Scionlife.com Scion Enthusiast Community
New! Use your Facebook to securely log into this site, click logo to login
Register Search Today's Posts Mark Forums Read Vendors
Reply
Old 10-21-2005, 05:19 PM   #1
ack154
Super Mod
ack154's Avatar
ack154 29/M
Default Common tC Issues and Various Fixes
With all of the "rattle this" and "delay that" posts thoughout this tC forum, I thought I would begin trying to compile some of the common issues and/or fixes people have experienced or tried. Keep in mind, neither myself, nor SL, nor the original poster of these threads are responsible for any modifications you do to your car. Don't come whining to us if you break something or these don't work for you.
Your mileage may vary.
TECHNICAL SERVICE BULLETINS
From this link, you will find the most current list of TSBs for the tC. Any changes/modifications/additions should be PMd to icdedppl.
--> TSBs
http://home.cfl.rr.com/icdedppl/faq.html#b7
RATTLES
Many tC owners have complained about some sort of rattle. Whether it's the hatch, the sunroof, wind deflector, license plate... whatever. The first thing I think any of you with a "rattle" should do is visit your dealer. It might not even be anything listed here. Check with the dealer first. Go back a couple times if you have to and get Scion Corporate involved - until they say there's nothing more they can do. Then you might consider trying some of these possible solutions.
--> Wind Deflector
http://www.scionlife.com/forums/viewtopic.php?t=88812
--> Hatch/Sunroof
http://www.scionlife.com/forums/viewtopic.php?t=87311
http://www.scionlife.com/forums/viewtopic.php?t=86680
http://www.scionlife.com/forums/viewtopic.php?t=86588
http://www.scionlife.com/forums/viewtopic.php?t=83260
http://www.scionlife.com/forums/viewtopic.php?t=82901
http://www.scionlife.com/forums/viewtopic.php?t=79677 <- FAQ Thread
http://www.scionlife.com/forums/viewtopic.php?t=79501
THROTTLE DELAY
Due to the tC's drive-by-wire system, many people complain about a noticable delay in throttle response time. This is the way it is. But some people have been trying to find a way to minimize this delay and there are a couple options. This isn't something the dealer can address b/c it's working the way that it was intended. But try these if you like:
--> Bump Stop
http://www.scionlife.com/forums/viewtopic.php?t=84643
--> Grounding Kit DIY - for an xA, but still relevant.
http://www.scionlife.com/forums/viewtopic.php?t=29261
-=-=-=-> Note: There are also manufactures that make prefab grounding kits for the tC (eg. GroundFusion).
SUNROOF DOESN'T CLOSE
Our sunroof has a safety feature that will open the sunroof back up if it is "stopped" by anything. Possibly if a hand or other body part were sticking out - so that it wouldn't try to close on that body part and someone lose a limb. Well this can start to happen when it shouldn't as you close the sunroof. Occasionally as the sunroof tries to press down the wind deflector, this safety feature will trigger and the sunroof will open back up. As mentioend above, first thing you should do is try your dealer. They may need to clean the tracks or lubricate it. Or you can read through these:
--> Clean/Lubricate Track
http://www.scionlife.com/forums/viewtopic.php?t=108551
http://www.scionlife.com/forums/viewtopic.php?t=73540
LOOSE CLUTCH PEDAL
Some tC users say they have some play in their clutch pedal before any part of the clutch engages. Listed below is one method that may remove the play in the pedal and make the clutch more responsive. It's a method similar to the bump stop for the gas pedal.
--> Bump Stop
http://www.scionlife.com/forums/viewtopic.php?t=84917
OTHER ISSUES
** Squeaking Clutch Pedal **
Over time, you may notice a squeak when pressing in the clutch pedal. Seems to be intermittent and usually will be from the engine bay.
--> Grease Method
http://www.scionlife.com/forums/viewtopic.php?t=148671
** Radio Door Squeeking **
Some of the radio doors will squeek opening and closing. This is one possible method to alleviate the noise so that it's quiet again.
--> 3M Tape Method
http://www.scionlife.com/forums/viewtopic.php?t=87166 (page 3)
** Brake Light Turns On While Accelerating **
This is two step problem. The light is coming on because the brake fluid is low and sloshing around. But the brake fluid is low because your brake pads probably need to be replaced - less brake pad means more fluid in the lines and less in the reservoir.
--> Related Discussion
http://www.scionlife.com/forums/viewtopic.php?t=185625
** 2007 HVAC Lighting Issues **
Many of the early 2007 tC's have had issues with the HVAC lighting working intermittently or stopping all together.
--> Discussion and Options
http://www.scionlife.com/forums/viewtopic.php?t=253387
If you know of something else that should be added here, reply with a link to the thread and why you think it should be in here. Not everything will be added. Depends on how common the issue is or how useful it might be. Also depends on the situation of the problem - but I'll review them all.
