Scionlife.com Scion Enthusiast Community
Go Back   Scionlife.com » Tech and DIY » tC Tech and DIY
New! Use your Facebook to securely log into this site, click logo to login
Register Search Today's Posts Mark Forums Read Vendors
Reply
Old 04-09-2005, 01:34 AM   #1
Kaeon
Kaeon's Avatar
Kaeon 22/M
View this user's Super White Corolla
View this user's Black Sand Pearl Yaris
View this user's Dark Blue Pearl Supra
View this user's Black Sand Pearl tC
Default Header Install (DC Sports)
Tools Needed:
Metric Socket Set
Torx 5.0mm socket
WD40
Floor Jack
Jack Stands
4" or 6" Socket Extension
12mm Open Head Wrench
Adjustable Wrench (or 15/16 Open Head wrench )
Optional:
New Exhaust Manifold Gasket (P/N 17173-28010)
12mm Deep Socket
Impact Wrench
Torque wrench
Work Mat
Drill
1/2th bit
First and foremost Please DO NOT!!! WORK UNDER THE CAR WHILE IT REST ON A FLOOR JACK... Use jack stands, I've had a bad experience with a car held only on a jack trust me its worth the 15 dollars or so...
Now that I have some stands thanks to Jesse(from focaljet) I jack the car up from the front support.
I then place one stand on each side of the car using the cars side supports.
Now that you have done this its time to get down and dirty
*Make sure the engine is cool before you start working*
First Remove the (4) 12mm nuts holding the heat shield in place(Red)
Then using a 5.0 torx socket unscrew the stud(Yellow)
After removing the stud, move the heat shield away from the header and spray the (5) Header nuts and 02 sensor with WD40. (Use a good amount)
(Note: Doing this will make the new header smoke for about 10 minutes, if smoke continues for more then 10 minutes shut the car off at once and recheck your work)
Now let the nuts and 02 sensor soak in the WD40 for about 20 minutes.
While the 02 is soaking get under the car and using your 4"-6" extension remove the (2) 9/16th spring loaded bolts(Red).
Now in this picture you will see a black bracket that connects from the bottom of the header to a mounting point. There is two of these brackets one on each side of the header, both have one nut connecting them to the header. The nuts are 9/16ths(Purple) remove them as well.
The Right hand bracket (Closest to the passenger side) Will need its 2nd bolt removed. This bolt connects the bracket to its mounting point. Remove this bolt(Yellow) then remove the right hand bracket. (Bracket needs to be removed to slide the OEM header out)
Bracket gone ( Phat Pat making a weird face, Sorry )
Now remove the 12mm bolt(Red) from this mount, And the other 12mm bolt(Purple) Hidden Under the mount
If it has been 20 minutes or more head over to your o2 sensor with your Adjustable Wrench Or (15/16 Open Head Wrench) Give it one turn after that it should be loose enough to take it off with your hand. After this you can remove the heat shield completely.
Now unbolt the (5) 12mm nuts, The Nut in (BOLD RED) is a little stubborn. I had to use a 12mm Open Head Wrench with slight Hammer tapping. :D. Once you get the final bolt off, remove the header by sliding it out to the passenger's side and then pulling up, this will expose the old gasket.
Remove the old gasket. (If you are reusing the gasket do not remove it.
On the bottom of the OEM header you will see this Donut Gasket.
Remove it
And place it on the DC header.
Now with your new Gasket. (P/N 17173-28010)
Install it.
And set the header in place.
Now put your bolts on the studs and tighten them as they are numbered. Give each bolt about one turn and then move on to the next one. Repeat this until they are all tight. (20 foot pounds is the specs on these) I myself didnt have a Torque Wrench so I used Miko's "Its Tight" method just use your judgement. As for the number (4) Nut, I tightened it by hand and then used the Hammer Method once more to get it tight.
Now Place in your o2 sensor in the new header, Tighten it down with your wrench.
Now back under the car line up the header and put in your spring loaded bolts.
Tighten them down until the spring is fully compressed.
And your done!!!
Review:
Instructions were good, they could be improved. (Maybe include better description on things) for the people who are new to Header Installs. Our total install time was about 2 hours this is because we heard the ALT needed to be dropped to get the last bolt out. We called Dennis from DC and left a message. He replied promptly and told me that Gahun (Sorry If I spelled that wrong) Would give us a call about this problem.
