Finally dropped the tC...
Old Dec 19, 2004 | 07:15 AM
Tcguy's Avatar
Default Finally dropped the tC...
I did the install on Friday. H&R suspension, compliments of Dezod.com.
Perfect drop! Rides excellent, and the suspension is ISO certified (higher certification than US requirements). The car settled to a lil more than a 1.5" drop.
I'll post up pics either tomorrow night or Monday.
Mods are: H&R springs, TRD exhaust, oem lip kit, fogs, blue interior lights, obx pedals, JL 500/5 amp, JL 10W3, Viper alarm with paging remote (and screen), misc silver decals, hotchkis bar, aem oil cap and battery tie down.
I'm installing the Apexi RSM soon, along with some more hush hush mods. Until then, I can only talk about what I have now.
Old Dec 19, 2004 | 08:45 AM
putz's Avatar
sounds phat, get pics up asap.
Old Dec 19, 2004 | 07:02 PM
smash's Avatar
Yea I was interested in doing the H&R setup paired with TRD shocks. The drop from the TRD springs doesn't do much for me and I'd like to see pics with the H&R springs, which hopefully looks a bit more aggressive. It's hard to find a medium between wimpy drop (TRD) and extreme drop (something like GoldLine springs that offer a 2" + drop..)
Pics! :D
Old Dec 21, 2004 | 08:29 AM
05TC916's Avatar
I went with the H&R springs too. Ride is great and drop is perfect. Check it out.
http://www.cardomain.com/id/05tc916
Old Dec 21, 2004 | 02:54 PM
smash's Avatar
That looks so fresh and so clean, clean. What would you estimate the actual drop came out to on those?
Old Dec 24, 2004 | 08:03 AM
franktherank's Avatar
with the HRs did u need new shocks? yeah pics would be awesome
Old Dec 24, 2004 | 11:19 PM
Stefan_TC's Avatar
Tc,
that definetely looks cool, in the same time HRs are very decent spreing when it comes to quality, ride, hadnling etc...
Question, are the HRs progrewwsive all around (all four springs)?
Also, did you ever question HR on installing the sprng with stock dampers?
My ceoncern is if these spring have higher rates (progressive???) that there is more required from the dampers.. Generally, AFAIK, the rates on springs should be lower
that dampers otherwise the damper is "OVERSRESSED".
Do you have any info?
I am currently looking at boht HR and TEIN springs and have not decided yet...
Once again,
good job,
Stefan
Brooklyn
Old Dec 25, 2004 | 05:14 AM
Tcguy's Avatar
The H&Rs are progressive on all four springs. The spring rates are stiffer than stock, and it's slightly noticeable. I don't see having long term reliability as a major problem, because the TRD springs are only .4" less of a drop, while still having a more aggressive spring rate.
If I ever blow my shocks, then I'll get the TRD shocks, until then, it's all good.
Old Dec 25, 2004 | 10:23 AM
Stefan_TC's Avatar
That's true. dampers actually go downa slowly, first you notice "wobbliness" and then it will increase to the point you will feel like you do not have any dampers at all...
AFAIK the damper is supposed to be stiffer that the spring so it can "tame" it. Otherwise it will die in a disastrous way... Let's see how good is the stock damper... BTW, what is the class/brand of your HRs i.e. sport, race?
Old Dec 25, 2004 | 10:48 AM
siopao2000's Avatar
i believe the hr springs are linear if i'm not mistaken... also, only the sport springs are the only ones available, again, if i'm not mistaken. i also contacted h&r for spring rates, all i was given was that they are 25-30% stiffer than stock.
Old Jan 3, 2005 | 12:22 PM
smokinjoe's Avatar
30% sounds about right
smokinjoe's Avatar
I couldnt say if there were progressive or linear
Old Jan 3, 2005 | 03:40 PM
Joe_Dezod's Avatar
Progressive.
Old Jan 3, 2005 | 05:39 PM
Fixtion's Avatar
No one post pics anymore when the announce something, sad.
laforze
12
Feb 16, 2016 12:50 AM
Jayrdee
Oct 15, 2015 03:38 PM
TTCCC
Sep 15, 2015 02:12 PM
Threequalseven
Aug 26, 2015 04:24 PM
SoCal_CJ
Scion tC 1G ICE & Interior
Jul 14, 2015 09:14 PM
