The COMPREHENSIVE thread on NST (NonStopTuning) Pulleys
Old 01-23-2009, 08:57 PM
NonStopTuning's Avatar
Default The COMPREHENSIVE thread on NST (NonStopTuning) Pulleys
It looks like we have threads popping up constantly with questions regarding pulleys.
So I decided to take some time to try and put up a good thread in which we can cover most of the topics that normally come up, FAQs, along with user reviews and data. This last bit (user reviews and data) I feel are most important... so pulley owners, PLEASE take a few minutes out of your very busy days and post your experiences with us in this thread. I am very confident that your fellow board members will find your reviews very very helpful.
First, I will post some general info regarding NST Pulleys, how they work, and why they help to free up power and torque.
Second, I will list some FAQs that have come up in past threads with info and answers.
Third, it is your job pulley owners, to post your first hand experiences, comments, and data with us.
Most of this data can also be found on our website, www.NonStopTuning.com, but I will post some of it here for your viewing pleasure!
NonStopTuning is offline
Old 01-23-2009, 08:59 PM
Think of it this way, underdrive means to slow down. Underdrive crank pulleys found at NonStopTuning are designed to slow down engine accessories and reduce parasitic loss.
Crank pulleys, attached to the outside of the crankshaft, are the source of power for a car's accessories. The alternator, power steering, water pump, and air conditioner are all belt driven units, attached to the crank pulley, that use horsepower from an engine to provide their own services. This draw of power by these accessories is called parasitic loss. NST Underdrive Crank Pulleys increase an engine's horsepower by reducing the power required to drive these external accessories. By replacing factory pulleys with CAREFULLY RESIZED units, some of the accessories are slowed enough so that their performance DOES NOT suffer, but just enough so that more horsepower is sent to the wheels and put to the ground. Where horsepower should be!
The R&D team at NST is dedicated to developing kits that provide great gains for track days and continue to deliver proper accessory output for everyday street use.
NST equipped cars do better on the track, benefit from increased accessory life on the street, and also deliver better mile-per-gallon fuel efficiency.
NST was the first company to design and develop pulleys for the Scion tC, and now offers more for the tC than all of our competition combined. We offer the most comprehensive line of pulleys for these cars, and we also have the ability to build custom pulleys for any custom application. NST offers more than 100 different pulleys for Honda, Nissan, Toyota, Lotus, Volkwagen, etc on www. NonStopTuning .com. When you buy from NST, you are buying from the leader in sport compact pulley development.
Old 01-23-2009, 09:04 PM
1. Will I need to buy a new belt if I am using NST Pulleys?
A. The NST Underdrive Crank Pulley, NST02020, does require the use of a resized belt. We offer GATES belts on our website. We also list these universal belt numbers, you can look for the correct belt number and take this number to your local AutoZone, PepBoys, Advanced, etc. if you prefer to buy your belt locally.
A. The NST CR-Lite Crank Pulley, NST02148, is specifically designed for use with the OEM belt. You can use your OEM belt as long as you have a good, healthy, belt. Please remember that all belts are normal wear and tear items and should be replaced at roughly 50,000 miles.
2. Will/should NST Pulleys lead to any squeaking or noise from the belt?
A. A properly installed kit, along with the porper belt size, and a healthy belt, should NOT lead to any noise. Belts should be inspected from time to time and replaced at proper intervals. Belts should not be sprayed or cleaned with any chemicals. Dust or debry can be cleaned with a brush or a can of air.
3. Do NST Pulleys actually add HP/TQ?
A. NST Pulleys do not technically add power, they free up the power that the engine makes by way of great weight reduction and the slight underdriving of the accessories. The great weight reduction leads to improved HP and TQ curves in the low, mid, and high range... this is something very few bolt on modifications can do. These pulleys also improve throttle response and fuel economy, both of which can not be measured on a dyno but can definitely be seen on the road, or track.
4. Are there any independent dyno charts available to prove these claims?
A. Yes, there are several sources of independent dyno charts for NST Pulleys. Viewers should be careful to look for AREA UNDER THE CURVE when looking at these dyno charts. You can see improvements in low, mid, and high range HP and TQ. This is something most other bolt on modifications can not do...
SAMPLE: Import Tuner Power Pages. September 2008 issue. Civic Si K20 Kit.
http://www.importtuner.com/powerpage...ulley_set.html
5. Can NST Pulleys cause my engine to run lean?
A. The above pulleys can not, in any way, change the air/fuel ratio of a naturally aspirated or turbocharged engine... as pulleys have nothing to do with the flow of air, exhaust, or fuel. ECU reflashes, intakes, exhausts, or header systems are what normally affect air/fuel ratios.
6. Can I use the 20% Underdrive Crank Pulley on my TRD supercharged tC?
A. The NST Underdrive Crank Pulley, NST02020, is designed for use with any naturally aspirated or turbocharged application. Underdriving (slowing down) a supercharger is not ideal, because a supercharger is basically a pump driven by a belt that is attached to the crank pulley. An underdrive crank pulley would lead to less boost. We have designed what we call the CR-Lite Crank Pulley, NST02148, for you TRD SC owners. You can add our Alternator Pulley & Water Pump Pulleys, for further weight reduction and better overall alternator output at idle.
