can "Start button" be done in our tC ?
Old Nov 16, 2005 | 04:26 AM
zyzyx6969's Avatar
Big Sky Scion
Default can "Start button" be done in our tC ?
can it be done in our tC like the new Lexus ?
what you think of this ?
experts, please help !
Pivot Starter Button
http://www.the-pivot.co.jp/product/starter/ssk-e.html
http://cgi.ebay.com/ebaymotors/Pivot...temZ8009269260
DIY (on different car) translated from Japanese
http://translate.google.com/translat...en-US:official
Old Nov 16, 2005 | 04:30 AM
zyzyx6969's Avatar
Big Sky Scion
Theft Prevention
Car theft prevention function prevents the starter from working, if the secret number of times is not pressed. This helps prevent theft by direct battery connection or even by leaving keys in car. Also, even if the car is stolen, it will prevent the car being started again.
Normal Operation
When not needed, it is easy to reset the crime prevention function to allow you to start the engine as usual.
Secret number of times
Possible to make secret starter settings in two groups with up to six times each.
Threatening Blink
If engine is off, the illumination will blink.
Illumination
Lamp emits highly luminous LED.
Switch
Just open a up22mm hole for easy installation.
Easy-to Install
Easy-to-install harness for turbo timers complete with couplers connected (possible to wire directly)
Can be used
Possible to use together with remote control starter and / or turbo timer.
Old Nov 16, 2005 | 05:30 AM
ChicagosFinest's Avatar
OhioScions
I'm working on something like this.. I'm not sure if it will be plausable to sell it as a kit, or if it would just be something for my self.. I'll keep you updated on it though.
Old Nov 16, 2005 | 05:33 AM
zyzyx6969's Avatar
Big Sky Scion
thanks a bunch
keep us updated
Old Nov 16, 2005 | 05:44 AM
OhioScions
I'm still trying to decide how I want to do it.. it's one of my many projects that are in progress..
I'm thinking though that I'm going to run it off the alarm so it works like the remote start.. or maybe like the key after remote start.. I'm not sure yet, and I need to get back under there before I decide.. give me a week or so and I'll follow up with the final plan..
Old Nov 16, 2005 | 06:46 AM
zyzyx6969's Avatar
Big Sky Scion
hahahahha, I know how to do it now check these PDF files out
http://www.the-pivot.co.jp/manual/pdf-e/SSK-1-e.pdf
http://www.the-pivot.co.jp/manual/pdf-e/SSK-2-e.pdf
http://www.the-pivot.co.jp/manual/pdf-e/SSK-3-e.pdf
http://www.the-pivot.co.jp/manual/pdf-e/SSK-4-e.pdf
or go here:
http://www.the-pivot.co.jp/manual/flame-manual-e.html
The Pivot Security Engine Start Button allows you to start your vehicle's engine with a push of a button. Also features a car theft prevention function which prevents the starter from working, if the secret number of times is not pressed. The secret code consists of 2 set of scret number of pressing from 1 to 6 pressings for a total of 36 combinations from which you can choose. This helps prevent theft even by leaving the keys in car. (When not needed, it is easy to reset the crime prevention function to allow you to start the engine as usual)..The highly luminous blue illumination allows for easy nighttime visibility and will also blink when the engine is off to deter thieves. The kit provides everything you need to upgrade to this cool feature. Installation instructions included for an easy install. Made by Pivot Japan.
Old Nov 16, 2005 | 08:42 AM
OhioScions
you sir have made my evening.
I'll probably do this first week of dec.
Old Nov 16, 2005 | 11:36 AM
OhioScions
to work it you need the key in the on position.. I'm going to work arround that though..
I'll see if maybe I can get a wiring scheme drawn up this evening or tomorrow.. a little to tired to do it now, and a little too close to class to sleep
Old Nov 16, 2005 | 04:06 PM
zyzyx6969's Avatar
Big Sky Scion
good luck with the new project
Old Nov 16, 2005 | 04:45 PM
OhioScions
I might need more time to consult with sources, but I'm going to get it done soon..
Old Jan 31, 2007 | 02:43 PM
STNC's Avatar
The pivot button looks great, i just ordered the blue security starter switch.
Old Jan 31, 2007 | 11:02 PM
mattieg's Avatar
hmmm i know that if you have a remote start you can press a valet switch twice and it will start the car. Thats if you have it prgrammed to do that. But what about the steering wheel lock? Are you going to start the car with the button and then put the key to the on position?
Old Feb 1, 2007 | 02:49 PM
STNC's Avatar
I'd put the key in the on position, and then push the start button, although pivot says they can wire it so you don't need a key, but I'm not going to do that
Old Feb 2, 2007 | 08:17 PM
pentavolvo85's Avatar
If you just want it so you turn the key on and then hit a start button its extremely easy to do. Let me know and I can provide you with some more details
Old Feb 2, 2007 | 08:28 PM
teamben158's Avatar
It would be sweet to hook this up, in combination with something like the new vettes have, where all you need is a card in your wallet to unlock the doors and start the car. You wouldn't even need a key anymore.
Old Feb 2, 2007 | 08:57 PM
STNC's Avatar
Pivot, the company that makes a switch, has a way to wire it so you dont need the key, idk if thats such a good idea.
Old Feb 3, 2007 | 01:03 AM
mattieg's Avatar
What about the computer chip thats inside our key... if the key is not in the cylinder then you would need a 556LW module and put your spare key in that so you can start it. Then what about the steering wheel lock?
Old Feb 3, 2007 | 02:51 AM
STNC's Avatar
idk, thats what i was wondering about, ill look at the manual and get back to you
Old Feb 3, 2007 | 02:53 AM
STNC's Avatar
Heres the manual: http://www.pivotusa.com/installationman/pivssk_r_l.pdf
Old Mar 30, 2007 | 02:17 AM
nautyblu06's Avatar
Just to let everyone know, a push start button can be done. I have it installed in my tc. In another day or so i will have the link to my youtube video and pictures of it posted.
