Will a 15" steel wheel fit on a tC?
Old Nov 23, 2005 | 06:26 PM
BizzyDaKid's Avatar
Default Will a 15" steel wheel fit on a tC?
I went to Les Schwab to price out some snow tires and wheels for my GF. They said tC's only come with 17 in. wheels so 15 in. wheels might not clear.
And if a 15" does fit, does anyone know the offset? Is it a 4x100?
Thanks.
Old Nov 23, 2005 | 06:36 PM
Shoe_Here's Avatar
15's work just fine on tc, especially for winter. 5x100
Old Nov 23, 2005 | 06:38 PM
BizzyDaKid's Avatar
Awesome, thanks.
I figured they would, but they were afraid that they came with 17's for a reason like bigger brakes or something.
I just wanted to make sure.
Old Nov 23, 2005 | 07:06 PM
Rick_NSX's Avatar
nope... 15's will fit fine... I have a set of steel corolla rims for drag tires so I don't burn up my road rubber... it fits perfect
Old Nov 23, 2005 | 07:50 PM
DynomyteSW's Avatar
what year corolla did your 15's come off?
thought corollas were 4 lug
Old Nov 23, 2005 | 08:42 PM
Rick_NSX's Avatar
it came off a 2005 and it is 5 lugs...
Old Nov 23, 2005 | 10:22 PM
schwettynuts's Avatar
How much money are you going to spend total?
Old Nov 24, 2005 | 06:31 AM
tikbhoy's Avatar
15's ???? why ? what are you trying to achieve ?
Yes as said above its 5x100 and get the right offset if you are going that size . Do some more research also how this combo will affect the calibration of your speedometer.
Old Nov 24, 2005 | 06:33 AM
Jimmy's Avatar
if 20's fit, im sure 15's will... offset must be high for it to clear the calipers though
Old Nov 24, 2005 | 07:19 AM
DJ_X_Trodinaire's Avatar
hmm 15 x 10 rims!
that be interesting
Old Nov 24, 2005 | 07:46 AM
Jimmy's Avatar
Originally Posted by DJ_X_Trodinaire
hmm 15 x 10 rims!
that be interesting
thats what you call gangster lean
Old Nov 24, 2005 | 11:08 AM
06tCguy's Avatar
no, 13x10 is gangster. 15x10, assuming the tire is tall as well, is called traction.
Old Nov 24, 2005 | 11:27 AM
djct_watt's Avatar
Team Sushi
Changing the size of your wheel does not affect the speedometer. It's the overall diameter of the wheel/tire. Assuming you correctly size your tires, your speedometer will remain accurate. . . nothing a basic online tire size calculator can't do.
Old Nov 24, 2005 | 11:30 AM
djct_watt's Avatar
Team Sushi
And don't be surprised if your MPG increase, and your acceleration increases as well (radius supercedes weight in rotational inertia: meaning that reducing the wheel size produces more power gains than reducing weight, assuming you keep width constant, for traction).
Old Nov 24, 2005 | 12:10 PM
06tCguy's Avatar
yep, less rotating mass equals better acceleration and more fuel efficiency, as it takes less power to move a lighter wheel.
Old Nov 24, 2005 | 01:32 PM
getting 4 steelies and snow tires can be pricy. Also what kind of winter tires are you getting? I hope you are not getting snow tires. Get performance winter tires! If I were you I would check out www.craigslist.org and find people in your area whos selling their winter tires. Youll be suprised. Also tell me how much you are going to spend.
Old Nov 24, 2005 | 03:46 PM
tCb00b's Avatar
You may also want to check out www.tirerack.com They have neat little program that shows/ helps you choose winter wheels and tires. Go to their site and click winter.
Old Nov 25, 2005 | 06:10 AM
djct_watt's Avatar
Team Sushi
You're on the right track, but sorry if I seem like I'm busting your spheres. . . but I would really like to see the common misconception cleared up.
Rotational inertia is a function of mass and the SQUARE of radius (or was it diamter, but basically the same thing, sorta). What does that mean? Keeping weight constant, reducing the wheel size has an exponential effect on reducing inertia, rather than the linear effect of weight alone. Therefore, going with a smaller, heavier wheel often times outperforms a larger, lighter one. However, the ideal setup is a light weight, small diameter wheel.
My main point is that the size decrease alone is far more beneficial than the weight savings (unless of course the % weight decrease is more substantial by a great degree, which is rare).
Don't forget that increased MPG and acceleration aren't the only benefits. . . your braking power is considerably increased, and if you are a skilled driver, all track times will decrease (considering your tires and wheel width is up to par). But the original poster is only looking for winter wheels, so all this is moot anyway. And small rims are ugly, of course. Hahaha!
Old Nov 25, 2005 | 06:37 AM
bB2NER's Avatar
Music City Scions
I did some research and came up with a tire size of 205/65/15 should be the same height as the stockers. The 15 inch steelies should work fine for winter duty on a tC also. Went to tire rack and they only go down to 16's for winter tires. Hope this helps Bro!
Old Nov 25, 2005 | 07:53 AM
bBlover's Avatar
Has anyone seen the tC Tuner Edition Comcept?? That has steelies.
