Scionlife.com Scion Enthusiast Community
Go Back   Scionlife.com » Tech and DIY » tC Tech and DIY
New! Use your Facebook to securely log into this site, click logo to login
Register Search Today's Posts Mark Forums Read Vendors
Reply
Old 06-07-2006, 10:51 PM   #1
tcrock
tcrock's Avatar
tcrock
View this user's Super White tC
Default Intake Install (AEM)
Hey all, I wanted to thanks the guys at ScionLife for providing the intake and this website. Without this site I would not have bought a Scion. Thanks guys!
After glancing at the instructions I felt confident that I could let the neighborhood kids handle the installation. Markus is seven and Andrew is nine, and both have a reasonable grasp of how to follow instructions. I sat back and let the kids take over.
AEM Cold-Air Intake Installation Guide
Read Instructions
Both kids voted to commit the instructions to memory before touching the car. Markus couldn't figure out what some of the car part names referred to, but was sure that he could figure it out once he started taking things apart. Andrew was more concerned about the large hole in the top of the intake pipe. Hows this gonna keep the air in?
Check Parts
Our kit came with two sections of polished piping, a filter, assorted silicon pipe fittings and hose clamps, a small bag of miscellaneous hardware and instructions.
Open Hood
My tC's engine compartment was definitely NOT going to turn any heads. The large, ugly plastic intake pipe and filter box is the opposite of bling. The kids agreed that adding some shiny metal would make the car much better.
Remove Front Left Wheel
Markus got to work loosening the lugnuts, then Andrew located the arrow under the coupe's sill to properly locate the jack. After jacking the car up it was a snap to remove the pre-loosened lugs, and the wheel was set aside.
Remove Engine Cover
Markus knew the directions by heart, so he jumped right in and started removing the engine cover. After the installation was complete he realized that it was never in the way, and probably didn't have to be removed. But since it was only two bolts and it can scratch easily he thought it was still a good idea.
Loosen Components
The instructions were very detailed, and easily led the two through each little detail of the installation. To remove the old intake they had to unsnap a small hose and pull out the PCV hose.
Remove MAF
The Mass Air Flow sensor (MAF) had to be removed from the old intake so it can get installed on the new one. Andrew's little fingers had trouble unplugging the sensor, but once that was done it was easy to remove the two screws and pull the sensor out. He knows that MAF sensors are very fragile, so he set it aside carefully so it wouldn't get damaged.
Detach Sensor
Another little sensor is attached to the old intake, so it was pulled straight up to snap it out, then the bracket was unscrewed with a single philips screw. It was kind of hard to pull the sensor out of its holder, so I had to put down my cold beer and take control of this step.
Remove OEM Intake
Finally! The two latches holding the filter cover on were released and the old intake was pulled from the throttle body. The clamp holding the old intake onto the throttlebody was tight, and difficult to reach with tools, so the kids called me over again! Luckily I could use my fingers to squeeze the clamp so the intake came right off. I then immediately settled back into my observation chair and opened a second beer.
Compare Parts
With the old intake out it was easy to compare the two. Markus was very pleased at the lightness of the new AEM unit, and its obvious reduction in airflow resistance. He also liked that it was shiny, as previously noted. Andrew was unhappy that he had to hold the old crappy intake system, and moments after the picture was snapped he proceeded to throw it into his years where his year-old pitbull used it as a chew toy.
Remove Remaining OEM Components
A couple more old parts still had to come out. The bottom of the filter box was removed with three 10mm bolts and the lower intake section had two plastic philips screws holding it in. The top screw was simple, but the lower screw took some finesse. This is where seven-year-old hands come in handy. The fusebox cover was removed and a stubby philips screwdriver made removal of the intake section much easier. Then it simply pulled out and went into the trash.
Loosen and Move Fender Liner
Time to get the inner fender liner out of the way. A screw and plastic pop rivet in the wheel well and three screws under the car loosened the part of the liner that was in our way. We folded it back and hooked it behind the brake to keep it from slapping ou hands while we worked.
Remove Headlight Ground Bolt
Down in the wheel well we stuck our heads and camera into the small area under the headlight to locate the headlight ground bolt. It needed to be removed to make room for a future intake mounting bolt. The 10mm bolt was not visible, but the kids could feel it behind the sheet metal. It was easy to find because it had two white wires running to a metal ring terminal that was bolted to the body.
Prepare for Intake Installation
Markus screwed in the two rubber intake mounts, popped the silicone adapter onto the throttlebody (with two hose clamps on it) and wrapped the plastic spiral wrap onto the rubber hose, as per the AEM instructions.
Install Long Intake Section
Next Markus slid the new intake section into the hole in the inner fender, lined it up with the adapter on the throttlebody and slid the tabs into the newly-installed rubber mounting bolts.
