Scion xD Drivetrain & Power Engine and transmission discussions...
xD oil change
Old 05-03-2008, 05:38 AM
tmrepp's Avatar
Drain Plug: Clean it and install it with a new gasket. Torque: 37 N*m (377kgf*cm, 27 ft.*lbf)
Oil Filter Cap Torque: 25 N*M (255kgf*cm, 18 ft.*lbf)
Capacities
with oil filter change: 4.4 US Quarts
without oil filter change: 4.1 US Quarts
dry fill: 5.0 US Quarts
tmrepp is offline
Old 05-05-2008, 10:07 PM
SpoonKiller's Avatar
Thanks for the torque specs.
I ended up taking it in because I was unable to remove the oil filter. My wrench just kept slipping off!
SpoonKiller is offline
Old 05-06-2008, 04:00 AM
SeattleGuy's Avatar
Somebody on this forum said this Sears tool fits the xD filter body.
http://www.sears.com/shc/s/p_10153_1...ord=oil+filter
Haven't tried myself tho.
SeattleGuy is offline
Old 05-07-2008, 12:21 AM
Yeah I'm gonna try that next time. The one I was using was labeled 65-67mm and I just couldn't get a good grip on the filter housing!
Old 05-13-2008, 06:12 PM
Mynam3isazia's Avatar
you know how many liter of oil do I have to put in I never done it before and the around here do not have the filter I I just order some
Mynam3isazia is offline
Old 05-14-2008, 06:39 PM
tmrepp's Avatar
with oil filter change: 4.2 liters (4.4 us quarts, 3.7 lmp. qts)
without oil filter change: 3.9 liters (4.1 US qts, 3.4 lmp. qts)
dry fill: 4.7 liters (5.0 US qts, 4.1 lmp qts)
tmrepp is offline
Old 05-14-2008, 07:12 PM
thank you I still learning I have to do it because the shop will not do it because my car is to low
Old 05-14-2008, 10:43 PM
tmrepp's Avatar
Did my first oil change tonight. Drained it out, and let it drip dry then filled it up with 5w20 royal purple synthetic. No problems getting anything apart, bought a 65mm end cap wrench from Advanced Autoparts for $4 and change. Only problem I had was getting the original metal gasket/washer off the drain plug. It sort of dry-welded on. I eventually grabbed it with a pair of channel locks and it popped right off.
tmrepp is offline
Old 05-28-2008, 08:24 PM
Garage1217's Avatar
Very good info guys I noticed the new cartridge when I had the car jacked up taking a look at things. Searching to see if pure 1 or wix has a cartridge available for it yet. Will let you all know asap.
Garage1217 is offline
Old 05-28-2008, 08:33 PM
Garage1217's Avatar
The filter part number for purolator will be L16311 but is not yet available to the public.
The Dana / Wix part number will be... Also not available yet.
http://www.wixfilters.com/filterlook...asp?Part=57064
k&n does not list a fiter as of yet.
Old 05-28-2008, 10:13 PM
Garage1217's Avatar
Last item, you can buy a 10 pack of oem filters from TRD sparks for $35.50! WOOHOO!
http://www.trdsparks.com/displaypart...&parts_id=2129
Old 05-29-2008, 02:23 AM
tmrepp's Avatar
...and why the heck didn't you just edit your post to include all this instead of making three separate posts? Odd. Thanks for the info though.
tmrepp is offline
Old 05-29-2008, 02:47 AM
Garage1217's Avatar
Because I was doing it from a phone, was faster to just make a new post, and besides that I felt like it whinebag
And to further help that vein pop out on your forehead, I also made a seperate thread about the cartridge filter itself Hope this does not destroy your perfect night *LOL*
https://www.scionlife.com/forums/viewtopic.php?t=224757
Old 05-29-2008, 03:27 AM
tmrepp's Avatar
Whinebag? Nah not at all. Being on a phone makes perfect sense. I do wish they made a mobile version of this site though, that'd be the ---- right there.
tmrepp is offline
Old 05-29-2008, 03:43 AM
Garage1217's Avatar
Just jabbing ya in the ribs a little No hard feelings
Old 05-29-2008, 05:51 AM
ChelsDS's Avatar
Man, so glad you got an xD haha.
ChelsDS is offline
Old 07-08-2008, 01:09 PM
gr8gran2aj's Avatar
Default maintenance required light
[quote="speedoguy"]
Originally Posted by Stupidhaole
Originally Posted by speedoguy
does anyone know how to reset the maintenance req light ? the instructions in the book are wrong
1. Trip A instead of ODO selected on the multi function display
2. Turn key to OFF position
3. Hold down button while turning it to ON position.
4. Trip A will go to zero and back to actual mileage after 5 seconds.
Thanks it worked like a charm. No more annoying maintenance required light. [/b]
gr8gran2aj is offline
Old 07-22-2008, 09:58 PM
SlvrBk's Avatar
Recently while changing my oil and filter late at night, I forgot I didn't have a tool to twist open the plastic filter cap, so I improvised and used a coilover wrench key. It took a few revolutions to loosen the cap for the first time, but it worked.
SlvrBk is offline
Old 02-05-2009, 01:04 AM
kuo34's Avatar
Used a 65 mm filter wrench from Advance Auto for the casing. Worked like a charm, though I spent a good bit of time bashing my knuckles against the oil pan trying to loosen the casing in a clockwise motion. Relatively painless once the gremlins of the oil change were worked out.
kuo34 is offline
Old 02-05-2009, 12:03 PM
DeathMachine's Avatar
Wix filter is out... I ordered one from O'Reilly Auto Parts where I work now... I don't have the part number but it is a special order item.
DeathMachine is offline
Quick Reply: xD oil change
