xB2 keyless entry door unlock programming
Mods, make this a sticky/tech FAQ? It seems some people did not receive a manual with their Security option.
For the "xA - Security with RKE" (Remote Keyless Entry)
I assume this is the same with xB, and possibly tC?
Programming
Driver's Door/All Doors Unlock Selection
The xA Security with RKE is factory-set to unlock the driver's door when the UNLOCK button is pressed on the remote control, then unlock the remaining doors when the UNLOCK button is pressed again within 3 seconds. You may change the programming so all doors will unlock at once when the UNLOCK button is pressed by following the steps below:
1. Before you begin: Open the driver's door. Remove the key from the ignition switch
2. Start the programming Procedure (Complete all these steps within 40 seconds)
A. Insert the key into and remove it from the ignition switch 2 times
B. Close, then open the driver's door 2 times
C. Insert the key into and remove it from the ignition switch 1 time
D. Close, then open the driver's door 2 times.
E. Insert the key into the ignition and leave it in.
F. Close the driver's door
G. Turn the key from LOCK to ON 4 times (ending at LOCK)
H. Remove the key from the ignition switch.
I. (Program mode Confirmation; you did everything correctly) The tail and marker lights flash 4 times, the buzzer chirps 4 times, and the doors lock and unlock 4 times
3. Select the operating mode and complete the programming procedure
A. Press and release both LOCK and UNLOCK buttons at the same time.
B. TO ENABLE ALL DOORS UNLOCK Press and release the UNLOCK button once for all doors unlock
OR
TO DISABLE FEATURE Press and release the LOCK button once for driver's door unlock only
C. The tail and marker lights flash 1time, the buzzer chirps 1 time, and the doors lock and unlock 1 time
Note: if the system lock the doors twice, start over.
E. Open the driver's door; programming is now complete
This took me 3-4 tries to do correctly. . . it DOES work.
Programming
OR
Originally Posted by xhrhx15x
i did mine with no problems. it is in the manual. nothing like the first post. hopefully that was posted to be funny.
Did you change your remote to open ALL DOORS with a SINGLE push of the remote???
IF, so, please tell us how, cause it's not in the manual how to unlock ALL DOORS with a single push of the remote..
tell us what YOU did & what got changed.. Thanks alot for your info.... thanks agian jh
Originally Posted by onemorescion
The auto lock from shifting into park is only capable on Automatic Trans.
According to page 11 of the owners manual, all 4 doors on the xB2 can be changed to unlock with 1 press of the unlock button on the remote, the instructions say "see your Scion dealer."
Originally Posted by Wil
I haven't searched it out yet, but does anyone know a way to turn off the chirp sound when you lock/unlock the doors with the key fob?
But that is besides the point. The point was to be able to DIY so one does not have to go to the dealer.
DelMarVa
Scion Tuners
For some reason, mine doesn't chirp when I press the lock in my fob, the doors lock, but doesn't chirp. It does however chirp when I unlock the doors.
I hear ya xb2, I put it in quotes because I agree about the DIY, and was being sarcastic.
When I sold Acuras it was an owner selectable feature, and really easy to change anytime you want.
