J3st3r's Setup(s)
Old 09-17-2009 | 11:55 PM
j3st3r's Avatar
Music City Scions
Default J3st3r's Setup(s)
Well I was trying to keep this under the radar but had to let the cat out of the bag so to speak on another thread. I am in the process of a whole new setup on the car for the 2010 Time Attack series.
Finally had to tear down the setup that I got from a....well I will leave the piece of $...name out of this...and WOW the things you find and learn. Here is kind of a log as to where we stand.
Problems Found:
1) Cylinder walls washed and scored (looked like engine was assembled dirty)
2) #4 Rod was through 2 of the 3 layers of bearing, so it was close to being spun
3) Valve clearances were wrong, and under operating temp, were either barely sealing or not sealing
4) One valve was bent and had to be replaced
Good news:
Engine does have Carillo Rods
Engine does have Ferrera Valves
Head is ported and has oversized valves
Engine block was notched to accept Carillo rods
Solutions:
Head has been fixed(clearances, new valve, etc)
Cylinders were honed to accept oversized pistons
Engine will be assembled and built by people that know what the _____ they are doing!
Car will be setup for next years Time Attack Series, this will include roll cage, LSD, BBK, and tires!
Pictures:
Balance Shafts Were Removed BUT....They did not remove the gear from the crank.....
You can clearly see the scuff marks and damage on the old pistons, and bearings
Motor Had Less Than 4k Miles On.....Great Engine Builder.....NOT
Now onto the new setup
Finished Honing
Crank Milled, Balanced, & Ready for Assembly
Pistons and Rods Assembled
Block Notched for Carrillo Rods
ARP Mains Installed
Bottom End Assembled
Valve Seats Finished Being Cut in Head!
More shots of the Head Prepped and Ready to Go!
Fairly Obvious Where the New Valve Is!!
Ports Cleaned Up
Clutch Setup
The Stash!
I DO NEED SOME HELP THOUGH.....PLEASE SEE HERE..https://www.scionlife.com/forums/sho...d.php?t=171615
Old 09-18-2009 | 12:08 AM
tCtCtC's Avatar
watching
Old 09-18-2009 | 04:01 AM
CSUnited14's Avatar
this will be nice when your done
Old 09-18-2009 | 05:08 AM
Ace83's Avatar
Ronin Scion
nice, who is doing your engine build this time? are you getting whole new internals?
Old 09-18-2009 | 05:30 AM
Domo's Avatar
oh i love built engines.
Old 09-18-2009 | 05:59 AM
j3st3r's Avatar
Music City Scions
Not all new internals, just oversized CP Pistons and rings...The Carrillo rods are fine but the big end of the rods were machined to assure that everything was in the round and in spec. The crank is the same too it was just rebalanced, machined, and the balance shaft gear was removed(which should have been done previously). ARP main studs were also added, and the block was line bored. The head was also re done.
Old 09-18-2009 | 06:44 AM
Ace83's Avatar
Ronin Scion
I see.. looks like the first build wasnt so good.. lethal injection is doing the work?
Old 09-18-2009 | 06:53 AM
j3st3r's Avatar
Music City Scions
First build was probably one of the worst experiences of my life.....I bought the car in Oct 2005, and it has 12k miles on it....it was down for the better part of 2 years on that one.......Lethal is doing the work.....they have been GREAT to work with...and their machine shop is freaking phenomenal.
Old 09-18-2009 | 02:52 PM
THansenite's Avatar
Looking good Brian. I can't wait to see this engine when it is done...especially since it is being done by a company that knows what they are doing. Definitely going to be watching this thread.
Old 11-04-2009 | 05:40 AM
mikescion's Avatar
what turbo kit you rocking?
Old 11-04-2009 | 05:48 AM
crush02342002's Avatar
I remember seeing the car when it was in houston...never got to hear it run though
Old 11-06-2009 | 04:55 AM
j3st3r's Avatar
Music City Scions
GT-K 550
car is buttoned up and tuned..... right now on 5psi until I can get some miles on it.
Old 11-06-2009 | 04:58 AM
j3st3r's Avatar
Music City Scions
I wont even voice my thoughts and opinions on the shop/people in Houston...there are a couple on here, and several posts on how I feel and what I went through with those........<insert you swear word here>
Turbonetics GT-K 550
Old 11-06-2009 | 05:34 AM
I fully understand brethren....trust me!!!....the poop iv had to deal with is crazy.
I wish you the best of luck this go round.
Old 11-06-2009 | 05:38 AM
btw the engine looks pimp...bravo to you and the shop.
Old 11-06-2009 | 06:42 AM
m6ar2cel6oTC's Avatar
got a better picture of the turbo mani?
Old 11-06-2009 | 07:59 AM
ZTC's Avatar
ZTC
i thought this was shopped for a second with the engine sitting in front of the car lol
Old 11-06-2009 | 11:54 AM
ElevationTC's Avatar
The head looks like it was never decked!?
Hows the car? How many miles now! Also was that original bearing a standard acl? did not look like a acl race bearing! What were your findings on why it happened?
Old 11-06-2009 | 12:09 PM
Beckenbauer's Avatar
Music City Scions
MCS FTW! I just cant wait to see the unicorn...its been like forever since ive seen her last ha
Old 11-06-2009 | 05:32 PM
scikotictc232's Avatar
nice set up man, what turbo set up u got ? pictures of it all put together.
Quick Reply: J3st3r's Setup(s)
