Professional Grade Cabin Air Filter
I had one of these made for my truck awhile back and decided to make one for the xB.
I purchased the filter from HD and the frame from Hobby Lobby.
The filter was about $10 and the frame about $7.
Used my miter saw to cut the frame pieces to size. Had to cut the sides a little shorter, about 1/8th to 1/4in, due to the stock filter gives when you put the cover on, this hard framed filter will not.
You use these clips or brackets to attach the frame pieces together.
I used some wire cutters to cut the plastic cage piece to size.
I used sissors to cut the filter to size. I used 1 layer of the carbon and 2 layers of the filter. Probably only need 1 layer of filter, but I decided to try 2 on this first one.
Finished product. Fits liiiiiike a glove. Carbon side down, filter side up.
Overkill? Probably.
Purdy? You betcha!!
Overkill? Probably.
Purdy? You betcha!!
It came out too long. This is due to the way Scion made it, the stock filter is actually bigger than the space, but it gives when you put the cover on. So I had to cut about a 1/4in. off to have room to put the cover on.
I will pull it out and measure it tomorrow and let you know.
I took RicRat's dims and made an aluminum frame. I bought a 4' length of aluminum ($5.50), flat corner braces ($2.00), and a WEB Eco Washable filter ($20.00) from Home Depot today. The filter has a lifetime warranty and is supposed to last as long as 120 standard filters. Hopefully it'll do what it claims and I can feel good about not adding more rubbish to the landfills....The dims of the filter are large enough to make filters for my '08 xB, my daughter's '06 tC, and our friend's 1st gen '06 xB. Good value.
The frame. I sprayed it because I have plenty of paint on hand and because it's just plain fun. So why not, yeah?
With plastic support frame
Filter placed in frame
And frame inserted behind glove compartment. Fits perfectly.
The '06 tC comes with a plastic tray so I simply cut filter to size and voila!
Done with hacksaw, JB Weld, Dremel, and scissors on a lazy Sunday afternoon.
Mahalo nui loa RicRat!
airmankevin1
02-14-2018 01:23 PM
