Need help from the experts...
Old May 11, 2005 | 04:51 PM
rcX's Avatar
rcX
Default Need help from the experts...
I just bought my new Alpine CDA-9855 headunit yesterday. Now I'm looking for an amp and subs (2x 10").
I don't listen to much rap/hip-hop. Mostly rock/hard rock.
Therefore, I'm looking to get 2 10" subs (sealed, not ported) because I want hard hits and clear sound.
I'M NOT WANTING A "LOUD" SYSTEM THAT THE GUY NEXT TO ME CAN HEAR.
I'm not familiar with the different brands, etc. But I do know most of the technical stuff.
What do the experts suggest?
Old May 11, 2005 | 05:10 PM
SCI_TC_GUY's Avatar
budget??? for really nice tight bass, get a single JL8w7.....wow
Old May 11, 2005 | 05:27 PM
mandos's Avatar
2 10's and an amp
2 11Kv.2 Dual 4's and a Nine.2
Run ya $378.25 w/ the 15% package discount.
Old May 11, 2005 | 06:00 PM
rcX's Avatar
rcX
Not really on a budget... considering I just dropped $500 on the HU.
Duals seem cheap to me... considering the price point and the fact that they have to illuminate them to sell them.
Old May 11, 2005 | 07:03 PM
AldoRx's Avatar
He meant the subs are dual voice coils...not the dual brand. I believe the subs he was referring to were made by Elemental Designs.
Old May 11, 2005 | 07:29 PM
rcX's Avatar
rcX
Call me a n00b... but what (physically) is the difference between SVC and DVC? I'm assuming DVC sounds better. Also, does it affect impedence?
I just noticed the links in mandos' post. Sorry about that. GREAT DYI BTW on gutting the tC! ( I still can't get my grocery hooks to come off though)
Old May 11, 2005 | 07:53 PM
rcX's Avatar
rcX
With a 68% efficiency, the NINe.2 would probably have to constantly have quite a bit of power on it to sound good, correct?
Also, what is the range on the 11Kv.2? 30-120hz or so?
Old May 11, 2005 | 09:58 PM
rcX's Avatar
rcX
I'm currently looking at getting the following:
2x Infinity Perfect 10 DVQ Subwoofers
1x Alpine MRD-M605 Amplifier
Old May 11, 2005 | 10:07 PM
dex's Avatar
dex
if your looking for a clean setup thats not overly loud then dont bother buying 2 subs. all you need is one and it will be plenty good enough. i had one 10" JL W3 and it was plenty loud enough as long as your not looking to be floored with SPL.
Old May 11, 2005 | 10:54 PM
mandos's Avatar
No more really than any other A/B amp. Looking at a D amp you could get a Nine.1...same ratings but more efficient as it's class D...probably won't notice a difference in the power use.
Regarding output on the 11Kv.2's, we haven't had a chance to run the sealed tests yet. Ran through the subs in a ported box today, hopefully get the sealed done tomorrow.
And thanks for the props on the walk through....the grocery hooks are a pain....you'll need to push the pin in after having them turned 90 degrees while pulling them out...it's evil ;)
Old May 12, 2005 | 11:24 AM
SCI_TC_GUY's Avatar
The only difference in SVC and DVC is just that, the number of voice coils used......the only advantage/disadvantage is for wiring purposes.....Say you have an amp that runs max power at 1 ohm.....no-one makes a 1 ohm SVC sub but there are plenty of DVC 2 ohm subs....so you get one of these DVC 2 ohm subs and wire it in parallel making a single ohm load.......the sound Q isn't gonna be affected by the number of voice coils.....unless it gets messed up somehow in the wiring...
Old May 13, 2005 | 05:46 PM
bmac's Avatar
I have a website that describes how to remove grocery hooks in the tC. Check it out at http://www.brendanmc.com/scion/scion.htm
Here's the most important pic...
GL,
B-
Old May 13, 2005 | 06:28 PM
JasonH's Avatar
I agree one good, sealed 10" sub can do everything you need. You should be able to feed it a ton of power, it will go low enough and be plenty loud.
zunit66
Scion tC 1G Aero & Exterior
15
Dec 18, 2007 03:47 PM
