"Big Throat" Throttle Body for xB?
Old Nov 28, 2003 | 01:24 AM
rjsalvi's Avatar
Default "Big Throat" Throttle Body for xB?
Has any mfr. released a (larger venturi) throttle body for the xB yet? Maybe someone like Neuspeed...?
Old Nov 28, 2003 | 08:31 PM
Mr_scion's Avatar
N.G.S.O.
i think there is one for the echo should work for the scion
Old Dec 14, 2003 | 07:17 AM
Wraith's Avatar
I know EL Prototypes has one on the shelf...
Old Dec 14, 2003 | 07:43 AM
Guest
Guest
Posts: n/a
is it compatible though? Will it work with our ECU and not cause a check engine light to come on?
Old Dec 14, 2003 | 07:48 AM
Wraith's Avatar
the echo throttle body and the xb/xa have the same engine and electronics... It will not do a check engine light... The only time my echo threw a check engine light is when I pull too much fuel with my s-afc ... I'm a cheap bastard when it comes to my echos gas mileage. I'm getting between 450 to 550miles to a tank with my echo...
Old Dec 14, 2003 | 09:11 AM
bBted's Avatar
thats a lot...u using safc?
Old Dec 14, 2003 | 01:47 PM
Guest
Guest
Posts: n/a
Now what about smog? Wil it pass smog, because when I install something I am just to dam lazy to take it off. :D
Old Dec 14, 2003 | 02:08 PM
Blu_Box's Avatar
Shouldn't cost to much to bore out the stock throttle body
and replace the valve.
That may be the best way to go.
What do you all think?
Blu
Old Dec 14, 2003 | 02:17 PM
Guest
Guest
Posts: n/a
mmm...interesting proposal. But I would need to find a machine shop that has done it before. I don't want to be a quinea pig, but then again how much could you really bore out of our throttle bodies. They are pretty small as it is already. :? Very confusing
Old Dec 14, 2003 | 03:30 PM
its_ikon's Avatar
a throttle body should not cause a check engine light. i had my TB done at E.L. and it came out very nice.
Old Dec 15, 2003 | 01:52 AM
Wraith's Avatar
yes I have a Apexi S-AFC and I aslo have more aggressive injectors but they're still the same flow rate which is 200cc ... The spray pattern on the injectors are alot more aggressive than the stock ones...
Old Dec 15, 2003 | 05:50 AM
Guest
Guest
Posts: n/a
does anyone have the price or the website. I might want to check that out! :D
Old Dec 15, 2003 | 08:17 AM
Wraith's Avatar
Call Eric Lapka at 626-812-4358 Tell him Justin aka Wraith with the 3s-gte powered Camry sent you. Eric is the owner so he should give you a good deal on it ...
Old Jan 4, 2004 | 03:28 PM
DJ_SpaRky's Avatar
What is the Make & Model/prt number of these injectors?? Are there others that'll flow a little more, i.e. 210/220/250??
gedster314
14
Nov 17, 2018 02:56 PM
Threequalseven
Aug 26, 2015 04:24 PM
StxArOne
Jul 13, 2015 06:25 PM
rancur3p1c
Jul 12, 2015 07:59 PM
