Scionlife.com Scion Enthusiast Community
Go Back   Scionlife.com » Scion xB 1st Gen » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Drivetrain & Power
Register Search Today's Posts Mark Forums Read Vendors
Reply
Old 12-25-2004, 09:51 PM   #1
Kong
Kong
View this user's Polar White xB
Default Voltage Stabilizer DIY/Installation
Hi everyone,
Here is the instruction of how to make a voltage stabilizer for our cars. Although it has many names such as hypervoltage system, ground or volt stabilizer, they are all the same. Their prices range from $60-$220, but you can do it yourself for less than $40. . Personally, I don't know exactly what is inside the box. So what I describe below is based on my knowledge as an electrical engineer.
The voltage stabilizer is used as a filter and a secondary voltage storage for your car. Although the battery itself acts as a large capacitor, it doesn't respond to all current fluxuation in your car. Voltage stabilizer help supplying or absorbing transient current so that electrical inteference is suppressed and more energy from the alternator is stored.
As a result, the engine will run smoother and quiter. Its throttle response will improve. You also get more miles from your gas.
It consists of capacitors connected in parallel. High capacitor value should be use to maximize the filtering effect. Both electrolyict and ceramic capacitors should be use to cover broad frequency range. For battery protection, I add a 3-5A fuse. You can dress it up with some LED lights, but it will just drain up your battery a bit.
Here is the part list:
1. 3-foot 4 or 8AWG wire and 2 ring terminals
2. Plastic enclosure
3. 4 16V Electrolytic capacitors
4. 4 16V Ceramic capacitors
5. a fuse and a fuse holder
6. 2-side sticky tape
7. pre-drilled PCB board
First, Cut the wire and connect each wire with a ring terminal. Then drill 2 holes on the plastic box. Align capacitors in parallel on the PCB board and solder them. Be aware that the electrolytic capacitors have polarity. You should connect all the capacitor's negative terminals to the same point of the PCB board and similary for the positive terminal as shown in the schematic.
This is what inside the box. wires, PCB, CAPs, a fuse and a fuse holder:
Zoom in image of the caps
Then connect one of the fuse holder port to the positive terminal of the capacitors. Insert the positive wire though the box and solder it the PCB board at the other end of the fuse holder. Afterthat, insert the negative wire though the box and solder it the PCB board. Close the box's lid and your voltage stabilizer will look some thing like this:
http://www.scionlife.com/gallery/sho...sort=4&cat=500
Installation: Just connect its + terminal to the + battery terminal and then connect - terminal to the - battery terminal. You will see some spark :twisted: . It would be best to charge the unit with a power supply before you hook it up to the battery. I stick my voltage stabilizer on top of the fuse box using a piece of sticky tape. The ECU needs about 1-2 days to adjust itself once you install the your voltage stabilizer, but you should see some improvement immediately.
The system should last for at least 3-5 years.
IMPORTANT NOTE! improper connections may cause the fuse to break or it may drain your car's battery. Good luck!
Kong is offline   Reply With Quote
Old 12-25-2004, 11:23 PM   #2
squirrel
squirrel 110/M
View this user's Thunder Cloud Metallic xB
Mike (Mikochu), please put this in the Tech section!
squirrel is offline   Reply With Quote
Old 12-26-2004, 03:21 AM   #3
timinaz
timinaz 53/M
View this user's Black Cherry Pearl xB
Send a message via ICQ to timinaz Send a message via AIM to timinaz Send a message via MSN to timinaz Send a message via Yahoo to timinaz
Another Mad Mike creation I'll have to try!
Mods- Injen Short Ram Air Intake, Megan Headers, Strup Exhaust, Tein S Tech Springs, Scion FX Strut Bar, Randode Short Shifter, OBX Pedals, Shaved emblems, CF Spoiler, TYC Taillights, Halo Projector Headlights, Silverstar bulbs, OEM Billet Grille, Rear Bumper Applique, Mikochu's mad grounding mod, AEM Billet Oil cap and Battery Tie-down
timinaz is offline   Reply With Quote
Old 12-26-2004, 04:07 AM   #4
hotbox05
hotbox05 25/M
View this user's Sky Blue Pearl Camry
View this user's Impulse Red Pearl Corolla
View this user's Impulse Red Pearl Tacoma
View this user's Custom Color Truck
View this user's Blue Onyx Pearl xB
View this user's Garnet Red Pearl 4Runner
View this user's Black Metallic Supra
Send a message via AIM to hotbox05 Send a message via MSN to hotbox05 Send a message via Yahoo to hotbox05
man i need some better pics of how it is all connected to the board. i'm pretty sure id fry somethin or just make a really crappy looking plastic crap box.
hotbox05 is offline   Reply With Quote
Old 12-26-2004, 05:28 AM   #5
Kong
Kong
The stuff inside doesn't look that pretty to show, that what the plastic box is for . Anyway, make sure that the wiring for the positive terminal is not connected to the wiring of th neganative both inside or outside of the box and you won't fry anything .
Old 12-26-2004, 06:33 AM   #6
hotbox05
hotbox05 25/M
no i wanna see the wiring in and out of the capacitors.
Old 12-26-2004, 09:57 PM   #7
George
George's Avatar
George 110/M
OK, I'm not a electrical engineer, but I would love to know what current four little electrolytic capacitors can supply that a full-size lead-acid starting battery cannot. I wasn't aware of any great current time-lag, or internal resistance losses in such a battery.
