So i finally get my car home...
Old Nov 11, 2003 | 06:55 AM
Docofmind's Avatar
Default So i finally get my car home...
but my #$%ing luck has not changed. As many of you already heard, I had purchased my wheels and tires long before i ever even got my car. Well, being as obsessive as i am, as soon as i picked the car up from the dealership tonight I drove straight home to swap out the wheels for my 18s. Low and behold, the spokes touch the caliper. The funniest part is that i have a Wilwood big brake kit at my shop ready to be installed tomorrow. Well, it was ready until i found this out.
The wheel will clear with just another mm of clearance but i know the BBK will require atleast another 5mm maybe even a bit more os space. My question to you guys is how large of a front spacer has anyone run?
Basically, the wheel is a Racing Hart knock off, its a 6 spoke wheel with a lip. It has a 45mm offset which is obviously way to high but i knew that going in. I knew i would be adding a spacer but i just didnt know how much. Looks like a 10mm and some longer studs are the only solution. Only problem is im running a 215/40 18 I must say though, the extra sidewall really does look a lot better.
Time to take a bat to the fenders
Old Nov 11, 2003 | 07:12 AM
Hardhitten's Avatar
Wow that sucks dude. I ordered 215 35 18s with 42 offset hope I got no problems.
Old Nov 11, 2003 | 03:27 PM
Docofmind's Avatar
You really shouldnt have a problem as the wheels that i have are +45mm offset. On top of that, they are in set meaning that they have a lip.
Old Nov 11, 2003 | 03:42 PM
randode's Avatar
Wagonistas
if you change to longer studs, a spacer will be fine. Just dont try to use the stock studs, it could be dangerous.
Old Nov 11, 2003 | 04:39 PM
its_ikon's Avatar
my friend with a honda had to get new rims to fit the rotora big brake kit for the same thing you are ending up with.
Old Nov 11, 2003 | 05:47 PM
scionara's Avatar
Because of my buddy's wheel design, the wheel is barely touching the calipers so a 5mm spacer was used (18x7.5 with 42mm offset). He is also running 215x40x18s lowered with TRD springs. I haven't heard a complain from him since.
xbsimple - do you want to add to this?
Old Nov 11, 2003 | 07:09 PM
Docofmind's Avatar
That helps a lot, thanks. So basically he is running a 37mm up front with the trd springs and no rubbing. I just scored some used TRD springs and i called my machinist to make me some 10mm hubcentric spacers for the front and rear. I was just worried about rubbing the fender.
Ultimately, the eventual set up will be a 18 x 7.5 with a 35mm offset from the added spacer and 215/40/18s with TRD springs. The rear will have the same thing so we ll see. I ll keep you guys posted
sensez
34
Nov 24, 2004 12:30 AM
kagero79
39
Nov 23, 2003 05:26 PM
DjFrOsT
Nov 14, 2003 05:26 AM
tC_Normo
Oct 22, 2003 07:20 PM
its_ikon
Oct 3, 2003 08:55 PM
