*LEDmod Daytime Running Light DRL for xB
Old 10-12-2011 | 11:00 PM
LEDmod's Avatar
Default *LEDmod Daytime Running Light DRL for xB
High Power Daytime Running Light for Scion xB 08 an UP
Benz style DRL
It's so much brighter than Benz Stock DRL, see the comparison below
You can see them clearly during daytime and seen from far away
Easy installation, just need to drill two hole and run any two wires to 12v power source (mine is tap to cig lighter, which make it turns on when ever car is on)
- Using 12 0.5 Watt High Power LED to make it daytime visible
- Powered by any 12v source
Direct order page here
Scion xB2 (11 and up)
Old 10-12-2011 | 11:05 PM
LEDmod's Avatar
We are looking for someone with 2011 Scion xB in So Cal area
To do test fit the DRL lights!!
Old 10-20-2011 | 02:07 AM
NUTS2U's Avatar
I have a 2011 XB. I work in Orange CA.
Old 10-20-2011 | 07:03 AM
LEDmod's Avatar
Let me know when you have about 1-2 hours to swing by my shop (it's located in Anaheim, CA)
Thanks..
Old 10-24-2011 | 08:47 PM
enonvator's Avatar
How much is it installed?
Old 10-24-2011 | 08:59 PM
LEDmod's Avatar
$100 installed with the parts.
I'll wire them, so it will turn on when ever car is on, so they will be on during daytime and night as long as car is on...
Old 10-25-2011 | 06:08 PM
TheotherBMan's Avatar
Has this happened yet?
Old 10-26-2011 | 05:50 PM
LEDmod's Avatar
Test fitting done, it will fit the 2011 model...
There are few differents ways to fit them..
If you are interested, let me know..
Old 10-26-2011 | 08:45 PM
magyver's Avatar
are these from something? I think it looks kinda weird that they don't fill the whole vent area. I think it would be cool if they were longer with a little curve to fit the area and make it look OEM...
Old 10-27-2011 | 01:57 AM
kingofthecrate's Avatar
I have a 2012 model with the TRD CAI if you are interested in modding into that since the grill insert is open vented for the CAI
Old 10-28-2011 | 01:24 AM
LEDmod's Avatar
It's not from anything. It's style based off Benz
So it won't be perfectly designed for xB
But it's close fit and doesn't require modification to stock parts then drilling two hole on the vent cover to mount.
Old 10-28-2011 | 01:25 AM
LEDmod's Avatar
If you have TRD cai, you can't put anything there cause is the vent.
Old 10-29-2011 | 12:43 AM
pyroman131's Avatar
I have a set of these that I have wired up. I'm just waiting for a good day so I can put it on my box.
Old 11-07-2011 | 05:17 AM
SamCarroll's Avatar
they look stick on. DNW
Old 11-26-2011 | 01:06 AM
NUTS2U's Avatar
I had these installed by Sean at LED Mod. I drove over during my lunch, and he installed them in about 1 1/2 hrs. Did an excellent job. He even installed an on/off button. They look great and are really bright. Highly recommend these lights, you will like them.
Old 11-27-2011 | 05:50 AM
KaneoheKoa's Avatar
I think they look good on a Benz, but on the xB, they look off balanced. A single straight row of LEDs probably would flow better with the vent profile.
Old 12-04-2011 | 12:17 AM
Gambit's Avatar
i did a custom install on my 2008 XB with these led driving light had to cut and modify them to fit but they came out pretty good. what do you guys think?
now i need to remember how to upload photos
Old 12-06-2011 | 08:42 AM
AUTO Design's Avatar
Pictures or it didnt happened
Old 12-06-2011 | 02:10 PM
Shadezz's Avatar
Easy just to post some pics peeps......11's + Pics
Old 02-10-2012 | 05:25 PM
LEDmod's Avatar
Here is the sample installed on the Scion xB2 (11 and up)
There are few different ways to install it, it's personal preference..
Quick Reply: *LEDmod Daytime Running Light DRL for xB