He called me ASAP but I missed the call. We played a little bit of phone tag trying to reach each other, I was about fed up with this damn bolt so we used a Open Head 12mm Wrench and a Hammer to tap is loose... Other then this small problem the install was pretty easy and straight forward.
After the install the header smoked for about 10 minutes this was due to the WD40, Grease, etc. The first test drive was performed with a Fireball Universal Tip w/ Silencer, At idle it gave a nice deep groan. Accelerating on the other hand sounded very raspy and high pitched like a Honda Civic on speed I think this is due to my muffler choice (Maybe I can get my hands on a DC system ).
I removed the Silencer from the Muffler, And the tone became a lot deeper at idle but once again acceleration had that same High pitched Raspy sound, I did feel the car pull more at high speeds witch was awesome it felt very responsive. I will update this after 2 weeks and after a month to tell you how the tone has changed. All and all good product! Does Need better instructions for New Installers!
*Note* The DC Header is known to make the 'check engine' light pop on, But no worries for $3.00 at your local Autozone Or Pep Boys you can fix this.
You will need a set of Spark Plug Anti-Foul's they are 18mm HELP! brand Part#42002 or 42009.
You will need to drill out a 1/2" hole in one of the Anti-Foul's
Unbolt your 2nd O2 sensor *NOT THE ONE ON THE HEADER, THE ONE ON THE S PIPE*
(I would spray a little WD40 on this o2 as well before removing)
Now screw on the Anti-Foul with the 1/2" hole on top of the regular one and then screw it into the hole for the 02.
Screw the 02 into the Anti-Fouler's tighten everything up, Then disconnect the (-) Battery terminal for about 1 minute.
And BAM no CEL.
~ Kaeon
Kaeon -
Tech Editor
Current:
2007 Black Sand Pearl Yaris Hatch [5spd]
Past:
2005 Black Sand Pearl tC [5spd] [Boost]
1995 Horizon Gray Civic [5spd] [Boost]
Kaeon is offline   Reply With Quote
Old 04-28-2005, 12:21 AM   #2
KINGxOFxSKA
KINGxOFxSKA's Avatar
KINGxOFxSKA 24/M
Send a message via AIM to KINGxOFxSKA
awsome post
PATRICK @ TWEAKED ICE
www.tweakedice.com
_________________
Check Out My Mods:
http://www.scionlife.com/profile/KINGxOFxSKA
KINGxOFxSKA is offline   Reply With Quote
Old 04-28-2005, 12:32 AM   #3
VoLktc
VoLktc
STICKY!!!!!!
VoLktc is offline   Reply With Quote
Old 04-28-2005, 07:43 AM   #4
DouBLeJ16
DouBLeJ16's Avatar
DouBLeJ16 27/M
View this user's Flint Mica tC
Send a message via AIM to DouBLeJ16
I did this anti-fouler mod with the megan header and 60-70 miles later I have the CEL.
- K&N CAI, Megan Header & S-pipe, Megan Drift Spec Exhaust, AP Crank Pulley -
9.82 @ 73.44
^^ Traded in for '04 350z (8.87 @ 81.3mph bone stock down to the air filter & tires)
DouBLeJ16 is offline   Reply With Quote
Old 04-28-2005, 09:26 AM   #5
Swanny
Swanny's Avatar
Swanny
View this user's Indigo Ink Pearl tC
Send a message via AIM to Swanny Send a message via MSN to Swanny
Very nice write up!
TRD Axle Back Exhaust , TRD Rear Anti-Sway Bar , OBX Sport Pedals , OBX Shift Knob , Door Still Protectors , DC Sports Front Strut Tower Brace , Weapon R Secret Weapon Intake, 18" Bronze Enkei RS7's
Soon...... Short Shifter , Header
Swanny is offline   Reply With Quote
Old 05-01-2005, 01:22 PM   #6
i64X
i64X
The spark plug anti fouler trick works great. I've gone over 3,000 on my car with this trick using the DC headers and I don't have a CEL yet.
i64X is offline   Reply With Quote
Old 05-01-2005, 01:57 PM   #7
Kaeon
Kaeon's Avatar
Kaeon 22/M
Quote:
On the DC header, It works fine. They only people having problems is the Megan Header users, Either way There is a couple of S.Pipes coming out that "Claim" to fix that problem. Ill post info on it when I get it and try it out.
