turbo oil return line
Old Mar 21, 2006 | 04:37 AM
black2doorecho1nz's Avatar
Default turbo oil return line
[img]What is involved in installing the return line in the oil pan on the 1nz-fe. Do i need to remove the upper alluminum portion of the pan.[/img]
Old Mar 31, 2006 | 05:09 PM
lastlookcustoms's Avatar
You dont need to remove the upper aluminum pan nor do you want to. I drilled into the upper aluminum pan, in the rear right infront of the passenger side inner cv boot...
Old Mar 31, 2006 | 07:00 PM
Simplyscion's Avatar
Team No Limitz
yea, I did the same...no way in hell you wanna take that oil pan off
Old Mar 31, 2006 | 07:14 PM
BoogieQ's Avatar
So, you guys just let the chips from drilling go into the oil pan? I am assuming you ran a bunch of oil down through the motor to try and collect as much as you could?
Old Mar 31, 2006 | 08:02 PM
dgHotLava's Avatar
no, you drop the oil pan...(the little frisbe cover)
they are talking about the lower girdle.
you drop that and the crank will drop out. just drill into the girdle with the pan off. no chips...
Old Mar 31, 2006 | 08:58 PM
thanks for the info
Boostedyota
12
Feb 20, 2024 10:46 AM
Brammi
Nov 13, 2016 03:46 AM
my06tc
Jun 25, 2015 12:18 AM
DougC
Feb 22, 2015 02:39 PM
psturm
Feb 18, 2015 11:12 PM
