SCION XB REMOTE KEY UNCUT
Old Jul 4, 2010 | 04:07 PM
MADD1's Avatar
Default SCION XB REMOTE KEY UNCUT
I recently rented a new Corolla and noticed the key remote is one unit. Does anyone know if we can get one that will fit a 04 xB. I think the blank is a "47" or a "Yaris" key but can the buttons be programmed for the xB?
Old Jul 10, 2010 | 02:52 AM
MADD1's Avatar
I now know that a TC key blank is the same but I cant get the remote to function, Even with the instructions to add a remote.
Old Jul 10, 2010 | 03:54 AM
spr0k3t's Avatar
It's very possible the key itself will not work like you are after. There is a difference in the pulse timing as well as frequency. If you know the pulse rate and acceptable frequency range, you can get any RKE fob you want as long as it works on the same specifications. I do not believe there is an RKE/key unit that will work with the 1st gen security.
Old Aug 15, 2010 | 08:27 PM
MADD1's Avatar
So far I think you might be correct. I talked to a locksmith that might be able to help but it doesn't look good. I got the key cut and it indeed works. I removed the transponder chip since the 1st gen xB doesn't have a need for it. After I get with the locksmith I will post the results.
wwotr
Mar 28, 2015 01:47 AM
Nicolewelker22
Jan 14, 2015 01:08 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Kiwibox
Dec 15, 2014 09:46 PM
BV19869
Dec 11, 2014 06:05 PM
