Scionlife.com Scion Enthusiast Community
Go Back   Scionlife.com » General » Off-topic Cafe
Register Search Today's Posts Mark Forums Read Vendors
Reply
Old 08-24-2004, 01:47 AM   #1
Diluvium
Diluvium's Avatar
Diluvium 109/M
View this user's Silver Streak Mica tC
Default i-VTEC vs VVT-i vs VANOS vs others....
anyone knows which is the better technology?
anything special for each?
what are other manufacturers made up there own technology???
2005 Scion tC (Silver Streak Mica)
Diluvium is offline   Reply With Quote
Old 08-24-2004, 01:53 AM   #2
Nick_AGP
Nick_AGP
Send a message via AIM to Nick_AGP
Vtec is probably the best cam technology I've seen. Two cam lobes works great.
VVTI can't even be compared. VVTI just changes timing, not lift. Vtech is amazing technology that every car should have.
Nick
www.agpturbo.com
Nick_AGP is offline   Reply With Quote
Old 08-24-2004, 02:21 AM   #3
Kayden
Kayden
Send a message via AIM to Kayden Send a message via MSN to Kayden Send a message via Yahoo to Kayden
vvti cuz the horse power kicks in at a lower rpm.....plus the v-tec engine has too many moving parts and its hella exspensive on the the timing chain, with vvti you get better fuel economy
Island boy jus trying to make it in the big world
Kayden is offline   Reply With Quote
Old 08-24-2004, 02:48 AM   #4
empleh
empleh 110/M
View this user's Indigo Ink Pearl xA
Send a message via AIM to empleh Send a message via MSN to empleh Send a message via Yahoo to empleh
well, they are two totally different systems. VTEC uses camshafts with dual profiles. so when you hit higher rpm, it clicks over to the other, better breathing camshaft. helps with gas mileage, high rpm power, and emissions. VVTI, has variable valve timing with intelligence, and since i don't have a lot of time right now, basically what that equates to is better overall power. from low rpm to redline. better driveablility. anyways, go to howstuffworks.com and check it out, its a pretty informative site.
Formerly of Toyota of Glendale, but now I'm home where I belong.
empleh is offline   Reply With Quote
Old 08-24-2004, 03:50 AM   #5
hahaitzskippy
hahaitzskippy 24/M
View this user's Super White tC
Send a message via AIM to hahaitzskippy Send a message via MSN to hahaitzskippy
how bout the SRT4... doesnt it have NOTHING???
hahaitzskippy is offline   Reply With Quote
Old 08-24-2004, 03:58 AM   #6
tcwannab
tcwannab
Send a message via AIM to tcwannab
Quote:
yea nothing.... except a turbo, a strong block and internals and a hell of a lotta hp and torque
2005 Super White Scion tC
"mods": OBX petal covers, sill guards, bumper applique, lip spoiler, mudguards, floormats, LED multicolor liteglow kit, TRD springs, Civic SI antenna, Kenwood Exelon 6.5" touch screen DVD/cd/mp3 headunit, LED Rear tails by TYC and 20% tint
tcwannab is offline   Reply With Quote
Old 08-24-2004, 04:10 AM   #7
Forevermore
Forevermore's Avatar
Forevermore
ya when i get my tc i think ill go ahead and get a vtec put on it. that should give it about 30-40whp once thats done ill get a turbo, that will add about 70 whp then ill get a blow off valve cause my friend says they give like an extra 20whp when you use them with a turbo. i might get the blow off valve before the turbo thogh just cause it makes that cool sound. by the time im done ill be running 11s all day long
Forevermore is offline   Reply With Quote
Old 08-24-2004, 04:21 AM   #8
tcwannab
tcwannab
Quote:
funniest thing iv read all night
Old 08-24-2004, 04:24 AM   #9
chucksu
chucksu's Avatar
chucksu 25/M
View this user's Camouflage Metallic xB
Send a message via AIM to chucksu Send a message via MSN to chucksu Send a message via Yahoo to chucksu
When looking at V-TEC you would compare it to VVTI-L. Most V-TEC systems work on both the intake & exhaust cams while VVTI is just the intake I think. Now the real V-TEC power was the B series engines. Build up one of those engines & put a turbo. I would love to drive a B18C5 with a turbo. Just taking it up to 8,100rpm. :twisted: Have a killer exhaust on that thing also just to scare the old ppl.
Met 7 SLers!