Now, I can see the advantage of a capacitor on the far end of a long wire run next to a device (like an audio amp) that has transient high current needs. It fills in the voltage drop caused by drawing large currents through the wire. Next to the battery, this advantage seems to be lost.
Also, wouldn't it be easier to use one larger capacitor instead of several smaller caps in parallel? I note that you didn't specify a value for the caps except for a voltage. 16V seems me to be cutting it a bit close on a system running ~14V. 25V would be safer,
I've seen these devices built for the Japanese market, housed in transparent boxes showing off the row of electrolytics, but frankly it seems like nicely-packaged snake oil to me.
George is offline   Reply With Quote
Old 12-26-2004, 10:06 PM   #8
hotbox05
hotbox05 25/M
this may be . i wanna see some company with any type of this get individually dynoed and un-biased tests with cars other than the owners ones
Old 12-27-2004, 02:15 AM   #9
Kong
Kong
It only help supplying transient current for less than <100ms, you will not notice it, but the computer will. It mostly acts as a filter. In electronic stuff, steady power supply in very important. Ripple in power supply also cause instability in some amplifier (I mean sensor stuffs, not audio). Let's say.. it makes a better environment for electronic systems to operate.
Yes, and No. Typicall, a large cap has smaller ESR (equivalent series resistance) and has higher ripple current, which is good . It is bulkly and difficult to package. It's frequency response is limited. Also, its price (capacity/$) is more expensive than the small capacitor.
I use 16V caps because I can get higher capacitor values. It is more compact and cheaper ;) . Yes, the battery is running at 14V and It won't go above that, unless there is something wrong with the alternator and the battery will be damaged anyway. I was first thinking about using the 25V caps, then I find justifications to use the 16V caps instead. The capacitor can withstand voltage ripple of more than 16V, but it cannot withstand "steady" voltage of more than 16V, so it should be safe.
The main reason I make this myself is that I want to know if it works without spending too much money on it.
Old 12-27-2004, 06:17 AM   #10
jct
jct's Avatar
jct 70/M
can we see a visual picture of the insides pls
Apathy, it works hard for you!!!
jct is offline   Reply With Quote
Old 12-27-2004, 02:07 PM   #11
Kong
Kong
I'm too lazy right now to take of its lid and take a picture in the cold weather . Anyway, I will post the picture of the inside.
Old 03-09-2005, 06:33 PM   #12
mikochu
mikochu's Avatar
mikochu 26/M
View this user's Polar White xA
I'll "FAQtify" this thread once a more thorough tutorial is made...either by Kong, myself, or someone else. For now, it will be sticky'd.
Michael Reyes
www.mikochu.com
2009 Honda Civic Si Sedan Crystal Black Pearl [6spd]
2002 Honda 919 Asphalt [6spd] (more info)
2004 Scion xA Polar White [5spd] (more info)
google it.
mikochu is offline   Reply With Quote
Old 03-10-2005, 11:04 PM   #13
Kong
Kong
Sorry guys, I totally forgot to take a photo inside the voltage stabilizer box. I'll do it this week end.
Old 03-10-2005, 11:21 PM   #14
jct
jct's Avatar
jct 70/M
not this weekend do it now, lol
your so lazy
Old 03-10-2005, 11:31 PM   #15
superfreestyle
DeepSouth Scions
superfreestyle 23/M
View this user's Custom Color Corolla
View this user's Custom Color Corolla Coupe
View this user's White MR2
View this user's Black Onyx MR2
View this user's Blue Metallic Celica
View this user's Medium Gray Metallic Corolla Coupe
View this user's Silver Metallic Corolla Coupe
View this user's Black Onyx Supra
View this user's White Truck
View this user's Camouflage Metallic xB
Send a message via AIM to superfreestyle Send a message via MSN to superfreestyle Send a message via Yahoo to superfreestyle
superfreestyle is offline   Reply With Quote
Old 03-10-2005, 11:52 PM   #16
Lonely_Raven
Lonely_Raven's Avatar
Lonely_Raven
Send a message via ICQ to Lonely_Raven Send a message via AIM to Lonely_Raven Send a message via MSN to Lonely_Raven
They sell something like this on EBay and I couldn't imagine
what it was, though I do understand basic electronics.
Thanks for your description Kong. Seeing as how I'm teaching
myself to build Vacuum Tube Guitar amps, your ripple filter
makes much more sense now. All you need is a spiffy chrome
box to put it in!
The Lonely Raven
Jack of all Trades,
Master of None
Lonely_Raven is offline   Reply With Quote
Old 03-11-2005, 10:48 PM   #17
jct
jct's Avatar
jct 70/M
just a surrealistic idear
make a voltage stablizer out of the vacuum tubes boy that would be so OLD school!!!
Old 03-11-2005, 11:26 PM   #18
Kong
Kong
As promised, I have taken some photos and added to thread above. Now you see what are inside.
If you have any question about how to make it, feel free to PM me.
Happy moding
Old 03-17-2005, 01:40 AM   #19
jct
jct's Avatar
jct 70/M
where the 4 16V Ceramic capacitors at???
and from your pic on your car it looks like its hooked up stright to your pos. and neg. terminals, is that right???
Old 03-18-2005, 02:20 AM   #20
Kong
Kong
They are one the other side of the PCB. Each one is connected between the electrolytic cap terminal.
Reply
Tags
automotive, build, car, cars, diy, grounding, install, make, recipe, schematic, stabalizer, stabiliser, stabilizer, volt, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin® v3.7.5, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
