17x7 +29 Offset too low?
Old Dec 16, 2005 | 05:46 AM
protomonkey's Avatar
Default 17x7 +29 Offset too low?
I was just wondering if a 17x7 +29 rim would work on a Tc, or is the offset too low?
Thanks in Advance.
Old Dec 16, 2005 | 06:19 AM
HKSpeed's Avatar
you will be fine. the fronts will fit almost flush. the rears will still sit in alot.
i have a 7.5 inch wheel with 33 offset. my setup sticks out 2mm more than what you proposed. i have a 5mm spacer in the rear and it still looks like poop. for your setup a 5mm spacer up front and a 15mm in the rear will make it flush.
Old Dec 16, 2005 | 03:46 PM
DuMa's Avatar
It'll fit. it will look better than the stock wheel setup.
its supposed to stick out around 16mm each wheel. if you had a 7.5 or 8" wheel, you'd be flush with the fenders.
Old Dec 17, 2005 | 08:43 AM
tinybigrig's Avatar
itll fit fine, run staggered if you can, itll fill the arches much better
brent
terrye
Jul 11, 2015 11:54 PM
debris
Dec 16, 2003 11:50 PM
hahajoey
Nov 15, 2003 04:48 PM
smilygo
Oct 1, 2003 07:03 AM
TJ
Sep 29, 2003 06:52 PM
