View Poll Results: Should tC come with a rear spoiler?
Yes
0%
No
0%
Leave as option
0%
Voters: 0. You may not vote on this poll
Spoilers and Hood Scoop for the supercharged tC
Old May 27, 2004 | 05:51 AM
NKP82's Avatar
Default Spoilers and Hood Scoop for the supercharged tC
Was looking at the Scion tC and was thinking how much better it would look with a good rear spoiler stock. That empty space some what detracks from the overall look IMO, but I am sure there is already a few aftermarket rear spoilers in the making. And as for the s/c model of the tC, will it have a scoop on the hood like other supercharged or turbocharged cars in its class.
Old May 27, 2004 | 06:00 AM
DuMa's Avatar
as far as major exterior changes.... i think its fine as long as its lowered and has tint.
the rear wing accessory looks pretty nice and clean. it should be a good compliment to whatever a tc enthusiast thinks their car should look like.
Old May 27, 2004 | 01:51 PM
mgithens's Avatar
the aftercooler is actually under the scoop on the WRX... on the neon, it is just for looks, the only thing that air scoop does is force air behind the engine to help eliminate some of the turbo's heat...
we don't need another "me too" car, just cause everybody else is doing it doesn't mean we should hope for it on the tC... people don't say that the WRX looks luxury, people don't think the Neon looks luxury... so don't emulate them if that is the look you want...
I personally like the rear of the car, but the M3 style lip spoiler will be a nice addition...
Old May 27, 2004 | 02:40 PM
NKP82's Avatar
I always been a big fan of cars with spoilers, and I knew they used the scoop for something besides looks, just did not quite know what. Well when I get a tC I assure you that I wont be ricing it out, if you put that much work into it, might as well go all the way and not half assed. I'll be getting the s/c tC. And I intend on putting new hood for the weight reduction it has, and would like it to have a scoop on it, they look kick ___ IMO. Never looked under the hood of an Impreza WRX (they are nice cars), does the intercool mounted onto the hood or does it sit above the engine, because if it monted on the hood I want to do the same with my tC when I get it. Gives purpose to having that scoop other then looks.
Old May 27, 2004 | 02:53 PM
mgithens's Avatar
well, the engine in a WRX is totally different... you have heard of a V-8, that is because 1/2 the cylinders are on one bank and 90 degree or 60 degrees away are the other 4... so they form a V... well, the WRX is a 4 cylinder and the banks are 180 degrees away, so you could call the engine a boxer or flat or horizontally opposed... this is how the VW BUg, Porsche 911, 912, 914, 356, 550 are all setup... the benefit is that the whole engine is much, much flatter - so this leaves room for a top mounted intercooler... for a typical horizontally mounted FWD inline 4... you pretty much need to route the ducting down to in front of the radiator and condensor...
also, the factory SC doesn't need a intercooler, it only compresses the air a small amount... so the air doesn't get as hot... so cooling is not near as beneficial, so the cost to benefit is pretty bad... we're talking a few horsepower for maybe $1000 to 1500...
Old May 28, 2004 | 05:50 PM
NKP82's Avatar
As for replacement hoods, I saw a hatchback with a carbon fiber hatch, functions much like a carbon fiber hood. Would the weight reduction by replacing the hatch with carbon fiber be worth it or is the hatch not have enough weight where it would be worth it. And as for the engine, what is a good manufacture(s) of cold air intacks, and which have the best price to performacne boost, with in a 150.00-250.00 range. And I was also thinking that about boosting compression ratio on the supercharger, and would like to know how high I could increase compression ratio with out the need for a intercool system or comperising the integrity of the supercharger and the engine.
Old May 28, 2004 | 06:23 PM
mgithens's Avatar
ok, one question at a time...
#1 hatch... I guess you are saying the entire hatch?? yeah, you could save a ton of weight if you took out the back glass and all the metal that the hatch are made of... maybe 50lbs of savings?? of course seeing out the back window is nice... and you aren't gonna find an aftermarket carbon fiber hatch for the tC that will hold the stock glass...
