2013-2014 Engine Cover :(
Mine was completely pitted by whatever the dealer used to clean the engine. Replacing the value cover would have been too costly.
You don't have to replace it. Just take it off and go thorough the process of polishing it.
This video shows how lengthy of a process it is if you do it thoroughly....
This thread is on the 2nd gen xB showing you the results of stock to polished....https://www.scionlife.com/forums/sci...polish-200625/
You can even take it to a shop and have them powder coat it to whatever color you want without having to sand it down. It will look rough with the coating over it unless you sand it down first giving it the smooth look.
IMO I think this is far more impressive than using plastic covers cause then you can also change the hose colors and other stuff in the engine bay where it all shows your individuality instead of it all being hidden under plastic.
Found the Scion emblem on ebay, it's the same one as on your steering wheel. Had to grind down the Toyota "T" to get good adhesion with 3M tape.
Also header cover has been painted black since this picture was taken.
Guess I'm a little **** also.
Ok, finally after long search (in Canada is not easy to find a Camry engine covers, at least where I live), found my cover in eBay $50 + $40 shipping & import taxes (again , I'm in Canada). I just try to gave some "touch" with the red color on the letters & "Toyota" emblem. Excuse the pictures quality, but was taken with my crappy phone...
So I got one of the smaller ones from ebay, painted it white and stuck it on, but one problem.
I want to put in a strut brace and I don't know if I'll have the clearance. There's AEM, TRD, Tanabe, and DC but they all look like they want to sit really close to the motor..
Does anyone know if it'll clear?
airmankevin1
02-14-2018 01:23 PM
2fixA
33
07-30-2004 03:13 AM
