Air Box Resonator mod - *Pic*
Old Aug 19, 2004 | 11:30 PM
JT_Scion's Avatar
Default Air Box Resonator mod - *Pic*
I realize this probably does absolutely nothing for performance. But i was getting the itch to do something.. anything AHHHH.. see its driving me crazy that i don't have any mods yet :D But i took off the resonator and plugged it up with a 1.5" cap i got at home depot. Sorry for the bad quality, i took the pic with my phone. I'm gonna go back and see if i can find a black one instead of yellow.
Old Aug 19, 2004 | 11:45 PM
aarontrini85's Avatar
what does this do?
Old Aug 19, 2004 | 11:48 PM
HellNBack's Avatar
Seems kind of pointless, does it change the intake sound any i.e. make it sound less hollow.
Old Aug 20, 2004 | 12:03 AM
JT_Scion's Avatar
Well resonators make the intake quieter, i took the top charcoal filter out of the airbox at the same time so yes it louder, and has a throaty sound to it now, but i did them both at the same time, and i'm sure removing the filter is the reason it got louder. But like i said i'm sure it didn't do anything, i just felt like taking it off.. hey.. less weight :D
Old Aug 20, 2004 | 12:08 AM
JasonH's Avatar
The resonator is there for a reason (and not just for sound.) They intake tract is tuned just like the manifolds and exhaust system. Mazda MX-3s have a similar chamber and removing it does nothing positive for the car, in fact, it usually messes up the idle a little. I would leave it as-is. Return your plug and save your money.
Old Aug 20, 2004 | 12:11 AM
Al-Truistic's Avatar
Quieter, really? Sounds not too bad? Would that work on any car, like my xB? Do you think it would help even if I have an aftermarket exhaust? Also, could that cap, or any other for that matter melt inside the engine bay like that?
For a low-cost mod I think it looks not too shabby...
Al.Truistic
aB
Old Aug 20, 2004 | 12:50 AM
JT_Scion's Avatar
Originally Posted by JasonH
.. in fact, it usually messes up the idle a little. I would leave it as-is.
That's kinda like saying you shouldn't get an aftermarket intake. I know you'll say .. well they tune those intakes properly.. but since i started the celica.net website, i got the blitz, aem, injen, and titan intakes from those distributors for my celica.. all of them produced a rougher than stock idle. If you think about it.. if you took the resonator off, and took the actual airbox off.. and hooked up a cone filter to the end, you'd have an aftermarket style intake. But like i said .. again.. the first line of my post was.. i know this probably doesn't nothing for performance. :D
Old Aug 20, 2004 | 03:55 PM
2200fire's Avatar
removing an intake resonator in my experience is always good. they are designed to make the exhaust quiter.
-so when it is removed- the dynamics of your intake a changed to more closely resemble a aftermarket intake (a straight pip with no extra branch offs)
if the idle is getting messed up on mx-3's i would assume that the resonator must be restrictin AIR FLOW big time, so when you take it off your A/F ratio changes to having much more air. THIS IS GOOD because now you can change your timing to add more fuel and that = more power :D
Old Aug 20, 2004 | 04:06 PM
JasonH's Avatar
Riiight.
Old Aug 20, 2004 | 04:10 PM
zoltiz's Avatar
N.G.S.O.
How tought was taking the charcoal filter off? AFAIK it's there only for smog/emissions reasons and looks pretty restrictive to me. Did you have to break off the clips that hold it or does it just snap out somehow?
Old Aug 21, 2004 | 06:02 AM
Sin's Avatar
Sin
Yeah, just break off the clips...I just used a screwdriver and poked through and pulled it out. After the main chunk is out, just use your fingers and pry the rest off that is attached to those clips.
DJ_FroZone
25
May 30, 2019 07:17 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
ninja_steph
Feb 5, 2015 02:50 AM
TheTripleC
Jan 4, 2015 06:46 PM
Godfryness
Jan 2, 2015 11:18 PM