#2 intake... price doesn't go hand in hand with performance, I know a bunch of guys that just get their own tubing... what matters is to develop a smooth, cool path for the air to go through... start with removing all the intake muffler, air box and ducting and see what room is available - the goal is to route the newer, larger air filter to a place where it will A- get a fresh supply of cool air and B- not drop below water in the event you have a heavy rain and finally C- have as little restriction and interruption to the air path until it hits the mass air flow sensor... APS has a system out right now, pics are already on the board of a baby blue tC with the intake and TRD springs...
#3 higher boost... the problem with higher boost is that when you compress air it gets hotter, so about the only way to avoid intercooling is to start with a cooler initial temp... so move to Alaska where it is below 30... I have heard of water injection schemes that shoot about 1 gallon of water per about 10 gallons of gas into the engine, not sure about longevity, but it helps the engine run cooler... all you need is a larger pulley to get more boost, but if the engine computer detects any hint of detonation (premature firing from overheated air/gas mixture) it will retard the spark and you will be making much less horsepower.. this is a whole new can of worms, don't think that you'll just bolt on a part in one hour and get 50 more hp... it will take TONS of time, patience and understanding... I recommend reading "Supercharged" by Corky Bell (available at any bookstore or Amazon)...
Old May 30, 2004 | 01:31 PM
iZero's Avatar
I can't think of other cars in the tC's class that have a hood scoop. The WRX and SRT-4, do but I wouldn't consider those to be in the same class unless they started selling for thouands less all of a sudden. The scoop on the Neon is pure rice. Chrysler thought adding holes all over the place would make the dopey looking Neon mean. The WRX uses the scoop to pass air through its intercooler. You can't really compare the engine layout of the Subaru since it's got a flat-4, which means there's room for the intercooler to sit above the block. Otherwise, you've got the Mustang which not only has a useless (large) hood scoop, but also faux side scoops, and fake rear diffuser.
Back in the mid to late 80's there were other tubocharged cars with hood scoops which fed air to thir intercoolers. Often times, the scoop was off center. I think that's where the trend started on the import side of things.
Old May 30, 2004 | 02:14 PM
jdgeary's Avatar
actually you should do some research before talking bad about any type of car. just cause you don't like srt-4 becasue you probably got beat by one doesn't mean you can trash it. the hood scoop feedd air directly over the turbo to help keep it cool. i'm sure if you got rid of this the snail would overheat, and the holes in the bumper weren't originally there, they were added in because the car actually needed extra cooling. sorry to get so crappy, but i hate it when people bring in there personal agenda's when talking technical.
p.s. no hard feelings...lol
Old May 30, 2004 | 02:48 PM
monsoon725's Avatar
The Neon doesn't need hoodscoops to look mean. I don't care how it looks or if you like it, but if flat out obliterates anything in its class and can hang with cars far more expensive than itself.
People that are talking about increasing boost pressure and trying to develop intercoolers reeaaaaallllly need to do some research. If it were that easy to build an intercooler, do you really think all the kits would be so expensive? BTW, if you intercool a car making low boost, you will actually lose power. Intercoolers zap about 1 psi across the board as you pass air through them. So, clearly, there is no advantage to running an I/C on a car making less than 10psi.
Furthermore, as soon as you go messing around with the TRD blower trying to raise boost, I can guarantee your warranty will be voided on the S/C unit itself and very well could be voided on the entire motor all together.
I hate to burst bubbles, but this is not a performance car....and it never will be..at least not with the TRD blower. When HKS and company start developing kits (if and when) than maybe we might be able to call this a fast car.
Until than, it isnt and all the hood scoops and intercoolers aren't going to help you much.