7. What colors do you offer?
A. All NST Pulleys are HARD ANODIZED. This is the most durable method of anodizing in the industry, and very few brands are actually hard anodized. This process adds a hard layer to the outside of the aluminum and helps to make the pulley as durable as possible. We currently offer Red and Graphite Gray anodized pulleys.
8. How hard is installation? Can you provide tips or a DIY guide?
A. Installation should not be too difficult if you have previous experience with wrenching on your car. Chances are if you did your own intake, header, or exhaust, that you should be able to tackle this in a couple hours with the proper tools.
Ofcourse if you are the least bit hesitant, or uncomfortable with trying this yourself, you should seek the assistance of a trained professional. NST can not be held responsible in any way, shape, or form for any damage due to improper installation. DIY installations are performed entirely at the risk of you, the end user.
More to come soon...
Old 01-23-2009, 09:07 PM
This one deserves an entire book, but here goes...
Q. Will NST Pulleys lead to premature engine failure?
I cover this topic at least several times a month but I don't mind, I understand that your cars are a very large investment for all of you and I prefer that you be intelligent and informed about all your modifications. So here we go again... Please take a few minutes to read everything I have posted here, as I worked hard on trying to give you a good explanation on the topic...
In the past many engines were externally balanced. There was an external balancer attached to the outside of the engine, on the crank snout, used to balance the engine externally. The crank pulley in such engines would then be attached to this balancer. Removal of this balancer is a bad idea. These balancers were most often used on large (6 to V shaped engines of the domestic muscle car era.
Take a look at any modern (1980s and beyond) Honda, Toyota, Nissan, or other japanese inline 4 and you will find no such balancer. These engines are all internally balanced, and this process has improved even further since the late 1990s. So the topic of a BALANCER does not apply here.
What you will find on many modern engines is a harmonic damper. This is a small rubber band, litterally less than 2mm, less than 1/8th of an inch, thick that is built into the crank pulley. OEM crank pulleys are often called DAMPERS. Try placing an order for a crank pulley at your dealer and your invoice will read damper. This rubber is used to absorb something called NVH, noise/vibration/harshness. Suffice it to say, this rubber is actually not very good at performing its intended purpose after as little as a few thousand miles. What happens to rubber after a couple years of humidity, weather, snow, rain, etc? It often becomes brittle, hard, and crunchy. Can something with these properties actually absorb vibrations very well?
Many many NST customers, including people on your own forums, have reported smoother running engines with NST pulleys. Especially at idle. How is this possible if the rubber is such a vital and super important piece??? Perhaps the rubber is not as important as it is cracked up to be???
Furthermore....
On the topic of the rubber damper, engine vibrations, or possible threats resulting from elimination of this rubber piece...
On a relatively understressed near stock motor with bolt ons or low amounts of boost like what most of the people on this forum probably run, a solid pulley will not have any life threatening consiquences. The factory pulley with a 2mm (less than a 1/8th inch) damper is primarily there for wide band NVH (noise vibration harshness) supression from the engine and driveline. Removing the damper and replacing it with a solid pulley may lead to minor addtional NVH but will not harm the engine. In fact, most people claim their engines seem to run smoother with NST pulleys.
The engineering reasons are that most modern engines have a short, strong crank with, a relatively high natural frequency. The dangerous second harmonic that can cause damage occurs at an rpm that this sort of engine will never see, in the area above 10,000 rpm. Even the stock damper is not tuned for attinuation at this sort of rpm so the argument is somewhat of a moot point.
Now weak engines that are pushing the limit with LOTS of revs, wimpy cranks, super long strokes, lots of boost and dwelling in the upper rpm ranges for long periods of time can benefit from a damper designed to deal with this sort of operation but our engine is not like this, and probably very few people with this motor on this forum push the envelope that hard. How many 2.0 Liter, 500HP, 12,000RPM motors do we have on these forums?
As far as I can tell, our engine has a strong and stiff bottom end that is well built for our intended use. It has an internaly balanced crankshaft which is less like to break due to torsional vibration.
There are a lot of Honda, Toyota, and Nissan guys who use underdrive crank pulleys in road racing series like NASA or SCCA. Road racing is much more punishing on an engine than other motorsports. The engine is subjected to run times lasting roughly 30 minutes with the engine always in the upper ranges of its rpm limit. One race weekend is the equivlent of hundreds of 1/4 mile passes. These guys would not use NST pulleys if they were not reliable.
NST sponsors the first ever wheel to wheel Scion tC NASA Road Race car. The same car is also very competitive in the Grand Am series and has factory backing from Toyota, Scion, and TRD. This car has been using pulleys from NST with great results since day one.
NST has sponsored several drift cars participating in the professional US drift series, Fromula Drift. Several of our cars have also competed in the NOPI Drift series. To make things better, NST products are also used in autocross, time attack, and drag cars. These cars have been using NST pulleys with no issues of any kind for the past few seasons.
We could go on and on...
