Need to know about offset
Old Jan 29, 2004 | 09:03 PM
monkeyboy's Avatar
Default Need to know about offset
I have never purchased aftermarket wheels befor I am getting an xA and need to know if a 16x7 with a 40 offset would work I checked the info above and it said a 33 offset could someone explain this to me please...
Old Jan 29, 2004 | 09:17 PM
scionaraxb's Avatar
ok.........
offset has to do with the distance that the difference between wheels lug surface(monting to hub/brake rotor) and the centerline of the wheel.....
zero offset means its exactly on the wheels centerline......
33 offset means is 33mm "offset" from the centerline.....
40 offset vs 33means that the mounting is more towards the outside of the wheel then 33 so the wheel edge on the inside will be 7mm closer to the suspension then the 33mm offset.
More offset= tucked closer to suspsnsion
Less offset= wheel pushed out more towards fender lip.
Make sense?
Old Jan 29, 2004 | 09:38 PM
monkeyboy's Avatar
Yeah.... Thanks!!
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