UPDATES:
10/24/05 - added FAQ thread - not sure how i missed it...
01/31/06 - added radio squeek and TSB list
05/22/06 - added sunroof closing issue
08/16/07 - added brake light info
08/06/08 - added squeaky clutch pedal
ack154 is offline   Reply With Quote
Old 10-22-2005, 08:09 PM   #2
ack154
Super Mod
ack154's Avatar
ack154 29/M
Over 100 views and not one suggestion? Damn...
Old 10-24-2005, 01:05 AM   #3
ScionEyes
KAD
Moderator
ScionEyes 36/F
View this user's Black Cherry Pearl tC
View this user's Blue Onyx Pearl xB
Send a message via Yahoo to ScionEyes
Default Re: Common tC Issues and Various Fixes
Quote:
Originally Posted by ack154
Check with the dealer first. Go back a couple times if you have to and get Scion Corporate involved - until they say there's nothing more they can do. .
I Like this one the best!
There are so many things that we take for granted that might actually end up costing you nothing to fix under warranty!
Scion Field Team
West Coast Florida Region
ScionEyes is offline   Reply With Quote
Old 10-24-2005, 01:14 AM   #4
foxtransmission
foxtransmission's Avatar
foxtransmission 31/M
View this user's Nautical Blue Metallic tC
View this user's Custom Color xB
Send a message via AIM to foxtransmission Send a message via MSN to foxtransmission Send a message via Yahoo to foxtransmission
excellent post up need more like these in one section
http://www.scionlife.com/profile/foxtransmission
http://www.cardomain.com/ride/2141376
aamco master transmission rebuilder stick auto t-case check out my stores
www.fearlessmsports.com
www.teamScionRG.COM
foxtransmission is offline   Reply With Quote
Old 10-24-2005, 04:48 PM   #5
rhythmnsmoke
Music City Scions
rhythmnsmoke 1/M
View this user's Black Sand Pearl tC
Good to see a collaboration of fixes to these daunting issues.
Fastest N/A tC @ NSS New BEST (1:16.746)
Sponsorship Acquired: Corbeau Racing, Extreme Dimensions
Music City Scions
Original Gangsta
The Road to being RE-boosted
Phase #1: Sale 350z (completed)
Phase #2: Infiniti FX 35 for the family (completed)
Phase #3: PTunified
rhythmnsmoke is offline   Reply With Quote
Old 10-24-2005, 05:29 PM   #6
ack154
Super Mod
ack154's Avatar
ack154 29/M
Thanks guys... remember... more suggestions will help if you think of something.
Also updated it with another thread.
Old 10-26-2005, 01:38 PM   #7
icdedppl
icdedppl 31/M
View this user's Super White tC
great job ack154! much appreciated.
added to the tC faq as well ;^)
http://home.cfl.rr.com/icdedppl/faq.html#a9
the scion tc faq site
2006 super white scion tC
- oem options: lip spoiler, mudguards, fog lights, mats
- add-ons: s2000 antenna, chrome turn signals, polarg: hir low-beam bulbs & pure yellow fog bulbs, varad 3-led white accent lights, 15% tint
icdedppl is offline   Reply With Quote
Old 10-27-2005, 11:54 PM   #8
400amonth
400amonth's Avatar
400amonth 35/M
I would like to know fixes for rattles around the steering column and under dash left side of driver.
Go easy on the new guy!
Too many parts to list but check out my domain @ http://www.cardomain.com/ride/2087543
400amonth is offline   Reply With Quote
Old 10-28-2005, 12:11 AM   #9
Acsilva84
Acsilva84 26/M
View this user's Flint Mica tC
Send a message via AIM to Acsilva84
thanks for all this..
you should add the link for the clutch stop
Viper791XV Alarm|15%Tint/5%visor|Luminics Ultra Whites|EuroDesignzBlueHighbeam|Hotchkis FrontStrut|CF B-piller|CC BorlaCat-back
Things To Come:
Creative Compacts s-pipe|GettinBoosted|demon eyes|Fidanza Aluminum Flywheel|ProgressCoilOvers|Engine Damper|Lip Spoiler|Blue LED Guage Cluster|Ground Fusion Grounding Kit
Acsilva84 is offline   Reply With Quote
Old 10-28-2005, 12:20 AM   #10
ack154
Super Mod
ack154's Avatar
ack154 29/M
Quote:
I don't think we've had anything really posted for that yet... if you know of anything, let me know and I'll put it up.
Old 10-28-2005, 12:30 AM   #11
ack154
Super Mod
ack154's Avatar
ack154 29/M
A good suggestion... added.
