Scionlife.com Scion Enthusiast Community
Go Back   Scionlife.com » Tech and DIY » tC Tech and DIY
Register Search Today's Posts Mark Forums Read Vendors
Reply
Old 10-28-2005, 06:12 PM   #1
rjj130
rjj130's Avatar
rjj130 29/M
View this user's Custom Color Corolla
View this user's Indigo Ink Pearl tC
Send a message via AIM to rjj130
Default iPod2Car Install
Hey everyone...I've heard many people rave about their ipod2car (neo2car, aux2car, etc...) so I decided I wanted one too.
I found one on eBay that came out to be about $95 w/ shipping and included the one cable, but not the second, but found it on Crutchfield for $9.99 w/ free shipping. So all in all, $105 for something that is usually $150-$200 depending on where you get it and they may or may not include cables which could add $25 to the cost. I think it's a good deal.
Anyways I decided to take pictures as I installed mine last night seeing as nobody else really did. It's not too hard and if you can get to your stereo you won't really need to look at this.
What you need:
1 - ipod2car adapter (or some variation of it)
1 - PXHTY1 adapter
1 - PXHTY2 adapter (needed to between PXHTY1 and HU)
1 - Phillips screwdriver
1 - 11mm socket driver
2 - 1" double sided adhesive squares (or some sort of double sided adhesives, not thin double sided tape!)
Let's get started. First thing is first. You need to unscrew the shift knob on your car, MT or AT. Set this aside and then gently pull middle section of the center console back towards the rear of the car. It's only held in place by some retension clips so it should come out w/ little problems. NOTE!!! Make sure you disconnect the cigarette lighter. Then just place this in the backseat out of the way.
Next we have to remove the dash area that surrounds the stereo and houses the climate controls. Sadly I forgot to take a picture here. But it works the same way as the center console portion. I stuck my fingernails behind the silver trim near the vents and again gently pulled forward and it just slid right off. NOTE!!! There is a connector powering the climate control area, you need to unplug this. Next, just set the climate controls in the backseat with the middle console section.
Now we get to remove the stereo from the car. This is where the Phillips screwdriver and 11mm Socket driver come into play. All you have to do is remove the two (2) screws as well as the two (2) bolts and the receiver will come right out. I didn't disconnect the power, antenna, or factory harness when doing this as I didn't think it was neccessary. It may be easier if you don't want to torque your HU around while it's still plugged in.
So now you have the HU out it's time to hook up the ipod2car adapter. You need to plug harness PXHTY1 into the ipod2car adapter and then plug the PXHTY2 harness into the PXHTY1 harness. Also don't forget to plug in the ipod patch cable to the ipod2car adapter.
Set the dipswitches on the ipod2car adapter. I used the following as the ones indicated in the directions do not work:
OFF: 3 5 7
ON: 1 2 4 6 8
Turn the HU around and you'll see exactly where the smaller (see image above) of the two plugs hook up to the HU.
Finally it's time to mount the ipod2car adapter. Again I didn't do a good job of illustrating this part. What I did was take two (2) one inch (1") max adhesive squares and place them on the back of the ipod2car adapter. Next I placed the adapter behind the stereo on the drivers side of the white plastic there. You can feel free to place yours elsewhere. I may in the future but I just wanted to get this done for right now. You can see below on the image where I put it based on the red arrows.
Also, you need to run the iPod patch cable somewhere. For the time being I ran mine back under stereo and out on the drivers side on the middle console section. Lots of room down where it and the carpet meet.
Lastly, put everything back together and enjoy!
The only glitch I found is that the time on the HU doesn't work. Which if you're going to have a glitch, this one isn't all that bad. It goes back and forth between 1'00 and 2'00...See the pictures below.
Hope this can help...
Yes...it is Sweet.
2005 IIP tC
Rear Lip Spoiler - Floor & Cargo Mat Package - VSE Bazooka Subwoofer - Madico Clear Bra - ipod2car - Aluminum tC Doorsill Inserts
rjj130 is offline   Reply With Quote
Old 10-31-2005, 09:10 PM   #2
mikochu
mikochu's Avatar
mikochu 26/M
View this user's Polar White xA
Nice! :D I'll add this to the Tech section and move it to the FAQ section in a week or so.
