Fitment Question
I used the wheel calculators, so I got an idea but I was hoping someone could clarify.
16x10, +12, 225/50 tires. Current drop is about a finger gap in front, half a finger in back.
Would you guys recommend a different tire size? Also will the wheels poke out too much without large amounts of camber, and will I have any rubbing issues with suspension?
With a 10 inch rim at +35 I'm nearly rubbing on the arms in the rear it clears by a millimeter or two. I'd say atleast +30 all around maybe. For clearance purposes on the inside. To not need overfenders the lowest you can go is probably +20? Not too sure on that. Riboflavin is running 10s with a +23 offset with some decent poke.
bootlgr
Jan 26, 2016 01:22 AM
