Regional - Great Lakes IL, IN, OH, MI, WI
Sound Performance TC Turbo Kit For Sale
Old Jan 31, 2006 | 08:04 PM
Parts_Pimp's Avatar
Default Sound Performance TC Turbo Kit For Sale
We at Sound Performance are proud to offer for sale our SP TC Turbo Kit. This is one of the nicest kits on the market. This is a full bolt on kit that will come with instructions and all parts needed. We will be offering a stage 1 stage 2 and a Tuner Kit. At this time the Stage 1 is the only available kit. We are testing the other 2 kits at this time. The stage 1 turbo kit will come with the following parts standard in the kit.
SP TC 32 Turbo (non ball bearing)
Tubular Stainless Steel Turbo Header
Delphi 440cc Injectors with clips
SP TC Front mount intercooler with pipes (bolt on no cutting the bumper)
SP TC Complete return fuel system
Fuel system includes
All high pressure line
All a/n fittings needed
Aeromotive fuel pressure regulator
Liquid filled pressure gauge
Fuel Rail with return fitting welded on
Tial 38mm waste gate with a 7lb spring
Turbo XS blow off valve
Apex Safc II (black or silver)
Ceramic Coated - Manifold/down pipe/turbo (hot side)
Powder Coated - Intercooler pipes and Air Intake Pipe(any color)
Polished-Turbo (compressor housing)
Oil Pan with fitting welded in
Oil Return line with fittings
Oil Supply line with fittings
Stock fuel pressure regulator welded closed
All couplers and clamps
AEM 3in Dry flow filter
NGK Spark Plugs
Retail price-$4999.00
Scion Life price-$4500.00
Special for the first 10 kits ordered-$4150.00
The up-grade options for the kit are
SP TC 32R dual ball bearing turbo with water lines $450.00
Stainless Steel fuel lines-$75.00
AEM Uego wide band gauge-$299
Chrome intercooler pipes and air intake-$325.00 (that includes all intercooler pipes)
Fiberglass glove box mount for SAFC and uego-$200 (painted to match car)
Apex turbo timer-$109.95
Auto Meter boost gauge-$59.95 (black-white-silver)
We will also offer a $125.00 credit for your old oil pan,fuel rail, pressure regulator
The car has no check engine lights and drives like stock. The blow off valve is vented open and the car does not stall at all. The kit makes 260hp at the wheels and 280 foot pounds of torque on 7lbs of boost. I will have video very soon...
Old Jan 31, 2006 | 08:08 PM
Parts_Pimp's Avatar
Here are the pictures of the kit on the car. I will have pictures of the kit off the car very soon. The turbo in the pics in the ball bearing up-grade with the chrome pipes.
BigPinoyTC's Avatar
Let the sales begin!!!!!!
Come one everyone.....this is what you've been waiting for and turbo kit that will not only perform but will also be a great show kit. Very Very clean looking.
Old Jan 31, 2006 | 08:11 PM
BigPinoyTC's Avatar
Come on Noel!!!
Spend some money!!!!!!!!
Old Jan 31, 2006 | 08:14 PM
mattssi's Avatar
VERY VERY NICE! Can't wait to see a customers install experience and #'s. Looks great, and the return system is just sweet.
That intro price is great too.
Is timing, etc adjustable w/ that SAFC-2?
Parts_Pimp's Avatar
Old Jan 31, 2006 | 08:17 PM
Parts_Pimp's Avatar
No you can not adjust timing we are tricking the computer to take away timing with the safc and fuel pressure..
Old Jan 31, 2006 | 08:31 PM
mattssi's Avatar
Good stuff. no cel = sweet.
What sort of bolts did you use to mount the intercooler?
Nuts and bolts size, etc (If you can answer, its appreciated)
Old Jan 31, 2006 | 08:41 PM
Parts_Pimp's Avatar
They all come with the kit...
Old Jan 31, 2006 | 09:03 PM
Parts_Pimp's Avatar
Old Jan 31, 2006 | 09:17 PM
mattssi's Avatar
Thats cool they do.
What are they specs on them (I need to get some)
Old Jan 31, 2006 | 09:27 PM
Parts_Pimp's Avatar
the bolts?
Old Jan 31, 2006 | 09:31 PM
Parts_Pimp's Avatar
The install will be $800 with before, after and dyno tunning all included in that price...
Old Jan 31, 2006 | 09:52 PM
mattssi's Avatar
the bolts?
Yes. (Who would have known)
Old Jan 31, 2006 | 09:54 PM
Parts_Pimp's Avatar
They are 5/16 x 3in corse bolts with lock nuts. They bolt through the bumper support...
Old Jan 31, 2006 | 09:56 PM
mattssi's Avatar
Thanks sir!
Old Jan 31, 2006 | 10:38 PM
Parts_Pimp's Avatar
Not a problem
Old Jan 31, 2006 | 11:08 PM
bpsciontc's Avatar
so how much is the better turbo kit & when is it comin out ? do u know how much more gain will be? will it be the same as just getting a ecu aem box how much gain off of that?
Old Feb 1, 2006 | 02:25 AM
Parts_Pimp's Avatar
Well the stage 2 kit should make around 300 wheel hp. The tuner kit will need the AEM ECU and to be wired in. That kit should make 400 plus HP.. I do not have prices yet.
Old Feb 1, 2006 | 09:14 AM
Eppopipe's Avatar
OhioScions
any chance itll work on a auto??
