DIY: Load Resistors for LED Turn Signals
Old 01-21-2010, 08:39 AM
greenguyshrek's Avatar
Default DIY: Load Resistors for LED Turn Signals
I personally installed the dual changing amber/white turn signal LEDs from Performance HID and had the problem of rapid blinking when the turn signal was activated. Its like the blinker is having a epileptic seizure.
So the solution is to use a load resistor to simulate the approximate load that a regular incandescent bulb would put on the car.
This method is a lot cheaper then buying the relay which is $16
(I personally got mine at radioshack 10 ohm wirewound resistors - 10 watt - about $2.25 comes in a pair)
Part #
What it looks like. (I cut it down cause it's too long)
So this is pretty straight forward, find the easiest way to access the wires for the turn signal bulb on your car.
To make it work you need to do is connect one side of the resister to the Turn Signal Power and the other to the ground. It dose not matter which side is connected on the resistor.
Cut and splice open the green Power like so:
Then use a connector on one side put one end of the power wire and at the other end put the resistor and the power wire together. Should look like this:
Now cut and splice open the white ground wire.
Do the same thing as the power wire using a connector. Make sure to cut the wire the same size as the resistor.
The wires should look like this when its all connected up.
Wrap it up with electrical tape to make everything sealed and water tight as possible
Here is a video on the difference.
YouTube - LED Blinker
greenguyshrek is offline
Old 01-21-2010, 09:12 AM
Tom11x's Avatar
nice diy
Tom11x is offline
Old 01-21-2010, 09:04 PM
Originally Posted by Tom11x
nice diy
Thanks hope this helps.
Old 01-22-2010, 02:07 AM
Zman's Avatar
Looks awesome. What LED bulb did you get? Is it legal to blink white and yellow?
You do some of the best DIYs btw.
Zman is offline
Old 01-22-2010, 02:20 AM
gingles's Avatar
butt splices=fail.
solder and heat shrink though=win
gingles is offline
Old 01-22-2010, 07:09 PM
What Ive been told buy the CHP is that you can have white but you also have to have the amber reflector.
This is were you can get the bulb:
http://www.v-leds.com/Exterior-LED/T...51397-1-2.html
Originally Posted by gingles
butt splices=fail.
I know I just need to learn how and get the soldering tool.
Old 01-22-2010, 07:56 PM
gingles's Avatar
soldering is like sex...take a second to get warmed up but once you are things start coming together. with soldering i say go to walmart or radio shack and but a 15w soldering iron along with a base and sponge.....let the iron heat up, whip it on the wet sponge to get any residue off, put a little solder on the iron, apply the soldering iron to the wire to heat the wire up and then apply the solder to the wires and or wire. its really really simple, just takes some practice.
gingles is offline
Old 01-25-2010, 07:46 PM
Zman's Avatar
Butt connectors aren't that bad.
Nice LED, pretty expensive though.
Zman is offline
Old 01-26-2010, 02:05 AM
Ya but a dealer I know should be getting them soon for like half of there price
Old 02-01-2010, 02:09 AM
SEXB909's Avatar
Whooooo love ya Shrek dizzle. Just for the plug, come by the pad before I leave so I can lace up Peggy's ride. Very nice write up and I shot a copy over to the boss.
SEXB909 is offline
Old 02-01-2010, 05:25 AM
You got it big dog
I'll bring the tc when I can
Old 02-01-2010, 06:54 AM
scyon's Avatar
nice job love it for sure
scyon is offline
Old 02-01-2010, 01:24 PM
Music City Scions
bB2NER's Avatar
Wouldn't buying an electronic flasher relay work better than cutting your harness? Plug and play baby for around 10-15 bucks.
bB2NER is offline
Old 02-01-2010, 04:53 PM
Why thank you
Yes there is a relay and it is $14 but with that relay you lose the flashing light when you lock and unlock your car
Old 02-04-2010, 05:40 PM
DJ_FroZone's Avatar
This is amazing. i just wish those bulbs weren't so expensive. anybody know of a lower end version? (or a discount code haha)
DJ_FroZone is offline
Old 02-04-2010, 06:01 PM
VVTiMovesMe's Avatar
that looks awesome!
nice diy and i like the seizure one better
VVTiMovesMe is offline
Old 02-04-2010, 09:06 PM
PerformanceHID's should be getting a shipment of these in soon. I got the last set. I know they will be selling them for like half of the other company's price.
Originally Posted by VVTiMovesMe
that looks awesome!
The seizure ones are cool but the blinking noise just gets annoying in the car. Plus you really cant tell that they change from White to amber.
Old 02-04-2010, 11:41 PM
DJ_FroZone's Avatar
maybe make a thread for him (or point me to his) so i can get on that when he drops that price.
Old 02-05-2010, 10:35 AM
Will do, but If you need any other lights, HID's or LED's his username is SEXB909
his name is Kirby and he is in charge of Performance Hid's.
Old 02-10-2010, 07:17 PM
llblutigerll's Avatar
would this work on the tc for the front turn signals?
llblutigerll is offline
Quick Reply: DIY: Load Resistors for LED Turn Signals
