torqing new studs down while in gear, but spinning!
Old Feb 26, 2010 | 04:30 AM
07-5spd-SprWht-tC's Avatar
Default torqing new studs down while in gear, but spinning!
ok so im installing extended wheel studs on the fronts and when i torque down the nut to get the new stud to seat properly the hub/rotating assembly turns when i put too much torque on the nut, now i have the car in 1st gear while doing this to prevent the hub from spinning while torqing the nut. my question is it supposed to spin after so much torque is applied? and if so does it cause any damage to the tranny or anything? kind of concerned about that, and no i couldnt get enuf torque to seat the studs fully i also tried putting it in reverse, and same thing, will let me tighten to a certain extent then starts to spin.
Old Feb 26, 2010 | 05:13 AM
Thorium06's Avatar
gotta have a buddy stand on the brakes. the wheel spinning is fine its supposed to do that
Old Feb 26, 2010 | 05:15 AM
dqlostsoulz's Avatar
What I did was grab my 50 pound dumbbell and put it on the brake.
Old Feb 26, 2010 | 05:36 AM
ScionSnowman's Avatar
lol now thats using your head! Or use a breaker bar and put it between the seat and your pedal
Old Feb 26, 2010 | 01:37 PM
haha cool, well i had to take the brake rotors and calipers off to install the new wheel studs so standing on the break wont do much lol. i guess ill tighten the studs as much as i can b4 the hub starts to spin then slap on the breaks use a 50 lb dumbbell to press em and torque the lugs some more! thanks fellas
Old Mar 2, 2010 | 06:07 PM
bionictony's Avatar
you should get a 1/2 torque wrench with socket so you can properly torque down your lug nuts. if the wheels are off the ground you need a way to stop it like friend on the brakes. if it's in the front, have the other side touching the ground so the diff won't spin. if it's in the rear, pull the ebrake.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rvascion
Nov 12, 2020 03:23 AM
rain7905643
Jun 13, 2018 05:29 AM
a23r
Feb 1, 2016 04:05 AM
Mike_xb2
Scion xB 2nd-Gen Wheel & Tire
Sep 10, 2015 01:18 AM