Also, have you noticed the flakey auto on/off feature? Like...the iPod not turning on/off when the head unit is turned on/off?
Michael Reyes
www.mikochu.com
2009 Honda Civic Si Sedan Crystal Black Pearl [6spd]
2002 Honda 919 Asphalt [6spd] (more info)
2004 Scion xA Polar White [5spd] (more info)
google it.
mikochu is offline   Reply With Quote
Old 11-01-2005, 01:04 AM   #3
rjj130
rjj130's Avatar
rjj130 29/M
Yeah there are a few quirky things about this whole setup, but I think it's the best thing shy of having the OEM package.
I have the following issues so far:
1. The time fluctuating between 1 and 2 minutes as mentioned above.
2. Sometimes there is a lag of changing songs from the HU
3. And finally, the whole not turning off and on thing.
2005 IIP tC
Old 11-06-2005, 04:18 AM   #4
Xenon_tC
Xenon_tC 110/M
Send a message via AIM to Xenon_tC
Could we possibly get a pic of the final product, of where the wire was fed thru and where ther ipod is mounted?
Xenon_tC is offline   Reply With Quote
Old 11-08-2005, 06:34 PM   #5
UnFocused
UnFocused's Avatar
UnFocused 26/M
View this user's Thunder Cloud Metallic xB
Not to steal your thread, BUT
I just installed my P.I.E TOY03-AUX adapter which gives you an audio input VIA an standard headphone jack. Whille it does not charge my I pod NANO, it does instantly give my head unit a signal, and the dispay on the headunit stays the same....
2005 TCM xB MT
UnFocused is offline   Reply With Quote
Old 11-09-2005, 09:47 PM   #6
Phixeus
Phixeus's Avatar
Phixeus 110/M
View this user's Black Cherry Pearl tC
View this user's Blue Onyx Pearl xB
i hooked up my iPod via the AUX jack and the remote mount button line that iPod sells. it works great too. cost me $35.
Chuck Norris is a vegetarian. Meaning, he does not eat animals until first he puts them into vegetative state!
Jack Bauer tried to use his detailed knowledge of torture techniques, but to no avail: Chuck Norris thrives on pain. Chuck Norris then ripped off Jack Bauer's arm and beat him to death with it. Game, set, match.
Phixeus is offline   Reply With Quote
Old 11-20-2005, 01:47 AM   #7
jeager521
jeager521 22/M
View this user's Azure Pearl tC
Send a message via AIM to jeager521
This write-up is amzing! However, do you know if this works with the 6-disc CD changer head unit? If so I will be on this ASAP. Thanks for your help, Stefan
jeager521 is offline   Reply With Quote
Old 11-21-2005, 04:18 PM   #8
DibujoB
DibujoB's Avatar
DibujoB
View this user's Camouflage Metallic xB
Ditto that...
Does this work with the 6 disk changer?
Trogdor! Burninating the countryside, Burninating the peasants and their thatch roof cottages!
DibujoB is offline   Reply With Quote
Old 11-21-2005, 06:35 PM   #9
R2D2
R2D2's Avatar
R2D2 103/M
What options are there if its not an iPod, but a aftermarket player?
R2D2 is offline   Reply With Quote
Old 12-06-2005, 04:08 AM   #10
Greg2385
Greg2385 110/M
View this user's Super White tC
Send a message via AIM to Greg2385
Will this set up work with the ipod nano?
2005 Manual
| TRD Exhaust | TRD Lowering Springs | TRD Anti-Roll Bar | K&N CAI | Fog Light Kit | Edi 6000 Components | Ed 3Kv2 Sub | S2000 Push Start Button | Angel Eyes | Blacked-out Corners | Tint | OBX Racing Pedals | Door Sill Enhancements | Completely Debadged |
For Sale
OEM Lower Grille (OEM Fog Light) | OEM Pedals
PM me for more info.