Old May 30, 2004 | 02:50 PM
iZero's Avatar
Get real. If the turbo needed constant airflow over it, a better system would have been devised. There is no specific ducting to ensure all the air goes over only the turbo. As it is, it only vaugely dumps air over the entire engine. Sure, some of it makes it over the turbo, but to say it's some sort of specific application is silly. Explain to me why the PT Cruiser GT, which has the same engine, lacks any hood scoop. If it's so critical to the vehicle's operation, I would assume Chrysler would have made sure the PT had it as well. If underhood heat were an issue, using vents on the hood would be more effective than trying to blow hot air down under the vehicle.
Not to mention the turbo itself, if it needed to be air cooled, would have all sorts of heatsinks on it to make sure it had maximum surface area to radiate as much heat as possible. At the same time, you're neglecting to realize just about every vehicle out there today comes equipped with a some for of liquid cooling. Why wouldn't that system be utilized as it is far more efficent?
Hey, it's a styling element. That's fine. It's not the first or last car that will use such items. But I'm simply not going to believe something that the marketing department came up with as the undeniable truth.
Old May 30, 2004 | 02:54 PM
iZero's Avatar
It is very possible for something to be fast and at the same time look tacky. They aren't mutually exclusive concepts.
Old May 30, 2004 | 04:19 PM
monsoon725's Avatar
This I agree with. However, I don't think the SRT-4 looks tacky
Adrian
Old May 30, 2004 | 04:43 PM
djimpak's Avatar
the SRT-4 is nice but i don't want one because i've never liked the neon.
Old May 31, 2004 | 11:31 PM
jdgeary's Avatar
dude, okay, go to the dodge dealership tomorrow, crack open the hood of an srt-4 and tell me that there is no ducting for the air to go directly to the turbo, and then look to the right and tell me that there isn't a place for the ducting to be cut to drop air directly over the air box, don't post what you don't know, or if you can't make it to the dealership just look here at the third post...
http://srtforums.com/forums/showthread.php?t=7320
Old Jun 1, 2004 | 02:37 AM
mgithens's Avatar
also, if you look down on the engine you can see plenty of daylight... and since cars cause a slight negative pressure under them and the ram air of the ducting will cause a slight postive pressure... you'll see plenty of flow... not quite as much as the turbo would see if it was just mounted directly on the hood, but plenty of air to help keep it cool...
Old Jun 1, 2004 | 10:01 AM
iZero's Avatar
The airbox? I thought it's supposed to go over the turbo. So now It's cooling a piece of plastic?
Old Jun 1, 2004 | 10:09 AM
iZero's Avatar
If the car had a significant low presure area under it, why would they have tacked on that supposedly functional wing to decrease lift? Almost all cars on the road today create lift at speeds, given their shape (flat on the bottom, rounded up top). Thus, the air must travel a greater distance around the top of a car creating a lower relative pressure. While it's possible the movement of air is enough to create a lower pressure arear in relation to the underhood area, I doubt it's all that effective as it is.
Old Jun 1, 2004 | 10:52 AM
jdgeary's Avatar
izero, all you gotta do is cut out a small piece from the hood ducting and from the air box, or with an aftermarket intake, then air will go directly into the intake , instead of using all underhood air. and the aerodynamics lesson, thanks, but i am getting ready to graduate in engineering, and if your point was completely correct then all cars would create downforce like a freakin enzo, i'm just saying, now that this thread has been hijacked, that the hood is functional not rice, that is what started the whole topic. catch ya guys later
jason
p.s. the wing is only functional at about 100+ and probably doesn't create that much downforce, most wings on any steet car are purely asthetic, NOT ALL, but most
Old Jun 1, 2004 | 02:45 PM
NKP82's Avatar
Well I know there are places where they can modify the black boxs programming to compensate for the increased boost, and since I am some what new to car tuning, I figured have a professional do it for me while I read up on it. And I was thinking about the same thing jdgeary siad, why did some of you hijack the thread I started?