Kaeon -
Tech Editor
Current:
Past:
Old 05-01-2005, 02:57 PM   #8
Boom12V
Scionetics
Boom12V's Avatar
Boom12V 110/M
View this user's Black Cherry Pearl tC
outstanding post
Boom12V
Boom12V is offline   Reply With Quote
Old 05-28-2005, 04:58 PM   #9
matty-tC
matty-tC's Avatar
matty-tC
Send a message via AIM to matty-tC
that rocks. nice writeup. now fix that muffler ;)
05 flint
matty-tC is offline   Reply With Quote
Old 05-29-2005, 03:22 AM   #10
Kaeon
Kaeon's Avatar
Kaeon 22/M
Quote:
That is next, Been in contact with DC about there Exhaust hopefully it goes well with their header! I will post as soon as/If I get it!
Later!
~ Kaeon
Kaeon -
Tech Editor
Current:
Past:
Old 06-15-2005, 06:11 PM   #11
raWr215
raWr215 25/M
View this user's Classic Silver Metallic tC
Send a message via AIM to raWr215 Send a message via MSN to raWr215
Quote:
Any more info about that?
raWr 0wnz j00 k?
raWr215 is offline   Reply With Quote
Old 06-15-2005, 07:09 PM   #12
Kaeon
Kaeon's Avatar
Kaeon 22/M
No, No info sorry, Im still in the works with trying to get the DC cat back system. If I do I will post some audio on how it sounds.
Kaeon -
Tech Editor
Current:
Past:
Old 06-16-2005, 07:34 PM   #13
raWr215
raWr215 25/M
sure that'll be great, but im a car noob, can you explain how would the anti-foul work with the o2 sensor
raWr 0wnz j00 k?
Old 06-16-2005, 08:25 PM   #14
Kaeon
Kaeon's Avatar
Kaeon 22/M
Quote:
Rawr,
Im not a car professional myself, But Im pretty sure that the DC Header has to much flow for the stock 02 to handle, Im pretty sure that extending the 02 out a little bit by using the Anti Foulers, corrects the flow being supplied to the 02 therefore not throwing a CEL, Someone please correct me if im wrong. This is just my guess..
Kaeon -
Tech Editor
Current:
Past:
Old 06-17-2005, 11:58 AM   #15
raWr215
raWr215 25/M
did DC give you that procedure for that fix? if so i can contact them and ask them, i am actually very interested in the DC header you put in your tC. so i don't mind calling them if i have to! plus i'll post the info when i get it
raWr 0wnz j00 k?
Old 06-17-2005, 03:02 PM   #16
Kaeon
Kaeon's Avatar
Kaeon 22/M
No DC did not tell me about this fix, As for the rest of your post I have no idea what your trying to say lol.. Sorry
Kaeon -
Tech Editor
Current:
Past:
Old 06-21-2005, 03:12 AM   #17
i64X
i64X
Just an update - over 8,000 miles now with the anti-fouler trick with the DC header and no signs of a cell yet.
Old 07-02-2005, 03:54 AM   #18
Emo
Emo
just a question for you guys... if I decide to finally put my DC header in... and then to go my dealer.. will they freak out seeing it in there and possibly void my warranty?
-Emo
The ONLY way 3 people can keep a secret is if 2 of them die.
Emo is offline   Reply With Quote
Old 08-01-2005, 07:21 PM   #19
jrjust123
jrjust123 109/M
i just did the non foulers trick with my 06 tc and it does not work. i have 4-1 DC sport race headers, i used non foulers HELP! part # 42002 AND 42009 and niether works, any help?
jrjust123 is offline   Reply With Quote
Old 08-01-2005, 07:47 PM   #20
Kaeon
Kaeon's Avatar
Kaeon 22/M
Quote:
Did you drill out the Top fouler to the proper size?. Did you reset the ECU? Did you check and make sure all your work is nice and tight? These details will help us assist you better..
Kaeon -
Tech Editor
Current:
Past:
Reply
Tags
dc, diy, due, engine, fouler, header, headers, installation, light, plug, scion, spark, sports, tc, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin® v3.7.5, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
