19x8.5 +35 on 2" drop
Old Jan 28, 2010 | 07:16 PM
The01Cav's Avatar
Default 19x8.5 +35 on 2" drop
Alright I am looking at a set of wheels for the tC they're 19x8.5 +35. My drop is right around 2" front and rear, will I see a fair amount of rubbing or should I be alright? I am also gonna run 5mm spacers in the rear as well so basically be +30 in the rear. Tires will more than likely be 225-35-19 Falken FK451's.
Old Jan 28, 2010 | 07:32 PM
tcleazy-girl's Avatar
Depends on the aspect ratio of your tires. You will rub a little if your ratio were at 35 and rub moderate at 40.
Old Jan 28, 2010 | 07:56 PM
tito_tc's Avatar
225-35-19 -35 or 30 Falking FK451's. it good to go
Old Jan 28, 2010 | 10:10 PM
Actually, you will need to roll your rear fender with those spacer in the back with 30 offset. The front fenders may need modifications as well.
Old Jan 28, 2010 | 11:01 PM
The01Cav's Avatar
I think my plans have changed some, I have to replace on of my current wheels as it was messed up. So i'm gonna get a replacement and get them refinished.
Thanks though for the help.
Old Jan 29, 2010 | 07:20 PM
mindoculae's Avatar
Thanks for the thread. Your concern is similar to mine. I'm considering 18 x 9.5 (XXR 502) with a 35 offset. It appears I will probably not have any rub issues with a 225 or even a 235 tire, preferably the former. Thanks again.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
ScionLife Editor
Sep 24, 2015 10:50 PM
Andreas24
Sep 15, 2015 02:10 PM
prescottn
Sep 13, 2015 09:04 PM
JZA70
Sep 12, 2015 09:37 PM
