Does every lowered xB squat in the back??
Old Feb 26, 2004 | 09:57 PM
matchbox's Avatar
Default Does every lowered xB squat in the back??
I have Goldline 2" springs and my xB look like it a tad bit lower in the rear. I looked through the registry and noticed this on most of the lowered xBz.
Matchbox
Dave
Old Feb 26, 2004 | 10:00 PM
hongs66's Avatar
The Tanabe springs don't. 2.2 in front, 2 in rear.
Old Feb 26, 2004 | 10:03 PM
Besk_one's Avatar
yup, most of the springs: spy, goldline, eibach, sprint all sit a tad lower in the rear
the Tanabe DF210's sit lower by a touch in the front (why i bought them)
you could allways cut a 1/4 coil off of your front springs to even it out a bit...
Old Feb 26, 2004 | 10:37 PM
randode's Avatar
Wagonistas
they appear that way because the rear wheel well is lower on the body. The side skirt is level. I am planning on cutting my front springs (spy) to see if it can be corrected.
Old Feb 27, 2004 | 01:17 AM
peppy's Avatar
i've got the tanabe df210 springs on my xb and it still sits lower in the rear i just got my trd struts tonight so i'm gonna cut a coil off the front when i put them on
Old Feb 27, 2004 | 01:46 AM
scionxb04's Avatar
my tein s techs sit lower in the front....
Old Feb 27, 2004 | 03:05 AM
hahajoey's Avatar
most of the jdm companies lower the front a lot more than the rear
so the car is even all around.
new companies in america haven't fixed that yet..
IE: spy, gold line and whatever else.
im running df210's.. i had nf210... they both are even steven...
and tein's are good, rsr's are good(bumpy) but i've never seen this height
problems with jdm springs...
Old Feb 27, 2004 | 05:59 AM
Guest
Guest
Posts: n/a
the eibach is 1.6 in the front and 1.8 in the rear. Really wierd, but mine is even and I even found that if you cut half a coil on the eibachs you can level out or get the rake you want. CUTT only if you are unhappy and the rear is sagging.
Old Feb 27, 2004 | 07:33 PM
cowboy's Avatar
the reason for the sag is that most compaines make one spring for both the xB and xA (eibach/hotchkis/etc...). so on the xA it has the correct height, but on the xB it sags in back.
that's why i got the tein s.tech springs - their specifically made for the xB and have the proper front sag.
Old Feb 27, 2004 | 09:43 PM
superjeer's Avatar
I got the goldlines because the pick on their site still showed a slight rake (2 front, 2 rear = normal but lower ).
Now I'm all worried, I can't handle the sagged look. I wouldn't want to cut the front down though, cause 2 is plenty. Is there a way you can space up the rear? I was thinking of something like a piece of rubber to help with any squeaking too.. but is there a risk they won't seat or will slip out leaving xB pieces all over the road? I think 1/4 to 1/2 would be plenty of height.
Thanks!
Old Feb 28, 2004 | 02:01 PM
ScottsXBScion's Avatar
yeah my Tien's are .9in in the back and 1.1in in the front sits nice
Old Feb 29, 2004 | 04:27 AM
Chrno's Avatar
no mine doesnt... :?:
<img src=http://img8.photobucket.com/albums/v28/swtbabiboi4u/xangur/downlowfront_copy.gif>
<img src=http://img8.photobucket.com/albums/v28/swtbabiboi4u/xangur/downlowrear_copy.gif>
Old Mar 3, 2004 | 02:33 AM
Inazuma's Avatar
i am still debating on cutting my Eibachs. I am getting kinda tired of the sagged look. I want a more aggresive look. It was supposed to settle in 2 weeks which Eibach claims. Its weird some days looks good and other days it kinda sags. I installed them on December 14.
Hey Stylis..should I cut the top or the bottom of the coil? I know I asked you this before but I forgot. 1/2 coil should be sufficient I think
Old Mar 3, 2004 | 03:56 PM
randode's Avatar
Wagonistas
you want to cut the bottom of the coil, but dont call me Stylis
Old Mar 3, 2004 | 05:33 PM
Inazuma's Avatar
sup Randode. I did not call you Stylis. I quoted his remark..
Thanks for the reply I will cut the bottom.
thanks again
Old Mar 3, 2004 | 05:52 PM
camoboXb's Avatar
How was the ride with the nf210's?
Old Mar 3, 2004 | 05:53 PM
randode's Avatar
Wagonistas
thanks again
i know, i was giving you a hard time. :D
Old Mar 3, 2004 | 06:06 PM
Inazuma's Avatar
thanks again
no problem man..thats what i thought..
Old Mar 3, 2004 | 06:14 PM
bobbyboshay's Avatar
I installed nf210's on Sunday. Personally I think the ride sucks. I'm extremely disappointed. They " DO NOT" ride better than stock. I would like to drive someone's xB that has goldline's ,spy's ,or the df 210 and is running 215/45/17 tires and rims. I ready to take springs back off. I think the back sits lower also but it's only been 3 days.
mark13018
Feb 6, 2015 08:57 AM
LowSchool_Xb2
Scion xB 2nd-Gen Wheel & Tire
Feb 3, 2015 12:02 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
lunchbx05
Dec 29, 2014 07:53 PM