Reinstall OEM Components
The PCV valve hose, MAF sensor and that other little sensor all had to go back together. The hose slipped right on using the old clamp, the MAF sensor screwed back in with new screws (supplied) and the other sensor went on with a new screw and locking washer.
Intall Lower Intake and Filter
Back in the wheel well Andrew was stumped on how to properly install the rubber mounting bolt for the lower intake. I pushed him aside, installed the mounting bolt and laughed in his face! Then Markus tried to install the lower intake, and had a lot of trouble. Andrew figured out that I had installed the mounting bolt wrong and fixed it. It turns out that the rubber mount should be installed on the backside of the sheet metal, from where the original bolt came out. I had installed it on the side of the sheet metal that I could see. Quick fix. With it installed correctly the lower intake tube went right on with an adapter and a couple of hose clamps. The braket screwed onto the mount and the folter tightened right onto the end of the intake. Easy!
Reinstall Fender Liner and Wheel
Andrew reinstalled the fender liner using the reverse process, reinstalled the wheel, removed the jack stands and lowered the car back to earth.
Tighten, Inspect Work and Test System
The little guys then tightened all of the upper hose clamps, checked everything over for tightness and fit. They made sure all tools had been removed from the car and then called me over to start it up. The car fired right up and no check engine light! We went for a zip around the block and the kids definitely felt that the intake made a huge difference. The sound of the engine was much more evident, with quick throttle blips taking on a new menacing tone. Full throttle was far more gutteral with multiple harmonics pleasing the ear.
Tools Needed
Remember in the beginning when we told you to read the instructions first? Well, if you did then you will see this before you start! Now that we were done with the install we could easily show you which tools we needed.
Relax
All done! Now sit back and enjoy a cold one! Of course, these are children, so they got to enjoy a couple of Henry Weinhard's finest Root Beers!
tcrock is offline   Reply With Quote
Old 06-08-2006, 12:12 AM   #2
SquallLHeart
Super Mod
SquallLHeart's Avatar
SquallLHeart 27/M
View this user's Classic Silver Metallic tC
View this user's Silver Streak Mica tC
Send a message via AIM to SquallLHeart
There is NO excuse for not being able to do this install yourself!
please??
original LED ideas - swap expert - parts available Become a fan! LED-Headz
LOOKING FOR a 2nd GEN tC to tear apart (when it comes out.. etc.. blah blah...)
PM me if you live in the Bay Area and are getting one. your assistance will be rewarded.
need help? call me: 408-905-7769
me like:
Doctor Isotope | TweakedIce | PrecisionMuffler | 365motorwerks | LEDmod.com(custom Gaugefaces)
SquallLHeart is offline   Reply With Quote
Old 06-08-2006, 12:16 AM   #3
2fast4you
Team ScionTific
2fast4you's Avatar
2fast4you 35/M
View this user's Blitz Blue Mica tC RS02
Now THAT'S the best tech article ever!
2fast4you is offline   Reply With Quote
Old 06-08-2006, 12:23 AM   #4
ProshopXB
ProshopXB's Avatar
ProshopXB 31/M
View this user's Black Cherry Pearl xB
Send a message via AIM to ProshopXB
Quote:
+1
Those kids proably no more than the Toyota Techs do and could do a better job.
ProshopXB is offline   Reply With Quote
Old 06-08-2006, 12:25 AM   #5
Spect2K3
Spect2K3's Avatar
Spect2K3 25/M
View this user's Black Sand Pearl tC
Now I KNOW that I can do this!
Spect2K3 is offline   Reply With Quote
Old 06-08-2006, 01:12 AM   #6
jrv2000
jrv2000 110/M
X3 this should be stickied, seriously.
20% tint all around
TRD Springs
TRD Shocks
Hotchkis Sway Set
DC Strut Bar
K&N CAI
DC header
Invidia S pipe
36" magnaflow resonator
jrv2000 is offline   Reply With Quote
Old 06-08-2006, 01:44 AM   #7
zer0
zer0 25/M
Good stuff, what is their hourly rate? $65hr?
zer0 is offline   Reply With Quote
Old 06-08-2006, 01:55 AM   #8
acex008
acex008 30/M
Send a message via AIM to acex008 Send a message via Yahoo to acex008
this was by far the most excellent, radical how-to i have ever seen, and believe me, between owning a tC and a air-bagged, fully cut-up truck, I've read many. Now, to more important stuff, do you notice a real performance difference thats actually felt rather than just heard?
-BSP tC 5spd-
-black brake calipers-
-blacked out emblems-
-tinted tail lights-
-s2000 antennae-
-alpine HU in flushed console-
-eD speakers and amps soon-
acex008 is offline   Reply With Quote
Old 06-08-2006, 02:04 AM   #9
Spect2K3
Spect2K3's Avatar
Spect2K3 25/M
i'd like to hear to hear about the performance as well...how does that puppy run?