But keep in mind... we don't want to just make another "tech" section of DIYs... I'm looking for issues that are common and someone may have found a solution to.
Old 10-28-2005, 06:01 AM   #12
ignitionr34
ignitionr34 23/M
Send a message via AIM to ignitionr34
under throttle delay section u should also add lo bux racer's fidenza flyweel installation ... cuase that when installed gives no more delay either
ignitionr34 is offline   Reply With Quote
Old 11-05-2005, 11:55 PM   #13
foreverandaminute
foreverandaminute's Avatar
foreverandaminute 23/M
View this user's Classic Silver Metallic tC
Send a message via AIM to foreverandaminute
When people say, "Go to the dealer", does it have to be the same dealer that sold you your car?
BUY SOME SHOES... cashmere sweater?
stock parts from my 06 tC lying around that u can buy from me:
sway bar & springs
ask me for discount on diamond.com and ice,com !
foreverandaminute is offline   Reply With Quote
Old 11-06-2005, 12:22 AM   #14
rockbrawler884
rockbrawler884 26/M
View this user's Absolutely Red tC RS01
Send a message via AIM to rockbrawler884
Good Post, ScionLife needed a collaborative post such as this.
http://www.tunerlane.com/ <--- Join. Big things are coming!
rockbrawler884 is offline   Reply With Quote
Old 11-06-2005, 12:37 AM   #15
PrivateTucker
PrivateTucker's Avatar
PrivateTucker 29/M
Send a message via MSN to PrivateTucker
Great place to start. I too took my tC to the dealer about the rattle before attempting anything myself. The dealership took apart all the interior panels in the back, wrapped everything in insulation foam (prolly just foam tape) and also readjusted the bumpstops for the rear hatch.
~Tucker - 05 VW Jetta 2.5
I have the body of a god... Buddha
Out with the cheap, in with the European!
PrivateTucker is offline   Reply With Quote
Old 11-07-2005, 01:44 AM   #16
toyota_scion_tc
toyota_scion_tc 29/M
Default Engine and Body Ground
The stock tc body and engine ground are 10ga wire which is really tiny wiring. I have a manual tc and when I come to a stop my headlights at night would dim slightly for a second then return to normal. The first thing I tried has fixed this. I went to a audio store and got some excellent quality 4ga wire and ring terminals and made a new ground cable for the battery. Its self explanatory just remove the old ground wire and make another one identical to it. Things you will need to do this. 10mm wrench, 12mm wrench and I believe a 14mm wrench. 1st disconnect the - battery terminal from the battery and tuck it beside the battery so it will not make contact to the terminal. Undo the plastic clips that retain the cable close to the battery. disconnect the 10mm bolt that goes to the body ground. The starter is in the way of the other ground. You will have to unbolt the starter but not remove it. Once it is unbolted undo the engine ground underneath the starter. To make the new cable I went to auto zone and bought a lead free battery terminal. I also had some zip ties and wire loom. And I made the custom battery cable identical to the battery cable you just took off. Then bolt everything back on and you are done. I have notice after a while it still does it but only 1/5 of the time. Not nearly as bad as it was.
toyota_scion_tc is offline   Reply With Quote
Old 11-24-2005, 06:06 PM   #17
scion-tist
scion-tist 34/M
Send a message via AIM to scion-tist
Good post....
scion-tist is offline   Reply With Quote
Old 12-08-2005, 01:34 AM   #18
tcholic
tcholic's Avatar
tcholic 23/M
Send a message via AIM to tcholic
very helpful thanks!
_TcHOLiC_
-=TAKE2CREW=-
94 325is RIP
05 Scion tC SOLD
07 Honda S200 SOLD
97 Honda Civic EK Hatchback CURRENT
SPONSORS:
| JDMTHEORY | FATLACE | WEK SOS | REDZONE | N1CONCEPTS | TRUE EAST| TURBOHOSES R&D |
HUGE PART-OUT SALE THREAD = http://www.scionlife.com/forums/view...892298#2892298
tcholic is offline   Reply With Quote
Old 12-27-2005, 12:17 AM   #19
ScionEyes
KAD
Moderator
ScionEyes 36/F
ipod help~ thats what i need... i have the shuffle but the adapter is for nano's... anyone find anything on this yet>?
Scion Field Team
Old 12-27-2005, 03:42 AM   #20
ack154
Super Mod
ack154's Avatar
ack154 29/M
I don't think the shuffle is compatible... unless you just use the aux input - with a 1/8" minijack cable from the headphone jack of the shuffle. They don't have the dock connector like the rest of the iPods... so the actual "ipod" input wont work.
Reply
Tags
05, battery, cable, clicking, close, clutch, deceleration, disconnected, issues, pedal, scion, sound, sticking, tc, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin® v3.7.5, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
