Scion xD Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
what sway to choose
Old Sep 15, 2009 | 03:45 AM
c2iix's Avatar
Default what sway to choose
i was going to get a sway bar but i do not know which to get. all i know is the trd sway bar and the sway for yaris. what should i get??
Old Sep 15, 2009 | 04:29 AM
SteveTC_RS_4-0's Avatar
i got trd. no complaints
Old Sep 15, 2009 | 06:19 AM
misformartin's Avatar
Default `
ultra racing.... 23 mm bar : ) cheaper and beefier.... : )
Old Sep 16, 2009 | 05:23 AM
ChelsDS's Avatar
As far as I know you can get a sway bar for the Yaris and slap it on our car, same chassis. I have TRD and it works fine, I noticed it right away when I put it on last year. What I would love to find would be a front under brace since that would make handling even better.
Old Sep 17, 2009 | 01:20 AM
c2iix's Avatar
the ultra racign bar i took a look at was like 200$ trd is like 150+shipping from trdsparks .. GAHH so much money ..
Old Sep 17, 2009 | 01:49 AM
sv650m's Avatar
The 23mm Ultra Racing bar is actually only $165. Go to microimageonline.com. Or you can go with the UR 19mm which is the same diameter as the TRD for $135.
Old Sep 29, 2009 | 02:03 AM
slipstream1016's Avatar
I apologize if this sounds stupid. I don't know a lot about cars. So anyway, what does the difference in diameter do? Will the weight difference be an issue in the long run?
19mm vs. 23mm
I ordered my Scion XD earlier after lusting over it for a couple of years. Dealer said it will be a few weeks. Thanks in advance for the info.
Old Oct 2, 2009 | 04:19 PM
ROCKLANDTOYOTA's Avatar
GT SPEC bars for yaris will also work with your xd. contact kevin chan at gt spec for all your needs....
Old Oct 4, 2009 | 12:08 AM
brodie7838's Avatar
Is the extra 4mm going to make that much of a difference? I can see where it would be important if you were serious about racing or something, but I'm thinking more along the lines of every day driving...
Also, how much of the Yaris Suspension stuff in the microimageonline.com store is interchangeable with the xD? I know they share the same suspension, but I wanted to check before I buy something that might not work.
Old Oct 11, 2009 | 04:19 AM
slim99's Avatar
Default Doesn't matter...
Sorry, but it doesn't matter much.
The xD axle isn't enhanced much by a sway bar. Even a small bar will give you the maximum benefit. The larger bars will only add more weight.
More sophisticated suspensions sometimes do benefit from bigger bars, but for the xD, this is not an issue...
Old Oct 11, 2009 | 04:20 AM
slim99's Avatar
What makes you believe that a front brace will improve handling?
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
SloTC1
Aug 16, 2018 02:45 PM
maximthegreat
Jan 19, 2016 02:31 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Subaru86
Jul 31, 2015 04:33 AM