Greg2385 is offline   Reply With Quote
Old 12-06-2005, 04:26 AM   #11
zoltiz
N.G.S.O.
zoltiz's Avatar
zoltiz 32/M
View this user's Silver Streak Mica xD
View this user's Black Sand Pearl tC
Send a message via ICQ to zoltiz Send a message via MSN to zoltiz
That's definitely another alternative. I've used wire-tunes unit in my tC for a while, but sold the iPod, so trying to sell the inteface unit now. It does not have the glitch with time not displaying and it turns the iPod on and off. Also does not require any extra cables - simple plug and play. Allows you to move between your playlists (I had 12), and move between songs / ff /fr/ and has a shuffle function. Everything controlled from the HU - I kept the iPod in the centec console away from prying eyes.
Check classifieds for my for sale ad ;)
'08 SSM Scion xD 5MT | 18s | sub | springs | fiveaxis kit
'05 Storm Titanium Lotus Elise | sport | touring | hardtop
zoltiz is offline   Reply With Quote
Old 12-06-2005, 04:47 AM   #12
mikochu
mikochu's Avatar
mikochu 26/M
But it locks the iPod screen...
Michael Reyes
www.mikochu.com
google it.
Old 12-06-2005, 07:57 AM   #13
squarrel
squarrel's Avatar
squarrel 27/M
Send a message via AIM to squarrel
Does it work with a nano?
CC Short Shifter
clutch pedal stop *TY sdparks*
35% window tint, 4" 15% windshield lip
TRD Springs
TRD rear sway bar
squarrel is offline   Reply With Quote
Old 12-06-2005, 11:49 AM   #14
zoltiz
N.G.S.O.
zoltiz's Avatar
zoltiz 32/M
Very true. Forgot to mention it. Never used the iPod screen - hard to see on the bottom of the center console
Wire-tunes new costs $99, btw. I only ask for half of that for mine.
Old 02-19-2006, 04:43 PM   #15
Johnm248
Johnm248's Avatar
Johnm248 23/M
View this user's Black Sand Pearl xB
Send a message via AIM to Johnm248
does this ipod2car thing work with the ipod video?
2005 Blank Sand Pearl xB
Johnm248 is offline   Reply With Quote
Old 05-15-2006, 10:57 PM   #16
IH8ONYU
IH8ONYU's Avatar
IH8ONYU 32/M
View this user's Hot Lava xB RS01
View this user's Envy Green xB RS03
Send a message via AIM to IH8ONYU
works nano & ipod vidieo
If you would like to make your own custom Spedo Face, Please PM me for the 04-07 XB Spedo Face Photoshop Template - $5 For the Template as a .PSD File. Design work also available for Custom One Of A Kind Designs.
Check out my myspace page.. It's under construction...
http://www.myspace.com/urbantransportation
Or Facebook me!
http://www.facebook.com/anthonydemetriou420
IH8ONYU is online now   Reply With Quote
Old 07-19-2006, 10:43 AM   #17
frontpage
frontpage 109/M
so... why no photo of the finished product?
frontpage is offline   Reply With Quote
Old 08-12-2006, 07:56 PM   #18
Xenon_tC
Xenon_tC 110/M
I just sent the wire down behind the HVAC and it comes out thru the E-Brake, and i just leave the ipod upside-down inside the cashtray. Didn't need to do any drilling and it looks somewhat clean
Old 08-25-2006, 07:25 AM   #19
roman1
DeepSouth Scions
roman1 29/M
Send a message via AIM to roman1 Send a message via MSN to roman1 Send a message via Yahoo to roman1
Quote:
Originally Posted by DibujoB
Ditto that...
I just read on Peripheral's site that it does not work with 6-disc changers. Its either ipod or cd changer, but not both.
Roman1
2005 Scion Tc flint mica
15% tint
Auto-dimming mirrors
2 Rockford Fosgate 800a2
2 12" Boston Acoustic Pro Series woofers
Boston Pro highs and mids
roman1 is offline   Reply With Quote
Old 08-26-2006, 12:19 AM   #20
mikochu
mikochu's Avatar
mikochu 26/M
The 6-cd changer headunit _should_ work with the ipod2car. I believe Peripheral is talking about headunits that have an external multi-CD changer...like the ones under the passenger seat or trunk...
Michael Reyes
www.mikochu.com
google it.
Reply
Tags
08, aux2car, grille, ipod2car, lower, remove, scion, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin® v3.7.5, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
