Lowering
Old Mar 21, 2004 | 03:41 PM
Hossam1988's Avatar
Default Lowering
Hey, I think I'm going with 18" ( 215/35/18 ) rims. What do you think is better for lowering?
1) TRD 1" Drop
or
2) 2" Drop (You tell me whats the best brand)
Old Mar 21, 2004 | 03:47 PM
scionracerxb's Avatar
2" GOLDLINE
Old Mar 21, 2004 | 03:48 PM
its_ikon's Avatar
spy or tein
Old Mar 22, 2004 | 12:15 AM
Nathant888's Avatar
DeepSouth Scions
It depends on where you are from. I live in Northwest Arkansas and there are hills, bumps, and potholes galore. I would say go with the TRD 1" drop, just to be safe. Many people have said the drop is 1.25 after u break them in. But the decision is yours.
Nathan
Old Mar 22, 2004 | 02:18 AM
xBSciontist's Avatar
Scion Dynasty
I got the same size wheels and got the Spy Engineering 2" drop springs. Box rides good and looks nicer. Need my bro to borrow his camera so I can post pic.
Old Mar 22, 2004 | 02:23 AM
TheScionicMan's Avatar
2" on goldlines. Looks good, rides good, handles great.
Old Mar 22, 2004 | 02:32 AM
PandaIst's Avatar
spy, tein, tanabe, or rs-r.
Old Mar 22, 2004 | 09:48 PM
Distracted_Thinker's Avatar
When you lower it I know it rides better but what about the bumps does it ride stiffer (more bounce)?
Old Mar 22, 2004 | 09:58 PM
randode's Avatar
Wagonistas
2" spy or 2" gollines.
i've installed 27 sets of springs!
Old Mar 23, 2004 | 04:32 AM
scionxb04's Avatar
tein if u want a nicer ride....spy and goldline have higher spring rates which = harsher ride
im running 18x7.5 with 215/35/18
offset front 45mm offset rear 30mm
using tein s techs
Old Mar 23, 2004 | 03:35 PM
randode's Avatar
Wagonistas
using tein s techs
both spy and goldline ride excellent.
Old Mar 23, 2004 | 06:53 PM
scionspecialistvegas's Avatar
I agree the spy's or goldline do give a preety smooth ride.
Old Mar 23, 2004 | 07:02 PM
randode's Avatar
Wagonistas
GoldLines are the best "bang for your buck"
Old Mar 23, 2004 | 07:43 PM
Al-Truistic's Avatar
OK.....ummmm
What's the diff, are the Spy's and Goldlines's lower rate than Tein, so that they "ride excellent?" Does that mean they ride more like a Towncar or even close? :?
Al.Truistic
aB
using tein s techs
Old Mar 23, 2004 | 08:13 PM
randode's Avatar
Wagonistas
Originally Posted by Al.Truistic
OK.....ummmm
What's the diff, are the Spy's and Goldlines's lower rate than Tein, so that they "ride excellent?" Does that meant they ride more like a Towncar or even close? :?
Al.Truistic
aB
using tein s techs
not quite like a towncar, but not as bumpy as stock.
Old Mar 23, 2004 | 08:23 PM
bBted's Avatar
tanabe df-210 is the bomb...
Old Mar 23, 2004 | 09:15 PM
stankubrick's Avatar
OK.....ummmm
This is what confuses me. From most opinions, Goldlines are supposed to be the smoothest ride (not stiff), so they must have the lowest spring rate right? But from the specs, Goldlines have pretty high spring rates. :?
spring rates = Front/Rear:
KGMM DR21 = 2.2-3.8/1.1-4.4
KGMM NP21 = 1.7-3/1-3.7
Goldline = 3.3/3.4 (front linear/rear progressive)
Tein S. Tech = 2.6/3.2
Tein H. Tech = 2.3/3.2
Tanabe DF210 = 2.8/3
Tanabe NF210 = 2.1/2.5
spy = ?
eibach = ?
(all are progressive except goldline)
By this info, Tanabes should be the smoothest (least stiff) :?
Maybe there are other factors besides spring rates that determine smoothness?
Old Mar 24, 2004 | 12:37 AM
jackmott's Avatar
since they are all progressive, a spring rate number alone is meaningless
the goldlines may have a softer or larger progressive range
or may be quoting the hardest part of their range while others are quoting the softness
who knows!
Ive got linear eibach race springs all around now and it feels fine =)
wussies ;)
OK.....ummmm
spy = ?
eibach = ?
Old Mar 24, 2004 | 12:42 AM
ahurdl01's Avatar
the springs may be softer, but longer, so they give the same drop but better bump absorbtion. the stiffer ones, may be shorter, and stiffer ride. progressive springs are the best way to go, soft at first then stiffer at the end.
Old Mar 24, 2004 | 12:46 AM
unlmtdndeavor's Avatar
i say tanabe...but hey, thats wat i got and the only ones ive ridden in have tanabe, so who knows