Is a solid crank pulley harmless to all engines? No it is not. As I said... small, super high reving engines, when modified way past the simple bolt on stages may have problems. These engines reach critcal harmonics, past the 10,000 rpm range, an rpm only reached by certain RACE engines.
A mildly modded inline six will most likely be fine but one subjected to high rpm for long periods of time (90% of its life) with lots of boost will probably suffer. In this case , the stock balancer/damper is probably not adequate either.
Some of the older american V8 engines are externaly balanced and it is critical not to use a solid hub pulley not designed for these applications, or damage to the engine could result. You will not find solid NST pulleys on our website for such engines.
Our engines and most around here do not fall into the above catagories. Rest assured that your engines will not blow up and die or have a reduced life in street and even racing use with these parts.
I would bet that every "expert" that tells you otherwise has little personal, practical, real world experience with the subject; as it applies in your case.
Again, I understand that your cars are a very large investment and that you depend on them as your daily means of transportation, so I do not take your questions personally. But please remember... No NST product is designed to cause you any harm or grief. We are not in business to sell junk. PERIOD.
Old 01-23-2009, 09:14 PM
Those of you who own NST Pulleys, please be sure to take a few minutes to share your reviews with us in this thread. I'm sure your fellow board members will enjoy reading your first-hand reviews, as will we.
Those of you considering NST Pulleys, feel free to post your questions and comments here as well. I would be happy to answer them as best as I can.
Old 01-23-2009, 10:17 PM
And finally, another ScionLife thread that I feel should be linked to here...
https://www.scionlife.com/forums/viewtopic.php?t=122725
Thanks again everyone, good luck and have fun with all your projects!
Old 01-23-2009, 11:24 PM
justin6969's Avatar
ive been looking up info and feedback on these pulleys seem to be great quality and i will be buying a full NST kit asap bump for NST
justin6969 is offline
Old 01-24-2009, 01:05 AM
crush02342002's Avatar
i havnt used nst pulleys "yet" (maybe soon if money permits..lol) but iv used the unorthodox underdrive crank pulley on my 97 nissan altima and never had an issue. as a matter of fact the reason i put an uderdrive pulley on it was cause the stock crank pulley cracked and tore the crap out of my oil pump seal, not to mention it was CHEAPER THAN THE STOCK ONE....lol
long story short i would put an uderdrive pulley on my ride anyday as long as its of high quality like nst.
crush02342002 is offline
Old 01-24-2009, 02:07 AM
gicode0823's Avatar
Im thinking about getting these soon...
but i dont know which combo should I go with ...
and I have NO TOOLS lol
plus i need something to install S/C pulley ... dont want to take to dealer for that ... lol
I love NST ...
bump for you mike !
gicode0823 is offline
Old 01-24-2009, 02:37 AM
BZinn1's Avatar
The gains felt using these on the tC area incredable,but you should try them on a xA or 1st gen xB or Yaris......my goodness it is like a whole new car......they also really seem to clean up any slugishness on automatics.
BZinn1 is offline
Old 01-26-2009, 02:42 AM
Thank you for the kind words and the feedback so far everyone.
Please keep the feedback coming
Old 01-26-2009, 06:44 PM
My07Tc's Avatar
I have had the NST light weight underdrive pulley on my car for more the 20,000. I have never had a problem. I just recently add the water and alternater. I have put about 5000 miles and no trouble. I highly recommend any scion owner to get these pulleys. Keep up the good work Mike!!
My07Tc is offline
Old 01-27-2009, 05:49 AM
Thank you for the kind words, we certainly do appreciate it!
Old 01-27-2009, 01:24 PM
xdejablu3x's Avatar
man...makes me one to get some now for my N/A setup!
xdejablu3x is offline
Old 01-27-2009, 05:34 PM
The NST crank pulley is one of the best bang for buck mods for the tC!
What other $100 mod can give you 5+ hp and tq accross the entire rpm band, better throttle response, and better fuel economy all at the same time?
Old 01-27-2009, 05:43 PM
1UP Crew
ippskidder's Avatar
I have the 3-pulley underdrive set from NST.
I've had it installed for more than 50k miles, with zero problems thus far.
Of those, about 30k miles are boosted.
I would definitely buy these pulleys for my next car.
ippskidder is offline
Old 01-27-2009, 11:02 PM
Thank you for the kind words ippskidder, we certainly do appreciate the support of our brand and products!
Be sure to look us up if you ever buy another car
Old 01-30-2009, 06:38 AM
Anyone else want to chime in with reviews/thoughts/comments?
Old 01-31-2009, 02:06 AM
raamaudio's Avatar
I firmly believe these to be of superior quality, value and will not harm your engine one bit. I have the crank and WP and have used all the different SC sizes, no issues at all on my TA TC. I am going to continue running them on my fully built turbo setup as well
Rick
raamaudio is offline
Old 02-01-2009, 01:50 AM
Otechhh's Avatar
Default I own an H.O.B Aluminum Crank Pulley
I own an H.O.B Crank Pulley, I wanna know if i should replace it. Please tell me.
Otechhh is offline
Quick Reply: The COMPREHENSIVE thread on NST (NonStopTuning) Pulleys
