215 x 40 x 18 be okay?
Old Feb 2, 2004 | 04:50 AM
dinkjs's Avatar
Default 215 x 40 x 18 be okay?
I was reading in another thread where someone directed the guy to this spot on the website that gave recommendations on tire sizes for different size rims
For a 18 x 7.5 with a 42 offset
Would I run into slight rubbing problems with running a 40 series tired instead of a 35 series...heck I would love a 45 if its feasible
Old Feb 2, 2004 | 04:57 AM
HotBox's Avatar
not sure about the offset on my rims but i have the 215/40 and theres a slight little rub on the front left tire only when making a full turn tho eother then that no prob
Old Feb 2, 2004 | 05:05 AM
dinkjs's Avatar
What about road noise on the 40 series? Still a quiet tire?
Old Feb 2, 2004 | 05:36 AM
HotBox's Avatar
yeah it quiet except for certain road that are really coarse but most of the time i cant here it since i have the radio on i wanted to go with 225/40s but it would have rubbed on the suspension components and it was also like i believe he said like 2 inches bigger so my odom would have been off so we opted for the 215/40
Old Feb 2, 2004 | 06:29 AM
CubiXBb's Avatar
Hotbox, what type of suspension set up do you have? I have some Eibach springs, and was thinking about using 215/40/18 all around. Have you noticed anything else with that tire setup you have? Also, do you have pics? Thanks :)
Old Feb 2, 2004 | 10:31 AM
HotBox's Avatar
i have a stock suspension i havent started to modify that yet which i was supposed to do first but didnt the pics are here https://www.scionlife.com/forums/vie...asc&highlight=
notice anything else like what ?
Old Feb 4, 2004 | 04:43 PM
JDMxB's Avatar
I'd like to know if 215/40/18's would work on a 2 inch drop...most likely not, but I want to know for sure.
I need new tires, and am shopping so this is greatly appreciated...
Will 215/40/18's work on a xB dropped 2 inches???
THANKS!!!
Old Feb 4, 2004 | 04:50 PM
HotBox's Avatar
well asoon as i get some more suspension parts either springs or coilovers i will let yall know but im not sure when thatll be im sure it would but not certain
Old Feb 4, 2004 | 04:51 PM
CubiXBb's Avatar
Hotbox I tried checking your last post for the pics, but they're coming up as red x's
Old Feb 4, 2004 | 04:57 PM
bBted's Avatar
215-40-18 should be fine...as i remember its the closest diameter to stock...
most people running 215-35-18...cuz its more popular size and cheaper tires..
scionara is running 225/40/18 with 2in drop...no problem
Old Feb 4, 2004 | 05:03 PM
scionara's Avatar
225.40.18 in the back is fine but I suggest to go 215.40.18s in the front or 215.35.18s.
Old Feb 4, 2004 | 05:09 PM
randode's Avatar
Wagonistas
225/40/18 or 215/40/18 should both be fine. You may have a problem though since your wheels are such a high offset. A spacer might fix it though.
Old Feb 4, 2004 | 05:30 PM
HotBox's Avatar
try refreshing they work on my laptop but onmy main comp some also come out as red xs also try refreshing or using another comp thats all i can tell yah if still no then ill post them again or something
Old Apr 20, 2005 | 10:58 PM
Woodys05's Avatar
So what is the factory ofset for 18" TRD Racing Hart rims? And will the 215-40-18s rub with Gold line springs?
Old Apr 20, 2005 | 11:46 PM
D2AUTOSPORT's Avatar
215/40/18 Won't be a problem at all, what wheels are you getting?
Old Apr 20, 2005 | 11:50 PM
Woodys05's Avatar
If you talking to me I have the 18" TRD Racing Hart rims. If you weren't sorry but what do you think? Would they rub if I put 215-40-18s on? Thanks man, Woody.
Old Apr 21, 2005 | 12:16 AM
No I was speaking to the post starter.
Old Apr 21, 2005 | 04:47 PM
scion619's Avatar
Hey there i have done a lot of research on this topic. im running 215/40 series tire with 18x7.5 with 42 offset and i have had no rubbing issues at all. They almost ride like stock. AS for goldlines i have them but haven't installed them yet.... but I did ask several peeps with this set up of tires and springs and they said they have no rubbing issues at all.
lates
scion619
Old Apr 21, 2005 | 07:36 PM
Woodys05's Avatar
Thanks brother!
silverevo05
Jan 9, 2007 08:46 PM
neckbonenick
Oct 26, 2006 03:00 AM
active9x
27
May 20, 2006 02:49 PM
Nick06tC
Scion tC 1G Wheel & Tire
18
May 14, 2006 05:49 PM
beezyyy
Feb 17, 2006 06:31 PM
