Installed Head Unit... Antennae not so good
Old Feb 9, 2010 | 04:05 AM
mr929dblR's Avatar
Default Installed Head Unit... Antennae not so good
Ok so i need a little help. I installed a head unit (sony xplod) into my 05 tc. everything works, FM, CD, etc... The only thing is the antennae is crap. I can only really pick up 2 stations and whenever i move close to the HU the signal weakens or gets strong depending on where i touch, almost as if using me as an antennae.
i tried to connect the blue Antennae wire on the HU to the blue antennae wire on the harness, no luck. I plugged the tc's antennae cable into the hu and still crappy reception. Currently i have the 2 blue wires disconnected and the HU's and the Tc's antennae cable (black cable with metal prong) taped toegther with electrical tape. This seems to be ok depending on the position of the wires BUT i can only get two stations.
Any help on why the antennae doesnt work or what i may have done wrong? This is my first HU install, it was simple minus the stupid antenna issue.
Please help me out here.
Thanks,
Old Feb 9, 2010 | 04:30 AM
SquallLHeart's Avatar
make sure to hook up the power antenna wire.
Old Feb 10, 2010 | 03:51 AM
mattieg's Avatar
Well the power antenna wire is for the amp turn on. It is possible that you have a bad radio.
Do you have HID's or anything else installed in the car?
Old Feb 10, 2010 | 04:06 AM
the vehicle does actually have an antenna amplifier which needs power to actually work.
i doubt anything is wrong with the antenna itself.. more likely it is either the headunit, or the install.
Old Mar 19, 2010 | 09:43 AM
GreenFlash's Avatar
Ey guys, I have a similar issue but I'm all stock. Ever since they crashed into my parked tC (>_<) once they fixed it I have horrible reception....only one station. Oh and it was hit from the opposite side of the antenna. Fan u guys help? Thanks
scsteven
Jan 25, 2015 01:06 AM
evolving_machine
Jan 13, 2015 08:04 PM
toyotaisme
Jan 10, 2015 10:24 PM
xdejablu3x
Regional - Mid South
Dec 29, 2014 02:15 AM
scionboxrox
Nov 24, 2014 06:38 PM
