FS - Polk Audio DB12 subs, amp and cap. Atlanta, GA
Old Aug 26, 2009 | 12:30 AM
Gardiner's Avatar
N.G.S.O.
Default FS - Polk Audio DB12 subs, amp and cap. Atlanta, GA
Selling my sub box, I painted the grills gold to match my interior but they can be painted any other color you wish. The grills come off real easy to make it simple to paint.
I live in the greater Atlanta, GA area, local pick up only, no shipping.
ported enclosure with two 12" db Series subwoofers
3/4" MDF construction with front-panel ABS trim
polypropylene woofers with Santoprene rubber surrounds
2-ohm mono impedance (1 set of heavy-duty binding posts)
Power Port venting technology
frequency response: 27-200 Hz
power handling: 750 watts RMS (1,500 watts peak power)
sensitivity: 103 dB
34-1/4"W x 16-1/4"H x 17-1/4"D1 x 13-1/4"D2
Profile AP1000 1000-Watt Amplifier
The Profile AP1000 amplifier is designed with an in built variable low pass and high pass filters and each with a slop of nearly 12dB octave. The high pass filter is constantly variable from 80 Hz to 1.2 KHz, whereas the low pass filter is constantly variable from 50 Hz to 250 Hz. The three way switch allows you to configure the amplifier for full range, low pass or high pass operations. The amplifier includes three protection circuits, the short circuit, DC offset and the thermal protection. On the left side of the amplifier is the red LED that would glow to indicate that the amplifier has gone into the protection mode.
Scosche .5 farad cap
Asking $250 for sub box with subs, amp and cap.
BlingSlade
Oct 19, 2016 12:39 AM
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
DannyBoy65
Sep 21, 2015 06:23 PM
