06 XB S/C Install
Old May 6, 2010 | 05:37 AM
Bamapolar's Avatar
Default 06 XB S/C Install
I recently acquired a Greddy S/C kit with the emanage unit. Just got it all installed and working properly and wanted to share some pics.
Old May 6, 2010 | 05:50 AM
Bamapolar's Avatar
Default well, I hit POST too soon
the above is a before pic.
There is one of the ALT bracket. Thought this might be good for reference.
There's an after shot.
You will have to reroute that wiring harness away for that actuator. Make sure the lever that moves down doesn't press on the wiring harness. I have since rerouted the spliced vacuum line for the gauge. I can get a pic if anyone needs it.
I still have to clean up (solder) these wires now that I finally got it wired right.
I wanted to show a little detail on the upper pulleys and bracket.
Hope this helps someone. I can take better pics if needed.
Old May 6, 2010 | 10:38 PM
johnny_vitz's Avatar
Nice! Did you buy the kit new? how do you like the new power?
Are you adding a ATF cooler too?
Old May 9, 2010 | 04:59 AM
Bamapolar's Avatar
I bought the kit used. The power is awesome. I can't ever go without it now. I'm spoiled.
I don't have any plans to get an ATF cooler.
I do want to replace my solid stainless grill with another grill that will let some air through. I don't have a gauge to verify but it seems to get hot under there.
The guy I bought it from is on this forum but I don't know his screen name. He pointed out that you should take out the headlight during the s/c install. I couldn't get the headlight out during the install but I had to tighten a few bolts today close to the pulleys and it made the job so much easier. You need to take out the two bumper bolts under the grill and the bolt in the fender well. I'll try to get some pics.
Dennis
Old May 11, 2010 | 03:32 AM
From what I've been told a cooler is highly recommended on the Auto's.
Although, I probably should have put a clutch in mine when I installed my kit, but it's holding up just fine! A clutch is a lot cheaper than a rebuilt tranny though
My install was a breeze only had trouble with the belt because my car doesn't have A/C. I definitely don't think I could go back to stock power...
Old May 12, 2010 | 04:39 PM
Olesen_Custom_Automotive's Avatar
Scion Dynasty
hows it sound? what psi?
Old May 12, 2010 | 05:30 PM
Bamapolar's Avatar
It sounds nice.
It hits 5 easily and I've seen it as high as 8.
Old May 13, 2010 | 05:16 AM
VIP_CAMO's Avatar
Big Sky Scion
nice,def a mod for me if my car does not sell soon.i love when ya pop the hood and bam up in your face unlike the hidden turbos,,
Old Jul 5, 2010 | 08:49 PM
kkawana's Avatar
how long did it take for the install?
yes.. i know its 2months old thread but oh well
Old Jul 5, 2010 | 10:48 PM
It was about 4-5 hours for me installing it on my echo. That includes a break to go out and get the proper sized belt. It plugs right in to the factory wiring (Same as the 04/05 xb's) no wiring/splicing is required.
Old Jul 6, 2010 | 01:38 PM
kkawana's Avatar
coolio... which reminds me i should go take the belt i have (used) and get a new 1 before starting
Old Jul 6, 2010 | 11:25 PM
From what guys told me, gatorback is the best for not slipping. Let us know how it goes
Old Jul 7, 2010 | 12:26 AM
spr0k3t's Avatar
One of these days... charged the box will be.
Old Jul 7, 2010 | 01:08 AM
kkawana's Avatar
starting tomorrow.....
we shall see how it goes
Old Jul 8, 2010 | 03:30 AM
kkawana's Avatar
started today... will start my own thread i guess
Old Feb 6, 2011 | 06:25 PM
mijos87's Avatar
can you show a pic of how you spliced it for your boost gauge?
ColonelSanders85
Dec 9, 2020 09:44 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
