant to flow.
Old Mar 27, 2008 | 03:29 PM
Dondirtyj's Avatar
i uderstand that, but any benefits of that???
Old Mar 27, 2008 | 05:35 PM
bkuhl's Avatar
my comment above was made just after nodsetse edited his post =P
Old Mar 27, 2008 | 06:04 PM
Zebman's Avatar
Lowered fuel mileage, takes longer to warm up, poor heater functioning in cold weather, no performance benefits at all... go for it!
Old Mar 27, 2008 | 07:13 PM
bkuhl's Avatar
if he's constantly running the motor hard, it will help to keep the engine a little cooler. Will it be much of a performance benefit? Probably not
Old Mar 30, 2008 | 02:17 AM
Dondirtyj's Avatar
how does it lower gas mileage???
Old Mar 30, 2008 | 04:20 AM
Zebman's Avatar
Your engine will take an exaggeratedly long time to warm up. Not a single internal combustion engine on earth is at peak efficiency until it is at operating temperature, the temperature that many hours of engineering determined would be optimal. Until it does, your ECU is programmed to run rich in order to warm up the engine. It doesn't know that it's fighting against a prematurely opened thermostat.
As you said, there are no benefits until you go F/I, where heat is generated much quicker.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
BManAmericae
Jan 18, 2015 12:17 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
