Center Dash Removal [xA]
Old Dec 9, 2004 | 06:30 AM
mikochu's Avatar
Default Center Dash Removal [xA]
In this tutorial, I will be showing how to take apart the center dash of the xA. This is helpful to xA owners who would like to change the EZ-Bake Oven bulb.
Tools needed:
Philips screwdriver
Flathead screwdriver
Duct Tape
I'm sure everyone who has tried to change their EZ-Bake Oven bulb, tried popping out this cover. In my experience, the cover does not come off easily...
To get to the compartments, we have to pop out the two pillars.
With the flathead screwdriver and duct tape, make a makeshift panel popper. Cut off a 4" piece of duct tape and fold it over the end of the flathead screw driver. I went ahead and put another layer of duct tape over the other piece...
Take your makeshift panel popper (flathead+duct tape) and wedge it under the pillar like so:
Be careful not to scratch your A/C Controls. Once you get the panel popper under it, slowly pop out the pillar.
At the bottom of the pillar, the fastener is angled. Make sure you have the pillar at around a 45 degree angle when you take it out. There's no science to it, but just be careful not to break the faster off.
Repeat the procedure with the other pillar.
As you can see, the compartments in the center dash are set up like a audio/server rack system.
To change the EZ-Bake Oven bulb, unscrew these 4 screws using a Philips screwdriver.
Make sure the compartment door is closed, then slide out the compartment.
You can totally disconnect the bulb assembly via the white plug. You can also just change the bulb by unscrewing the bulb holder and swapping out the bulb.
If you want to take the A/C control panel off, unscrew the two screws and pull from the bottom of the panel, upward.
FYI: The A/C control panel consists of the area A/C control panel, the two center A/C vents, as well as the frame around the headunit. There are also three wire harnesses connected to the A/C control panel that need to be unplugged in order to fully take the panel off.
If you have any questions, post it here, pm, or email me.
Old Dec 9, 2004 | 11:25 AM
matt_a's Avatar
That's what I needed to see...Thanks! Only one question. What kind of bulb is it and what does it look like? (bulb number would be great) I'd like to try to find a blue one and have it there when I take the car apart.
Old Dec 9, 2004 | 05:21 PM
Slyfx13's Avatar
Yeah, what type of bulb would work?
Old Dec 9, 2004 | 06:15 PM
mikochu's Avatar
The bulb size is 194 or 168. They both will fit.
Old Dec 9, 2004 | 06:20 PM
matt_a's Avatar
Thanks! Man I love this place. It's a wealth of knowledge. :D
Old Dec 9, 2004 | 06:27 PM
matt_a's Avatar
Hmm...I just looked up those two numbers, and they appear to be a "single ended bulb". See pic:
But the ownwers manual lists the storage box bulb as a 4.9watt "double ended". ????
Old Dec 9, 2004 | 07:26 PM
mikochu's Avatar
Take apart the dash and see for yourself. I doubt they changed it for the '05 xA. The only "double ended" bulb I know of are for the dome lights...Those are.. t-6?
Old Dec 10, 2004 | 01:34 AM
Epitrochoid's Avatar
Good info. I took this one step further...
I wired a switch into one of the blanks on the the dash.
I tapped the power from the blue plug under the consol on the floor where the shifter is. With the clip facing up the top left is Positive and the bottom left is Ground. The power to the "Oven" goes back to the switch.
Now the "Oven" turns on by a switch as long as the parking lights are on.
HTH
Old Dec 11, 2004 | 06:27 AM
Xcalibur1986's Avatar
So is the bulb 194 wedge end then?
Old Dec 11, 2004 | 06:20 PM
yeah, awesome, I just changed mine and it's incredibly better than orange. Thanks, guys
Old Dec 13, 2004 | 11:35 PM
kgzero's Avatar
Do any of you know if it would be possible to wire a switch to thos bulbs inorder to make it light up whenever the oven is opened? That would be cool.
Old Dec 16, 2004 | 07:02 PM
Sassyxa's Avatar
great how to... :D but i have tried to use the search to
remove the stereo can you help ?
Thanks Sassyxa
Old Feb 3, 2005 | 05:11 AM
lucas200400's Avatar
Default Bulb size
Well I found a bulb at monument. It's $3 for two bulbs but the size is NO. 194 and this paticular one is made by APC. So but in mine it works great at night that is.[/img]
Old Feb 11, 2005 | 03:45 AM
jct's Avatar
jct
i put a 194 blue bulb cover on mine easy bake oven bulb
Old Feb 17, 2005 | 08:33 PM
jct's Avatar
jct
a better way to get the trim paneling off is with a strong plastic putty knife like around a 1.5" wide
found out that a screw driver with duct tape on it still mar's up the plastic
plastic putty knife works lot better
Old Mar 13, 2005 | 04:08 PM
PhillyMJS's Avatar
Default Which variety of #194 bulb for oven & AC control light?
There are quite a few different kinds of 194 bulbs offered here.
I figure the white "matrix" bulbs will do for the parking lights, so that's no problem.
I also want to replace the bulb in the oven and the bulbs behind the HVAC controls with blue ones, but I'm not 100% sure which kind to get. Based on what I've seen in the take-apart pictures, I think the "opaque focused" 194 would be good for the oven. I want the HVAC control illumination to be as bright as possible, though, and can't tell exactly how the light is diffused. Anyone who has done this mod know which of the bulbs on the page above would be the best? I'm trying to avoid taking the console apart before I actually have the stuff to do the mod, and without having to buy a couple different kinds of bulbs and do trial and error to see what's the brightest.
TIA,
~Philly
Old Jun 24, 2005 | 07:07 PM
lalagimp's Avatar
Did anyone ever come up with a remedy for this?? I've been searching for a collective two hours to see if someone had posted it
Old Jul 16, 2005 | 08:39 PM
DOHCtorJT's Avatar
If you open the "oven" door first, you can easily pry off the silver side pieces without the use of a tool. Open the door, and you'll feel a bit of a lip at the side where the trim meets the oven. Just use your fingers, and that should get it out far enough so you could grab the top of the trim and remove it that way.
Old Jul 19, 2005 | 01:12 PM
dirtygreek's Avatar
phew - I'm glad I found this! I keep seeing threads for the tc that say the easy bake oven uses #74 bulbs. I guess the xA uses 194...
Old Jul 20, 2005 | 01:29 AM
uber-xA-RS2's Avatar
I must be stronger that I thought, I needed to take these off today to install the Scion Security and I just pulled them off.
