Braking
Old Jan 13, 2004 | 12:41 AM
izzles's Avatar
Default Braking
Has anyone heard a noise when braking..Example, I am driving then I break...I hear this sound coming from the pedal area as if something is tight and not wanting to be compressed..I mean the pedal goes smothly but I hear this noise and its erking me....anyone if not then Toyota here I come
Old Jan 13, 2004 | 12:45 AM
1NZFE's Avatar
Does it make a squeek sound? DOes it happen every time you stop or when your car has been sitting in the "cold" for a while?
Old Jan 13, 2004 | 01:22 AM
HotBox's Avatar
yes we need a little more detail cause my makes
some nosies too only when its been in the cold for
a while it makes like a whistle noise but just for a
little not long
Old Jan 13, 2004 | 02:29 AM
1NZFE's Avatar
If it only happens when the car has been sitting in the "cold" for awhile, it's the Toyota pads. Perfectly nothing wrong if the squeek, squeel noise. The Toyota Pads were designed for maximum braking force and better wear. Also to remove the use of asbestos from the pads.
But if the squeek happens every time you brake, that's an issue. Check your brake-fluid too. It shouldn't really have gone down that much though.
Old Jan 13, 2004 | 03:44 PM
izzles's Avatar
No this is after a drive and I begin to brake..I start to brake now I hear this like ery noise where the pedal is....I really cant put into words its not on the outside...I am not sure if it make come loose where the firewall is I am not sure...I know the squeaking noise is normal but this just started....
Old Jan 16, 2004 | 03:55 AM
aznr1c3bo1's Avatar
ive had a similar problem. when i was braking about 2 weeks ago i hit one of those sewer cover thingys and the brake petal started to rattle. the petal was pushing back and the car didnt want to stop. scary....since then nothing has happened. could it be because i have 18" rims?
Old Jan 17, 2004 | 05:49 AM
kdanie's Avatar
When you drove over the smooth metal manhole cover with your brakes applied your tire locked up and your ABS caused the pedal to "push back" and vibrate as it activated. That's normal.... no traciton means no braking even with ABS.
ken
Old Jan 22, 2004 | 04:04 AM
daverf230's Avatar
Ya the ABS. hehe. But how about when the tires are not locked up. Sounds like a vehicle speed sensor to me. It might be a faulty vss where if too much heat is applied it could not read or might have too much clearance. Could not really tell ya. You have to describe the driving conditions a little better, how you drive, and where your driving when it happens. Hope to hear from you soon. GL
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
