tC Tech and DIY Info for the Scion tC
LED Swap (Steering Wheel Controls)
Old Nov 3, 2005 | 10:31 PM
j3st3r's Avatar
Music City Scions
Default LED Swap (Steering Wheel Controls)
Tools Needed:
Philips Screw Driver
Wire Cutters/Knife
T30 Torx Bit
3 LED's (I Used Blue)
1. http://lc-led.com/View/itemNumber/98 - These are for the Guage Cluster, Steering Wheel Controls, and the AC Unit
2. http://lc-led.com/View/itemNumber/38 - These are used in the stock radio
Tweezers
Solder
Soldering Iron
1 Wire Tie
**Probably a good idea to disconnect negative battery cable first**
2006 Scion TC
1) Loosen the 2 T30 Torx Bit screws on either side of the steering Wheel
Left Side (Sorry for poor quality pic the screw is in the hole shown):
Right Side:
2) Gently pull the center section of the steering wheel toward you and prop it in a good postion. This will expose the single screw needed to remove the radio controls from the steering wheel.
3) Remove the screw holding the radio controls in place and then pull the controls out (It takes a pretty good pull to get this out)
4) On the back of the radio controls remove the 3 very small screws(shown highlighted in blue), and also clip the wire tie holding the electrical connection(shown highlighted in green)
5) There are 3 LEDs on the board(highlighted in Blue)
6) Finished Product!
Old Nov 3, 2005 | 10:44 PM
mandos's Avatar
NICE
Old Nov 3, 2005 | 10:55 PM
ScionofKirkland's Avatar
GREAT!!
Old Nov 9, 2005 | 01:30 AM
IAmTheProdigy's Avatar
Perfect, been looking for this. Thanks
Old Nov 11, 2005 | 02:52 PM
Probably a ridiculous question, but when removing center section of the steering wheel, are there any precautions in regards to the airbag? I think not, but I just want to verify. Thanks.
Old Jan 12, 2006 | 02:56 PM
scioncraze05's Avatar
are the leds the same as the gauge cluster and center console???
Old Jan 12, 2006 | 06:12 PM
FromThisSoil's Avatar
Always disconnect the negative battery cable when working with onboard electronics, especially around airbags...
Old Jan 14, 2006 | 07:49 AM
Poison's Avatar
Sweet, any updates?
Old Jan 14, 2006 | 01:45 PM
jjos1's Avatar
I wonder if blue would be as bright as the ambers are?
Old Jan 14, 2006 | 02:01 PM
j3st3r's Avatar
Music City Scions
The LEDS are the same as the guage cluster. I am running blue and they look great!
Old Jan 14, 2006 | 02:35 PM
Tito_Cruz's Avatar
ooooooh...(eyes widen)
Old Feb 3, 2006 | 03:32 PM
jetlounge's Avatar
any chance of getting the pics and links to work on the walkthru?
Old Feb 3, 2006 | 03:34 PM
ack154's Avatar
I just took a look at the actual links and the images are there, not sure why they're not showing up though...
Old Feb 3, 2006 | 06:59 PM
toupy's Avatar
can't see the pics lol and ack is right, if you go to the links you can see the images but it won't show up on here..
Old Feb 4, 2006 | 04:45 AM
PrivateTucker's Avatar
Is it possible to move this to the FAQ section?
Old Feb 4, 2006 | 12:11 PM
jetlounge's Avatar
is it possible to fix the pictures?
Old Feb 4, 2006 | 07:27 PM
j3st3r's Avatar
Music City Scions
Think I have it fixed!!!
Old Feb 4, 2006 | 08:03 PM
bBlover's Avatar
that's cool!!
Old Feb 4, 2006 | 11:13 PM
jetlounge's Avatar
great! thanks!
Old Feb 4, 2006 | 11:18 PM
jetlounge's Avatar
ugh...3 leds! i only have 2 left over from my console/gauge change. and lcled has a 30 led minimum.
oh rats!