Post Record 34.89ppd
Anime Fans: http://www.scionlife.com/forums/viewtopic.php?t=79625
My Space: http://www.myspace.com/chucksu
www.sciongirls.com www.animesuki.com
chucksu is offline   Reply With Quote
Old 08-24-2004, 04:29 AM   #10
BSP_5c10n
BSP_5c10n 23/M
View this user's Black Sand Pearl tC
Send a message via AIM to BSP_5c10n Send a message via MSN to BSP_5c10n Send a message via Yahoo to BSP_5c10n
Acutally VVT-i works with both the intake and exhaust cams. VVTL-i (Celica GTS tech) controls both valve timing and lift, while VVT-i just controls timing. I'm not sure if VTEC controls lift so I can't say for sure which is the better system.
BSP_5c10n is offline   Reply With Quote
Old 08-24-2004, 04:40 AM   #11
ImBack
DelMarVa
ImBack's Avatar
ImBack 34/M
View this user's Envy Green xB RS03
View this user's Polar White xA
Default How much of a difference.....
in power and economy is there between the VVTi and the VVTLi. If it would be a worthwhile transition to migrate to a VVTLi for higher end power could it be accomplished without as much hassel they're used in similar models of the same line... (i.e. corrollas use the VVTi standard but use the VVTLi in the XRS model along with a 6 spd transmission )
2006 RS 3.0 Green Envy xB #798
Departed- 2004 xA, Polar White, 5Spd
USN Retired
ImBack is offline   Reply With Quote
Old 08-24-2004, 04:43 AM   #12
Rich_Manas
Rich_Manas's Avatar
Rich_Manas 33/M
here's a link that explains variable valve timing and compares the differences between vvt-i, vvtl-i, vtec, i-vtec and vanos.
http://www.geocities.com/gkurka2001/CarTech/vvt_1.htm
what a lot of people don't know is that variable valve timing was not invented by honda but toyota and gm in the early 70's. honda was the first automaker that used it in production cars.
http://www.aatap.com/
Kearny Mesa Scion
San Diego, CA
858-279-8151
rmanas@penskeautomotive.com
San Diego #1 Volume Scion Dealer Since 2003
There's a reason why we are #1
Rich_Manas is offline   Reply With Quote
Old 08-24-2004, 01:38 PM   #13
Scion05tC
Scion05tC
Yes, I have to agree. Comedy Gold. You sir, are teh funnay.
Scion05tC is offline   Reply With Quote
Old 08-24-2004, 05:20 PM   #14
ScionSips
ScionSips
LMFAO I just fell out of my chair. I scrolled past it at first then went back after I saw your alls post. holly ____ that was funny.
Michael S. Sipple
Kerry Scion
6050 Hopeful Church Rd.
Florence, Ky 41042
859-371-3939
KerryScion.com
ScionSips is offline   Reply With Quote
Old 08-24-2004, 05:25 PM   #15
BoomBox757
DelMarVa
BoomBox757 108/M
View this user's Black Sand Pearl xB
Send a message via AIM to BoomBox757
but they do make a cool sound, there was one behind me yesterday, the loudest one i've ever heard
BoomBox757 is offline   Reply With Quote
Old 08-29-2008, 11:52 PM   #16
tlk90
tlk90's Avatar
tlk90 19/M
View this user's Classic Silver Metallic tC
Send a message via AIM to tlk90
ahhahahahahahahhahahaha he can't be serious.
08 CSM tC
Rochester Institute of Technology
tlk90 is offline   Reply With Quote
Old 08-31-2008, 01:10 AM   #17
xFistsClenchedx
xFistsClenchedx 28/M
View this user's Stingray Metallic xB
That reminds me of this awesome video lol
http://videos.streetfire.net/video/RICER-VIDEO_4385.htm
xFistsClenchedx is offline   Reply With Quote
Old 08-31-2008, 01:26 AM   #18
equinox2355
equinox2355 26/M
Quote:
Im sorry but that is not correct. VVT-i is only intake. If it has DUAL VVT-i then it does intake AND exhaust (thats why the 1.8 motor in the xD is so awesome (also the corolla has it, and the matrix i think (only 1.8L motors))
equinox2355 is offline   Reply With Quote
Old 08-31-2008, 03:40 AM   #19
jct
jct's Avatar
jct 70/M
only the 1ZR-FE, 2ZR-FE and the 3ZR-FE have the dual VVT-i
Apathy, it works hard for you!!!
jct is offline   Reply With Quote
Old 08-31-2008, 05:30 AM   #20
equinox2355
equinox2355 26/M
Quote:
yes, exactly
Reply
Tags
difference, ivtec, ivtech, killer, motor, scion, tc, vanos, video, vs, vtec, vtech, vvt, vvti, vvtl, vvtli, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin® v3.7.5, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
