Lighter wheels
do some serches online not sure about the exact number's but the more weight you remove from your rotating mass the faster your car will excelerate it is like using lighter weight valve train for your motor let's it rev faster
Here is a little answer. Maybe not how much time is knocked off a 1/4 mile,
but interesting.
but interesting.
Rotational Inertia
The rotational inertia topic was so big, it took me two months (June and August '99) to get it sorted out. Here's the deal: There is this rule of thumb among racers that adding weight to something that rotates is far more detrimental to performance than if you add it to the body of the car. This is absolutely true, and by bumbling through some physics, and after slipping and falling on a radian, I managed to get a few formulas figured out that could tell you just how much worse.
Any moving object has kinetic energy, as does an object sitting in place and rotating. An object that is both rotating and moving (like a rolling wheel, for example), has kinetic energy from both, meaning that accelerating or decelerating that rolling object will take more power than one that is just sliding along. How much more power is the question.
The answer, it turns out, depends on how the weight is distributed on the wheel. An extra pound on the tread of a rolling tire has as much kinetic energy as 2 lbs on the floor of the car. As you move toward the center of the wheel, the rotational effect drops until, at the center, a pound is just a pound. The formula I derived to determine the exact relationship between weight on a wheel and weight in the car isn't worth repeating here for one simple reason. It requires that you know the moment of inertia of the wheel, and measuring that is virtually impossible. What you need to know is that changing to tires that are 1 lb heavier will effectively add 8 lbs to the car (four tires, remember) and that adding a pound to the wheels will effectively add somewhere around 6 lbs to the car.
That only considers acceleration and braking; handling is dramatically affected by unsprung weight as well, but no simple formula is going to tell you how big the effect is.
Sport Compact Car :Technobabble: September 2001
The "Technobabble" Study Guide
By Dave Coleman
By Dave Coleman
Team Sushi
Rotational Intertia = weight x (radius)^2
Removing weight is great. . . so long as you aren't pushing that weight further from the axis of rotation (meaning an increase in diameter).
Team Sushi
Furthermore, the whole analysis of wheel weight and equivalent weight on the car is kind of stupid. . .
Think of it this way, adding or removing weight to the car affects the power/weight ratio.
Adding or removing weight from the wheel (or affecting the diameter) directly increases or decreases the HP you put down to the ground, while affecting power/weight as well. Sure you can calculate the freed up HP's equivlent in weight reduction, but in all reality all you have done is increase HP. Imagine calculating the HP added by a turbo in equivalent weight savings.
Weight savings are weight savings. Reducing wheel weight and keeping diameters resonable increases HP to the ground.
ColonelSanders85
Dec 9, 2020 09:44 AM
BrokenTC2
Jan 27, 2015 03:32 AM
NonStopTuning
Jan 20, 2015 05:20 AM
eric_m
25
Oct 18, 2003 12:33 AM