2006 BSP Scion tC 5-speed
Check Out This Thread
~Jay
Old 06-08-2006, 02:23 AM   #10
xnevergiveinx
xnevergiveinx 27/M
View this user's Indigo Ink Pearl tC
Send a message via AIM to xnevergiveinx
haha, this is awesome.
wait a second, you put a kid under your car without using a jackstand!
Creative Compacts short shifter
Corsport shifter cable bushings
Redline MT-90 Synthetic Trans fluid swap
Monsterknob shift knob
Redout reverse & 3rd brake lights
Aux input box
autoalarmpro alarm
xnevergiveinx is offline   Reply With Quote
Old 06-08-2006, 02:28 AM   #11
Max
Max's Avatar
Max 29/M
View this user's Thunder Cloud Metallic xB
View this user's Gray Metallic Clearcoat Truck
I love the latest round of creative tech articles.
Good work.
Hey I'm not around as much as I used to be. If you have a specific question for me, please PM.
Max is offline   Reply With Quote
Old 06-08-2006, 04:11 AM   #12
roflitzjinno
roflitzjinno 21/M
Send a message via AIM to roflitzjinno Send a message via Yahoo to roflitzjinno
and someone wanted a shop to install their intake. crazy adults these days!
roflitzjinno is offline   Reply With Quote
Old 06-08-2006, 04:44 AM   #13
azurTC
azurTC's Avatar
azurTC 29/M
View this user's Azure Pearl tC
View this user's Polar White xB
Send a message via Yahoo to azurTC
Starting them young is awesome. Keep up the good work.
Don't worry about reinventing the wheel. Just accept the wheel is here and learn how to use it.
Never underestimate the power of stupid people in large groups.
I have great respect for all who ask questions and seek honest answers.
azurTC is offline   Reply With Quote
Old 06-08-2006, 05:50 AM   #14
soros151
soros151's Avatar
soros151 24/M
View this user's Custom Color Corolla
View this user's Black Cherry Pearl tC
Awasome, made me laugh a looot.
Life's simple, either u do it, or u don't. No regrets.
Quote:
Originally Posted by MJVsTC
If it feels like something is chewing on your right foot, you may want to get that checked.
Quote:
Originally Posted by snarcher
what? why would i put them on the front of a rear wheel drive car??
-------OMG!! LOL! HE DIDN'T KNEW HIS tC WAS FWD!! ROFL!
soros151 is offline   Reply With Quote
Old 06-08-2006, 06:34 AM   #15
Shocker
Shocker 23/M
View this user's Absolutely Red tC RS01
Send a message via AIM to Shocker
that is the first tech article that i have read every line of.. nice article
RS 1.0 tC #539
Shocker is offline   Reply With Quote
Old 06-08-2006, 12:35 PM   #16
THansenite
THansenite's Avatar
THansenite 26/M
Child labor? Children working in less than ideal working conditions for minimal pay. You should be ashamed of yourself
Nice write up. I can't believe you would let kids around your car. But as long as you trust them and they have respect for cars. They are now ScionLife celebrities.
North Regional MFIC - Scikotics Nationwide
Sponsored by:
NonStopTuning | Stewart Warner Performance | S-Max Performance
THansenite is offline   Reply With Quote
Old 06-09-2006, 01:33 AM   #17
FLEA
FLEA 28/M
View this user's Flint Mica tC
View this user's Natural White Tundra
Child labor laws is right. Markus cheated....looks like he had some help from Jedi Master Yoda!
FLEA is offline   Reply With Quote
Old 06-09-2006, 03:54 AM   #18
RedLine_tC
RedLine_tC's Avatar
RedLine_tC 24/M
View this user's Super White Camry
Send a message via AIM to RedLine_tC Send a message via Yahoo to RedLine_tC
man ur kids know more than you lol but good little tech on the aem intake!
- - SL Member #12308 - -
*-_~06 Flint Mica tC~_-*
Stock 17's
Tein S-Techs
Blacked Out Headlights and Anzo Taillights
Sponsors-
Malihini Customs
RedLine_tC is offline   Reply With Quote
Old 06-09-2006, 04:52 AM   #19
tC9o9
tC9o9's Avatar
tC9o9 23/M
View this user's Nautical Blue Metallic tC
Send a message via AIM to tC9o9
ALPHASQUAD
WTT APEXI CATBACK FOR STOCK EXHAUST
contact me for info on any of the above
tC9o9 is offline   Reply With Quote
Old 06-09-2006, 06:08 AM   #20
20tCDude05
20tCDude05 23/M
View this user's Lunar Mist Metallic Tacoma
Send a message via AIM to 20tCDude05 Send a message via MSN to 20tCDude05 Send a message via Yahoo to 20tCDude05
I oughta call those kids up and have them do my Injen CAI.
20tCDude05 is offline   Reply With Quote
Reply
Tags
air, ait, cold, diy, install, installation, instructions, intake, location, put, scion, sensor, tc, tein, xa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin® v3.7.5, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
