belt slipedge on blitz s/c
Old Aug 2, 2006 | 07:31 AM
orangescionxb's Avatar
Default belt slipedge on blitz s/c
i have a 2004 auto scion xb w/ the blitz s/c but the belt slips when i stomp on the gas. i dont know if thats belt sliping or somthing eles tell me if u guys have had the same problem and or how to fix it
Old Aug 2, 2006 | 04:49 PM
Eddy2006's Avatar
Default blitz s/c
I have a 05 x/b 5 speed with the blitz s/c, I think what you are feeling is the clutch engaging with the pulley. I doubt it's the belt but go ahead and have the tension on the belt checked out. Any time you change a belt it will need to be rechecked after it gets warm then just retension the belt. EDDY
Old Aug 2, 2006 | 04:55 PM
blown_xa's Avatar
it's the belt, you should tension it after car is warmed up. i tension it like this; i make sure i can twist the belt 90 degrees in between the sc pulley and alternator pulley without forcing, that's a good tension. If belt is too tight u will lose power from binding, if it is too loose u drop power from loss of boost. Believe me it is a fine line. buy a boost gauge also, should read consistant boost all the way to redline without dropping.
Old Aug 16, 2006 | 11:21 PM
its fixed !!!!!! im so happy it works so much better then b4
olyellr
Sep 28, 2015 10:32 PM
Ksn
Sep 21, 2015 06:21 PM
gqdabien
Jul 30, 2015 07:04 PM
bmxScion
Jul 23, 2015 12:07 AM
