Single coil or individual coil
Old Feb 10, 2004 | 02:31 PM
dinkjs's Avatar
Default Single coil or individual coil
The 1nz engine does it use a individual coil setup on each cylinder or is a single coil for all 4 cylinders????
Old Feb 10, 2004 | 05:03 PM
dinkjs's Avatar
Anyone?
Bump
Old Feb 10, 2004 | 05:24 PM
Guest
Guest
Posts: n/a
which motor is the 1nz ? Thats not ours is it? :?
Old Feb 10, 2004 | 05:29 PM
bBted's Avatar
1NZ-FE is our engine
Old Feb 10, 2004 | 05:32 PM
Guest
Guest
Posts: n/a
that sounds better, got to tell us the whole number, had me thinking their for a min. our cars use a coil pack for every cylinder and not a cap and rotor. :D there u go!
Old Feb 10, 2004 | 05:33 PM
bBted's Avatar
wassup gabe!!!! got burritos?
Old Feb 10, 2004 | 05:39 PM
Guest
Guest
Posts: n/a
as soon as I add the iridium plugs in my ride I will have major burritos!!!!
Old Feb 10, 2004 | 05:52 PM
Scionic's Avatar
Originally Posted by eric m.
• a two-stage muffler (as debuted in the Lexus range) to improve high rpm engine performance on the 1.5 litre sedan engine Additional fuel emission saving technology includes computer engine management, individual Toyota Direct Ignition for each of the four cylinders and electronic spark advance with a knock control system.
I'm confident to say that it's a coil per cylinder
Old Feb 10, 2004 | 07:58 PM
dinkjs's Avatar
Wonderful we even have a knock control sensor....that will help alot of people out when they are tearing into the motor and they over do things....or let it get to hot.....or not change the oil
Old Feb 10, 2004 | 09:16 PM
215scion's Avatar
the 1nz-fe ignition system is a DIS system were dis stands foe Distributerless Ignition System wich therfore would mean you need a computer controlled seperate coil for each of the four cylinders.
Old Feb 12, 2004 | 06:18 AM
scionxb04's Avatar
http://www.msdignition.com/1disign.htm im thinking about this one or....this from aem the C2DI http://www.aempower.com/productSubCatImages/35_1_f.jpg
Old Feb 12, 2004 | 02:40 PM
jackmott's Avatar
Theres not likely any benefit from an aftermarket ignition setup if the engine already has a coil on plug setup. We already have 'the good stuff'.
Vettes, WRXs and STIs all make freaking huge power with the same setup.
Old Feb 13, 2004 | 01:35 AM
ScionVan's Avatar
Agreed, until you have honestly exceeded your stock ignition system, there really is no need to upgrade it yet. As it is, the factory DIS is pretty well-designed imo.
yupinmytC
22
Jul 27, 2024 07:08 PM
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
Luna7ic
Sep 28, 2015 03:30 PM
Topfueltom69
Sep 6, 2015 05:25 PM
BlingSlade
Sep 5, 2015 08:52 AM
