how far does the sub magnet need 2 B from the opposite wall?
Old Oct 26, 2005 | 01:49 AM
skizzle's Avatar
Default how far does the sub magnet need 2 B from the opposite wall?
How far does the magnet on a sub need to be from the back of the sub wall? is 1" enough?
Also, this box is going to be 0.5 cu ft....is polyfill necessary?
thx!
Old Oct 26, 2005 | 03:19 AM
Piston's Avatar
yes and yes.
What kind of sub?
Jason
Old Oct 26, 2005 | 04:16 AM
xbderby's Avatar
more like yes and not really ( I bet you will not hear any difference if you had fill in the box or not - but then again, it's not like it is expensive to do so the real answer is it doesn't really matter, whatever makes you feel good )
Old Oct 26, 2005 | 10:40 AM
skizzle's Avatar
it is a memphis Power Reference 10" SVC sub...
will be powered by a memphis amp also....250w...
it's for a floor enclosure...
How much poly fill? enough to just cover the back wall? there won't be much room!
Old Oct 26, 2005 | 05:01 PM
SCI_TC_GUY's Avatar
1lb of stuffing for 1cu. ft......so 1/2lb....
Old Oct 26, 2005 | 10:02 PM
mandos's Avatar
The magnet should be as far from the back wall as the diameter of the pole vent.
Is the sub recommended for a .5 cube enclosure? If so, you don't need polyfill.
Old Oct 27, 2005 | 05:24 PM
INSIDEOUT's Avatar
I have not ever been a fan of polyfill..... But I would try to get at least 1/2"away from the wall up to 3/4" if you can..... Some subs will recomend 3/4" for the speaker to vent properly, almost all JL Audio subs do...
Old Oct 28, 2005 | 12:55 AM
skizzle's Avatar
yeh it recommends a .5 cu ft enclosure for sealed...
I even confirmed that with the memphis dealer here in town...
Thanks so much for the answers! I really appreciate it!
Old Oct 28, 2005 | 05:02 AM
Sciond's Avatar
read the specs and use the thiel and small paremeters to build your box,,,see the sticky for DIY
lvlonkey
Sep 22, 2016 02:23 AM
SJMiller
Sep 12, 2015 06:33 PM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
vancouverray
Scion xB 2nd-Gen Wheel & Tire
Aug 14, 2015 11:47 PM
Subaru86
Jul 31, 2015 04:00 AM
