Where to tap for A/F gauge?
Old Jan 27, 2004 | 08:47 PM
TheRedBox's Avatar
Default Where to tap for A/F gauge?
uhmm yeah.. i dont know where the wire is. Please advise.
Thanks!
Old Jan 27, 2004 | 09:54 PM
kdanie's Avatar
Are you trying to install an aftermarket Air/fuel meter? If so, it is an O2 sensor so you will need to istall another O2 sensor bung, before the cat.
ken
Old Feb 11, 2004 | 03:04 AM
SoCalbBox's Avatar
Don't waste your time on a narrow band sensor. If you are trying to tune, forget it. If you want pretty lights go for it.
AEM does offer a wide band sensor (bosch) and UEGO controller with a display. It reads green, yellow, red AND digital in the middle. The display has a sensor for autodimming as well. I believe you can show voltage as well if you don't want 11-17.
Old Feb 11, 2004 | 06:54 AM
sithscripter's Avatar
There are two O2 sensors, an upstream one and a downstream one, so I don't think you'll need to install another one.
Unfortunately the factory wiring diagram is a bit ambiguous.
Old Feb 13, 2004 | 12:48 AM
scionxb04's Avatar
install the a/f gauge pickup on the o2 before the cat...its is a 4wire heated o2 sensor the last time i got under ther eand looked....so u need to find the 4wires comming out and find the right one to tap to.....kragen or autozone or maybe one of the local toyota techs here could give us a wire diagram of the 02 sensor? then it would be easy
Old Feb 13, 2004 | 04:57 AM
Guest
Guest
Posts: n/a
daniel, I can install another O2 sensor bung for another O2 sensor. In fact I have a whole other OEM system for sale if you want it. :D
Old Feb 13, 2004 | 05:00 AM
DenZinz's Avatar
Are you force inducting your car?
Just curious on why you are looking to wire up a a/f meter.
Old Feb 13, 2004 | 05:06 AM
MiniHummer's Avatar
I have one in my car, an autometer a/f gauge. I tapped into the first o2 censor of the header. They are four wires but three of them are the same color I beleve grey you will just need to try them out and see which one works.
Old Feb 13, 2004 | 05:38 AM
I'd like one just for the "Knight Rider" effect. Of course I'd wire a power switch so I could kill it when I got sick of it (like in about two weeks).
Old Feb 13, 2004 | 05:44 AM
Guest
Guest
Posts: n/a
looks like the red box is up to something in the garage!! Whats up daniel!!?? Got something up your sleeve? Where are you gonna put the gauge? :D
Old Feb 13, 2004 | 04:43 PM
TheRedBox's Avatar
I'm not telling.
Old Feb 14, 2004 | 05:41 AM
Guest
Guest
Posts: n/a
super secret mods!! Can't wait to see.
Old Feb 29, 2004 | 04:16 AM
*** EDIT *** Whoops, I looked at the wiring info for the *DOWNSTREAM* O2 sensor by mistake. Please ignore whatever I posted earlier ...
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
ScionLife Editor
Sep 15, 2015 04:40 AM
paisatronix
Sep 5, 2015 04:13 AM
